arm (bsp=xilinx_zynq_a9_qemu ) task in 'testsuites/fstests/fsdosfsname01.exe' failed
Heinz Junkes junkes at fhi-berlin.mpg.de
Sat Mar 19 15:54:33 UTC 2022
Waf: Leaving directory `/home/rtems/ARM_TST/kernel/build/arm/xilinx_zynq_a9_qemu'
Build failed
 -> task in 'testsuites/fstests/fsdosfsname01.exe' failed with exit status 1 (run with -v to display more information)
[1714/4241] Linking build/arm/xilinx_zynq_a9_qemu/testsuites/fstests/mimfs_fspermission.exe
[1715/4241] Linking build/arm/xilinx_zynq_a9_qemu/testsuites/fstests/mdosfs_fsrdwr.exe
/home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: /home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/lib/thumb/armv7-a+simd/hard/libc.a(libc_a-ucsconv.o): in function `ucs_based_conversion_open':
/home/rtems/ARM_TST/rsb/rtems/build/arm-rtems6-gcc-0f001dd-newlib-d88cbd0-x86_64-linux-gnu-1/build/arm-rtems6/thumb/armv7-a+simd/hard/newlib/../../../../../../gnu-mirror-gcc-0f001dd/newlib/libc/iconv/lib/ucsconv.c:66: undefined reference to `_iconv_to_ucs_ces'
/home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: /home/rtems/ARM_TST/rsb/rtems/build/arm-rtems6-gcc-0f001dd-newlib-d88cbd0-x86_64-linux-gnu-1/build/arm-rtems6/thumb/armv7-a+simd/hard/newlib/../../../../../../gnu-mirror-gcc-0f001dd/newlib/libc/iconv/lib/ucsconv.c:66: undefined reference to `_iconv_to_ucs_ces'
/home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: /home/rtems/ARM_TST/rsb/rtems/build/arm-rtems6-gcc-0f001dd-newlib-d88cbd0-x86_64-linux-gnu-1/build/arm-rtems6/thumb/armv7-a+simd/hard/newlib/../../../../../../gnu-mirror-gcc-0f001dd/newlib/libc/iconv/lib/ucsconv.c:78: undefined reference to `_iconv_from_ucs_ces'
/home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: /home/rtems/ARM_TST/rsb/rtems/build/arm-rtems6-gcc-0f001dd-newlib-d88cbd0-x86_64-linux-gnu-1/build/arm-rtems6/thumb/armv7-a+simd/hard/newlib/../../../../../../gnu-mirror-gcc-0f001dd/newlib/libc/iconv/lib/ucsconv.c:77: undefined reference to `_iconv_from_ucs_ces'
/home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: /home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/lib/thumb/armv7-a+simd/hard/libc.a(libc_a-ucsconv.o):/home/rtems/ARM_TST/rsb/rtems/build/arm-rtems6-gcc-0f001dd-newlib-d88cbd0-x86_64-linux-gnu-1/build/arm-rtems6/thumb/armv7-a+simd/hard/newlib/../../../../../../gnu-mirror-gcc-0f001dd/newlib/libc/iconv/lib/ucsconv.c:78: more undefined references to `_iconv_from_ucs_ces' follow
collect2: error: ld returned 1 exit status
Gruss Heinz
