[PATCH] GDB: Prefer Python 3 over 2
Mon Mar 21 06:54:04 UTC 2022
On 20/03/2022 23:22, Chris Johns wrote:
> On 19/3/2022 8:33 pm, Sebastian Huber wrote:
>> On 18/03/2022 22:56, Chris Johns wrote:
>>>> On 19 Mar 2022, at 2:40 am, Sebastian Huber
>>>> <sebastian.huber at embedded-brains.de> wrote:
>>>> On 17/03/2022 12:51, Sebastian Huber wrote:
>>>>> This fixes the build of a recent GDB version:
>>>>> gdb/python/py-micmd.c: In function 'int
>>>>> micmdpy_uninstall_command(micmdpy_object*)':
>>>>> gdb/python/py-micmd.c:430:20: error: 'PyDict_GetItemWithError' was not
>>>>> declared in this scope
>>>>>      PyObject *curr = PyDict_GetItemWithError (mi_cmd_dict.get (),
>>> Has a bug report been raised with gdb?
>> The Python 2 EOL was January 1, 2020. This code was added by:
>> commit 740b42ceb7c7ae7b5343183782973576a93bc7b3
>> Author: Andrew Burgess <aburgess at redhat.com>
>> Date:   Tue Jun 23 14:45:38 2020 +0100
>>      gdb/python/mi: create MI commands using python
>> It is not a bug from my point of view.
> The change has been reviewed again ...
> commit 5ec0444e8312c17e628739ebd7b8f0e29df3c9e9
> Date:   Fri Mar 18 15:55:34 2022 +0000
>      gdb: supply PyDict_GetItemWithError when compiling with Python2
Good timing.
I still think the patch to prefer the Python 3 installation of the
Python 2 installation makes sense. We will have this issue again if I
want to build the GDB main branch some time in the future.
>>>> I was able to build the latest GDB with this patch. Otherwise all
>>>> architectures failed with the above error.
>>> Has gdb dropped Python 2 support?
>> It seems so.
> It seems from above is after gdb 12 has branched. We could settle on gdb 12 for
> rtems6?
Given that GDB 12 isn't released yet this doesn't sound like a constraint.
>>> What happens on a host without python3 installed? Does the error appear? Does
>>> this in effect force RTEMS to drop the Python2 requirement for rtems6?
>> I guess if we want to use the next GDB release, then Python 3 is required.
> Then this changes rtems6 because it forces a major change I had not expected on
> to rtems6. I suggest a separate thread be started to again consider removing
> python 2 support for rtems6. It do not bother me but we have some users where is
> may so it is best to ask openly.
Yes, this makes sense.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
