[PATCH 14/26] cpukit/libmisc/capture: Manually change license to BSD-2
Tue Mar 22 16:24:33 UTC 2022
On Tue, Mar 22, 2022 at 2:49 AM Christian MAUDERER <
christian.mauderer at embedded-brains.de> wrote:
> Am 18.03.22 um 17:21 schrieb Joel Sherrill:
> > These files did not follow the standard format and needed to be
> > changed manually.
> > Updates #3053.
> >   cpukit/libmisc/capture/README                 |  4 +-
> >   cpukit/libmisc/capture/capture-cli.c          | 57 ++++++++++++-------
> >   cpukit/libmisc/capture/capture.c              | 55 +++++++++++-------
> >   cpukit/libmisc/capture/capture_buffer.c       | 49 ++++++++++------
> >   cpukit/libmisc/capture/capture_buffer.h       | 42 +++++++++-----
> >   cpukit/libmisc/capture/capture_support.c      | 57 ++++++++++++-------
> >   .../libmisc/capture/capture_user_extension.c  | 51 +++++++++++------
> >   7 files changed, 200 insertions(+), 115 deletions(-)
> > diff --git a/cpukit/libmisc/capture/README
> b/cpukit/libmisc/capture/README
> > index 3e59637149..806bb37d1f 100644
> > --- a/cpukit/libmisc/capture/README
> > +++ b/cpukit/libmisc/capture/README
> > @@ -1,7 +1,7 @@
> >             RTEMS Performance Monitoring and Measurement Framework
> > -                              Copyright 2002-2007 Chris Johns (
> chrisj at rtems.org)
> > -        23
> April 2002
> > +          Copyright 2002-2007 Chris Johns (chrisj at rtems.org)
> > +                          23 April 2002
> >   This directory contains the source code for the performance monitoring
> and
> >   measurement framework. It is more commonly know as the capture engine.
> > diff --git a/cpukit/libmisc/capture/capture-cli.c
> b/cpukit/libmisc/capture/capture-cli.c
> > index d489d9f32a..d8afc982a1 100644
> > --- a/cpukit/libmisc/capture/capture-cli.c
> > +++ b/cpukit/libmisc/capture/capture-cli.c
> > @@ -1,25 +1,40 @@
> > -  Copyright 2002, 2015 Chris Johns <chrisj at rtems.org>
> > -  All rights reserved.
> > -  COPYRIGHT (c) 2014.
> > -  On-Line Applications Research Corporation (OAR).
> > -  The license and distribution terms for this file may be
> > -  found in the file LICENSE in this distribution.
> > -  This software with is provided ``as is'' and with NO WARRANTY.
> > -  RTEMS Performance Monitoring and Measurement Framework.
> > -  This is the Target Interface Command Line Interface. You need
> > -  start the RTEMS monitor.
> > + * @file
> > + * @brief RTEMS Performance Monitoring and Measurement Framework.
> > + * This is the Target Interface Command Line Interface. You need
> > + * start the RTEMS monitor.
> > + * Copyright 2002, 2015 Chris Johns <chrisj at rtems.org>.
> > + * All rights reserved.
> > + * COPYRIGHT (c) 2014.
> > + * On-Line Applications Research Corporation (OAR).
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> >   #ifdef HAVE_CONFIG_H
> >   #include "config.h"
> > diff --git a/cpukit/libmisc/capture/capture.c
> b/cpukit/libmisc/capture/capture.c
> > index bba7d91396..2ed607ecaf 100644
> > --- a/cpukit/libmisc/capture/capture.c
> > +++ b/cpukit/libmisc/capture/capture.c
> > @@ -1,24 +1,39 @@
> > -  Copyright 2002, 2016 Chris Johns <chrisj at rtems.org>.
> > -  COPYRIGHT (c) 1989-2014.
> > -  This is the Capture Engine component.
> > + * @file
> > + * This is the Capture Engine component.
> > + * Copyright 2002, 2016 Chris Johns <chrisj at rtems.org>.
> > + * COPYRIGHT (c) 1989-2014.
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> >   #include "config.h"
> > diff --git a/cpukit/libmisc/capture/capture_buffer.c
> b/cpukit/libmisc/capture/capture_buffer.c
> > index 967842000b..2b7d6947e5 100644
> > --- a/cpukit/libmisc/capture/capture_buffer.c
> > +++ b/cpukit/libmisc/capture/capture_buffer.c
> > @@ -1,22 +1,35 @@
> > + * @file
> > + * to start the RTEMS monitor.
> I think there is a missing empty line after @brief. At least all other
> files have the new line.
Fixed. This would be a good thing to have a regular expression to look for.
> > + *  COPYRIGHT (c) 2014.  On-Line Applications Research Corporation
> (OAR).
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> >   #include "config.h"
> > diff --git a/cpukit/libmisc/capture/capture_buffer.h
> b/cpukit/libmisc/capture/capture_buffer.h
> > index af75c0204c..8f2f59b39f 100644
> > --- a/cpukit/libmisc/capture/capture_buffer.h
> > +++ b/cpukit/libmisc/capture/capture_buffer.h
> > @@ -7,21 +7,33 @@
> > -  Copyright 2016 Chris Johns <chrisj at rtems.org>.
> > + * Copyright 2016 Chris Johns <chrisj at rtems.org>.
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> >   #ifndef __CAPTURE_BUFFER_H_
> >   #define __CAPTURE_BUFFER_H_
> > diff --git a/cpukit/libmisc/capture/capture_support.c
> b/cpukit/libmisc/capture/capture_support.c
> > index e2438fb23b..ab301ddeb3 100644
> > --- a/cpukit/libmisc/capture/capture_support.c
> > +++ b/cpukit/libmisc/capture/capture_support.c
> > @@ -1,25 +1,40 @@
> > -  This is a set of print support routines that may be shared between
> > -  the RTEMS monitor and direct callers of the capture engine.
> > + * @file
> > + * This is a set of print support routines that may be shared between
> > + * the RTEMS monitor and direct callers of the capture engine.
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> >   #include "config.h"
> > diff --git a/cpukit/libmisc/capture/capture_user_extension.c
> b/cpukit/libmisc/capture/capture_user_extension.c
> > index ae4107afbc..8f793f1c9b 100644
> > --- a/cpukit/libmisc/capture/capture_user_extension.c
> > +++ b/cpukit/libmisc/capture/capture_user_extension.c
> > @@ -1,22 +1,37 @@
> > + * @file
> > -  Copyright 2002, 2016 Chris Johns <chrisj at rtems.org>. All rights
> reserved.
> > + * Copyright 2002, 2016 Chris Johns <chrisj at rtems.org>. All rights
> reserved.
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> >   #include "config.h"
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
