[PATCH 22/26] cpukit/libmisc/redirector: Manually change license to BSD-2
Joel Sherrill
joel at rtems.org
Tue Mar 22 16:10:42 UTC 2022
On Tue, Mar 22, 2022 at 2:51 AM Christian MAUDERER <
christian.mauderer at embedded-brains.de> wrote:
> Am 18.03.22 um 17:21 schrieb Joel Sherrill:
> > Updates #3053.
> > cpukit/libmisc/redirector/stdio-redirect.c | 33 ++++++++++++++++------
> > 1 file changed, 25 insertions(+), 8 deletions(-)
> > diff --git a/cpukit/libmisc/redirector/stdio-redirect.c
> b/cpukit/libmisc/redirector/stdio-redirect.c
> > index 7f3e9138a7..712968ac2d 100644
> > --- a/cpukit/libmisc/redirector/stdio-redirect.c
> > +++ b/cpukit/libmisc/redirector/stdio-redirect.c
> > @@ -1,16 +1,33 @@
> > - * Copyright (C) 2014 Chris Johns (chrisj at rtems.org)
> > + * @file
> > - * The license and distribution terms for this file may be
> > - * found in the file LICENSE in this distribution.
> > - * This software with is provided ``as is'' and with NO WARRANTY.
> > + * @brief RTEMS std redirector.
> > - * RTEMS std redirector.
> > + * Copyright (C) 2014 Chris Johns (chrisj at rtems.org)
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + * notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + * notice, this list of conditions and the following disclaimer in
> the
> > + * documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> Is removing that line correct? I think most files have one empty line
> between the license and the first code line.
It isn't correct. I have updated this patch and will commit the fixed
version.
There appear to be 42 files in cpukit/ which have the end of a comment
before #include. I will try to catch these in the patch set but follow up
with
a difference patch to address those that are copyright blocks.
> > #include <errno.h>
> > #include <stdio.h>
> > #include <stdlib.h>
> embedded brains GmbH
> Herr Christian MAUDERER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> phone: +49-89-18 94 741 - 18
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
