[PATCH 23/26] cpukit/libmisc/rtems-fdt: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Mar 18 16:21:30 UTC 2022
Updates #3053.
cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c | 25 +++++++++++++++++++---
cpukit/libmisc/rtems-fdt/rtems-fdt.c | 25 +++++++++++++++++++---
2 files changed, 44 insertions(+), 6 deletions(-)
diff --git a/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c b/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
index 61f20765e0..76f5cd7dbb 100644
--- a/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
+++ b/cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2013-2017 Chris Johns <chrisj at rtems.org>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
* @file
diff --git a/cpukit/libmisc/rtems-fdt/rtems-fdt.c b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
index 484cb1f9e2..7dd2bc1047 100644
--- a/cpukit/libmisc/rtems-fdt/rtems-fdt.c
+++ b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
@@ -1,9 +1,28 @@
+ * are met:
