[PATCH 01/26] cpukit/libdl/rtl-alloc-check.py: Change to BSD-2 by hand
Joel Sherrill
joel at rtems.org
Tue Mar 22 16:36:36 UTC 2022
On Tue, Mar 22, 2022 at 2:36 AM Christian MAUDERER <
christian.mauderer at embedded-brains.de> wrote:
> Shouldn't there be a SPDX-line added to this file?
Yep. I went back and reviewed all the manual edits and ensured
also had SPDX notation.
Another example where a pass after all this is over with scripts
and regular expressions to verify things will be good.
Thanks.
> Am 18.03.22 um 17:21 schrieb Joel Sherrill:
> > Updates #3053.
> > cpukit/libdl/rtl-alloc-check.py | 30 +++++++++++++++++++++++-------
> > 1 file changed, 23 insertions(+), 7 deletions(-)
> > diff --git a/cpukit/libdl/rtl-alloc-check.py
> b/cpukit/libdl/rtl-alloc-check.py
> > index c2145a768e..3d6b024442 100644
> > --- a/cpukit/libdl/rtl-alloc-check.py
> > +++ b/cpukit/libdl/rtl-alloc-check.py
> > @@ -1,11 +1,4 @@
> > -# Copyright (c) 2019 Chris Johns <chrisj at rtems.org>.
> > -# All rights reserved.
> > -# The license and distribution terms for this file may be
> > -# found in the file LICENSE in this distribution or at
> > -# http://www.rtems.org/license/LICENSE.
> > # Check the allocations for libdl:
> > # 1. Turn on the allocation trace.
> > @@ -13,7 +6,30 @@
> > # 2. Load and unload object files.
> > # 3. Capture the trace output and feed to this tool
> > +# Copyright (c) 2019 Chris Johns <chrisj at rtems.org>.
> > +# All rights reserved.
> > +# Redistribution and use in source and binary forms, with or without
> > +# modification, are permitted provided that the following conditions
> > +# are met:
> > +# 1. Redistributions of source code must retain the above copyright
> > +# notice, this list of conditions and the following disclaimer.
> > +# 2. Redistributions in binary form must reproduce the above copyright
> > +# notice, this list of conditions and the following disclaimer in the
> > +# documentation and/or other materials provided with the
> distribution.
> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > +# POSSIBILITY OF SUCH DAMAGE.
> > from __future__ import print_function
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
