[PATCH 01/26] cpukit/libdl/rtl-alloc-check.py: Change to BSD-2 by hand
Christian MAUDERER
christian.mauderer at embedded-brains.de
Tue Mar 22 07:36:32 UTC 2022
Shouldn't there be a SPDX-line added to this file?
Am 18.03.22 um 17:21 schrieb Joel Sherrill:
> Updates #3053.
> cpukit/libdl/rtl-alloc-check.py | 30 +++++++++++++++++++++++-------
> 1 file changed, 23 insertions(+), 7 deletions(-)
> diff --git a/cpukit/libdl/rtl-alloc-check.py b/cpukit/libdl/rtl-alloc-check.py
> index c2145a768e..3d6b024442 100644
> --- a/cpukit/libdl/rtl-alloc-check.py
> +++ b/cpukit/libdl/rtl-alloc-check.py
> @@ -1,11 +1,4 @@
> -# Copyright (c) 2019 Chris Johns <chrisj at rtems.org>.
> -# All rights reserved.
> -# The license and distribution terms for this file may be
> -# found in the file LICENSE in this distribution or at
> -# http://www.rtems.org/license/LICENSE.
> # Check the allocations for libdl:
> # 1. Turn on the allocation trace.
> @@ -13,7 +6,30 @@
> # 2. Load and unload object files.
> # 3. Capture the trace output and feed to this tool
> +# Copyright (c) 2019 Chris Johns <chrisj at rtems.org>.
> +# All rights reserved.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions
> +# are met:
> +# 1. Redistributions of source code must retain the above copyright
> +# notice, this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> +# notice, this list of conditions and the following disclaimer in the
> +# documentation and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> from __future__ import print_function
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
