[PATCH] GDB: Prefer Python 3 over 2
Chris Johns
chrisj at rtems.org
Sun Mar 20 22:22:31 UTC 2022
On 19/3/2022 8:33 pm, Sebastian Huber wrote:
> On 18/03/2022 22:56, Chris Johns wrote:
>>> On 19 Mar 2022, at 2:40 am, Sebastian Huber
>>> <sebastian.huber at embedded-brains.de> wrote:
>>> On 17/03/2022 12:51, Sebastian Huber wrote:
>>>> This fixes the build of a recent GDB version:
>>>> gdb/python/py-micmd.c: In function 'int
>>>> micmdpy_uninstall_command(micmdpy_object*)':
>>>> gdb/python/py-micmd.c:430:20: error: 'PyDict_GetItemWithError' was not
>>>> declared in this scope
>>>> PyObject *curr = PyDict_GetItemWithError (mi_cmd_dict.get (),
>> Has a bug report been raised with gdb?
> The Python 2 EOL was January 1, 2020. This code was added by:
> commit 740b42ceb7c7ae7b5343183782973576a93bc7b3
> Author: Andrew Burgess <aburgess at redhat.com>
> Date: Tue Jun 23 14:45:38 2020 +0100
> gdb/python/mi: create MI commands using python
> It is not a bug from my point of view.
The change has been reviewed again ...
commit 5ec0444e8312c17e628739ebd7b8f0e29df3c9e9
Date: Fri Mar 18 15:55:34 2022 +0000
gdb: supply PyDict_GetItemWithError when compiling with Python2
Commit
Introduced a use of PyDict_GetItemWithError, which is not available in
Python2, and so the Python2 build was broken.
This commit provides a work around for this:
#define PyDict_GetItemWithError PyDict_GetItem
The arguments passed to these calls are identical, the difference is
that the WithError version will return with an exception raised in
some error cases, while the PyDict_GetItem suppresses some errors, and
just returns nullptr.
Given that we are almost at the GDB 12 branch point, this commit is
the easiest change to get the Python2 build working again. After GDB
12 branches the plan is to remove Python2 support, so this #define
will be removed anyway.
As far as functionality I think this #define will be fine. In the
"normal" no error case, then obviously, everything will be fine. The
only difference is what happens when an error occurs.
The only errors I think could happen if Python runs into problems
hashing the string, or comparing the strings for equality. Given the
limited strings we're working with I don't expect that this should
occur during normal operation. So, my expectation is that this should
only happen if they user has gone and messed around with this hash in
some way - in which case I think it's OK if weird things happen.
This issue was discussed on IRC, and I think Simon might be working on
an alternative patch to remove the _mi_commands dictionary from the
gdb module, in which case the use of PyDict_GetItemWithError will be
removed completely. I'm posting this just in case people want to
consider a minimal work around for the breakage in the short term.
>>> I was able to build the latest GDB with this patch. Otherwise all
>>> architectures failed with the above error.
>> Has gdb dropped Python 2 support?
> It seems so.
It seems from above is after gdb 12 has branched. We could settle on gdb 12 for
rtems6?
>> What happens on a host without python3 installed? Does the error appear? Does
>> this in effect force RTEMS to drop the Python2 requirement for rtems6?
> I guess if we want to use the next GDB release, then Python 3 is required.
Then this changes rtems6 because it forces a major change I had not expected on
to rtems6. I suggest a separate thread be started to again consider removing
python 2 support for rtems6. It do not bother me but we have some users where is
may so it is best to ask openly.
