[PATCH 24/26] cpukit/libmisc/serdbg: Change to BSD-2
Joel Sherrill
joel at rtems.org
Fri Mar 18 16:21:31 UTC 2022
Updates #3053.
cpukit/libmisc/serdbg/serdbg.c | 25 ++++++++++++++++++++++---
cpukit/libmisc/serdbg/serdbgio.c | 25 ++++++++++++++++++++++---
cpukit/libmisc/serdbg/termios_printk.c | 25 ++++++++++++++++++++++---
3 files changed, 66 insertions(+), 9 deletions(-)
diff --git a/cpukit/libmisc/serdbg/serdbg.c b/cpukit/libmisc/serdbg/serdbg.c
index 4fa1335d89..c49e78762a 100644
--- a/cpukit/libmisc/serdbg/serdbg.c
+++ b/cpukit/libmisc/serdbg/serdbg.c
@@ -1,3 +1,5 @@
* RTEMS remote gdb over serial line
@@ -9,9 +11,26 @@
* Copyright (c) 2002 IMD Ingenieurbuero fuer Microcomputertechnik
* All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/libmisc/serdbg/serdbgio.c b/cpukit/libmisc/serdbg/serdbgio.c
index 23a4ca62f0..07c77a0b03 100644
--- a/cpukit/libmisc/serdbg/serdbgio.c
+++ b/cpukit/libmisc/serdbg/serdbgio.c
@@ -1,3 +1,5 @@
* TERMIOS serial gdb interface support
* the functions in this file allow the standard gdb stubs like
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libmisc/serdbg/termios_printk.c b/cpukit/libmisc/serdbg/termios_printk.c
index ba78fa54fc..2b5a7f8e69 100644
--- a/cpukit/libmisc/serdbg/termios_printk.c
+++ b/cpukit/libmisc/serdbg/termios_printk.c
@@ -1,3 +1,5 @@
* TERMIOS printk support
* this module performs low-level printk output using
@@ -8,9 +10,26 @@
+ * are met:
2.24.4
