arm (bsp=xilinx_zynq_a9_qemu ) task in 'testsuites/fstests/fsdosfsname01.exe' failed
Sat Mar 19 16:20:40 UTC 2022
Sebastian found this and is working on it. Newlib had a lot of work on its
build system and this broke.
Hopefully he will weigh in with status
On Sat, Mar 19, 2022, 10:54 AM Heinz Junkes <junkes at fhi-berlin.mpg.de>
wrote:
> Waf: Leaving directory
> `/home/rtems/ARM_TST/kernel/build/arm/xilinx_zynq_a9_qemu'
> Build failed
>  -> task in 'testsuites/fstests/fsdosfsname01.exe' failed with exit status
> 1 (run with -v to display more information)
> [1714/4241] Linking
> build/arm/xilinx_zynq_a9_qemu/testsuites/fstests/mimfs_fspermission.exe
> [1715/4241] Linking
> build/arm/xilinx_zynq_a9_qemu/testsuites/fstests/mdosfs_fsrdwr.exe
> /home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld:
> /home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/lib/thumb/armv7-a+simd/hard/libc.a(libc_a-ucsconv.o):
> in function `ucs_based_conversion_open':
> /home/rtems/ARM_TST/rsb/rtems/build/arm-rtems6-gcc-0f001dd-newlib-d88cbd0-x86_64-linux-gnu-1/build/arm-rtems6/thumb/armv7-a+simd/hard/newlib/../../../../../../gnu-mirror-gcc-0f001dd/newlib/libc/iconv/lib/ucsconv.c:66:
> undefined reference to `_iconv_to_ucs_ces'
> /home/rtems/ARM_TST/rsb/rtems/build/arm-rtems6-gcc-0f001dd-newlib-d88cbd0-x86_64-linux-gnu-1/build/arm-rtems6/thumb/armv7-a+simd/hard/newlib/../../../../../../gnu-mirror-gcc-0f001dd/newlib/libc/iconv/lib/ucsconv.c:78:
> undefined reference to `_iconv_from_ucs_ces'
> /home/rtems/ARM_TST/rsb/rtems/build/arm-rtems6-gcc-0f001dd-newlib-d88cbd0-x86_64-linux-gnu-1/build/arm-rtems6/thumb/armv7-a+simd/hard/newlib/../../../../../../gnu-mirror-gcc-0f001dd/newlib/libc/iconv/lib/ucsconv.c:77:
> /home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/lib/thumb/armv7-a+simd/hard/libc.a(libc_a-ucsconv.o):/home/rtems/ARM_TST/rsb/rtems/build/arm-rtems6-gcc-0f001dd-newlib-d88cbd0-x86_64-linux-gnu-1/build/arm-rtems6/thumb/armv7-a+simd/hard/newlib/../../../../../../gnu-mirror-gcc-0f001dd/newlib/libc/iconv/lib/ucsconv.c:78:
> more undefined references to `_iconv_from_ucs_ces' follow
> collect2: error: ld returned 1 exit status
> Gruss Heinz
> devel mailing list
> devel at rtems.org
