[PATCH 25/26] cpukit/libmisc/check: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Mar 18 16:21:32 UTC 2022
Updates #3053.
cpukit/libmisc/stackchk/check.c | 25 ++++++++++++++++++++++---
1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/cpukit/libmisc/stackchk/check.c b/cpukit/libmisc/stackchk/check.c
index fa0c3ea1ed..48342ce957 100644
--- a/cpukit/libmisc/stackchk/check.c
+++ b/cpukit/libmisc/stackchk/check.c
@@ -1,3 +1,5 @@
* @file
@@ -15,9 +17,26 @@
* COPYRIGHT (c) 1989-2010.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
2.24.4
