[PATCH 15/26] cpukit/libmisc/cpuuse: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Mar 18 16:21:22 UTC 2022
Updates #3053.
cpukit/libmisc/cpuuse/cpuinforeport.c | 25 ++++++++++++++++++++++---
cpukit/libmisc/cpuuse/cpuusagedata.c | 25 ++++++++++++++++++++++---
cpukit/libmisc/cpuuse/cpuusagereport.c | 25 ++++++++++++++++++++++---
cpukit/libmisc/cpuuse/cpuusagereset.c | 25 ++++++++++++++++++++++---
cpukit/libmisc/cpuuse/cpuusagetop.c | 25 ++++++++++++++++++++++---
cpukit/libmisc/cpuuse/cpuuseimpl.h | 25 ++++++++++++++++++++++---
6 files changed, 132 insertions(+), 18 deletions(-)
diff --git a/cpukit/libmisc/cpuuse/cpuinforeport.c b/cpukit/libmisc/cpuuse/cpuinforeport.c
index e8df78a359..dcbc7f1747 100644
--- a/cpukit/libmisc/cpuuse/cpuinforeport.c
+++ b/cpukit/libmisc/cpuuse/cpuinforeport.c
@@ -1,9 +1,28 @@
* Copyright (c) 2016 embedded brains GmbH. All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/libmisc/cpuuse/cpuusagedata.c b/cpukit/libmisc/cpuuse/cpuusagedata.c
index 0d06dd3e5c..350ade309b 100644
--- a/cpukit/libmisc/cpuuse/cpuusagedata.c
+++ b/cpukit/libmisc/cpuuse/cpuusagedata.c
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* COPYRIGHT (c) 1989-2009
* On-Line Applications Research Corporation (OAR).
+ * are met:
diff --git a/cpukit/libmisc/cpuuse/cpuusagereport.c b/cpukit/libmisc/cpuuse/cpuusagereport.c
index ea21e73dc1..bc7c897db5 100644
--- a/cpukit/libmisc/cpuuse/cpuusagereport.c
+++ b/cpukit/libmisc/cpuuse/cpuusagereport.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2010.
+ * are met:
diff --git a/cpukit/libmisc/cpuuse/cpuusagereset.c b/cpukit/libmisc/cpuuse/cpuusagereset.c
index d677c6d330..bdfba7c944 100644
--- a/cpukit/libmisc/cpuuse/cpuusagereset.c
+++ b/cpukit/libmisc/cpuuse/cpuusagereset.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libmisc/cpuuse/cpuusagetop.c b/cpukit/libmisc/cpuuse/cpuusagetop.c
index 51d049257a..045a38ae55 100644
--- a/cpukit/libmisc/cpuuse/cpuusagetop.c
+++ b/cpukit/libmisc/cpuuse/cpuusagetop.c
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* COPYRIGHT (c) 2014.
+ * are met:
diff --git a/cpukit/libmisc/cpuuse/cpuuseimpl.h b/cpukit/libmisc/cpuuse/cpuuseimpl.h
index 32184c3636..1162d1e892 100644
--- a/cpukit/libmisc/cpuuse/cpuuseimpl.h
+++ b/cpukit/libmisc/cpuuse/cpuuseimpl.h
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
#ifndef __RTEMS_CPUUSEIMPL_h
2.24.4
