[PATCH 0/7] cpukit/include: Change License to BSD-2
Joel Sherrill
joel at rtems.org
Thu Mar 24 22:05:59 UTC 2022
Hi
This should take care of cpukit/include for all the files we
currently have permisison for.
--joel
Joel Sherrill (7):
include/*.h: Change license to BSD-2
cpukit/include/dev: Change license to BSD-2
cpukit/include/drvmgr: Change license to BSD-2
cpukit/include/linux: Change license to BSD-2
cpukit/include/pci: Change license to BSD-2
cpukit/include/rtems: Change license to BSD-2
cpukit/include/sys: Change license to BSD-2.
cpukit/include/aio.h | 25 +++++++++++--
cpukit/include/dev/i2c/eeprom.h | 25 +++++++++++--
cpukit/include/dev/i2c/fpga-i2c-slave.h | 25 +++++++++++--
cpukit/include/dev/i2c/gpio-nxp-pca9535.h | 25 +++++++++++--
cpukit/include/dev/i2c/i2c.h | 25 +++++++++++--
cpukit/include/dev/i2c/sensor-lm75a.h | 25 +++++++++++--
cpukit/include/dev/i2c/switch-nxp-pca9548a.h | 25 +++++++++++--
cpukit/include/dev/i2c/ti-ads-16bit-adc.h | 25 +++++++++++--
cpukit/include/dev/i2c/ti-lm25066a.h | 25 +++++++++++--
cpukit/include/dev/i2c/ti-tmp112.h | 25 +++++++++++--
cpukit/include/dev/i2c/xilinx-axi-i2c.h | 25 +++++++++++--
cpukit/include/dev/serial/sc16is752.h | 25 +++++++++++--
cpukit/include/dev/spi/spi.h | 25 +++++++++++--
cpukit/include/drvmgr/drvmgr.h | 32 ++++++++++++++---
cpukit/include/drvmgr/drvmgr_confdefs.h | 32 ++++++++++++++---
cpukit/include/drvmgr/drvmgr_list.h | 32 ++++++++++++++---
cpukit/include/drvmgr/pci_bus.h | 32 ++++++++++++++---
cpukit/include/linux/i2c-dev.h | 25 +++++++++++--
cpukit/include/linux/i2c.h | 25 +++++++++++--
cpukit/include/linux/rbtree.h | 25 +++++++++++--
cpukit/include/linux/spi/spidev.h | 25 +++++++++++--
cpukit/include/mqueue.h | 25 +++++++++++--
cpukit/include/pci.h | 36 ++++++++++++++++---
cpukit/include/pci/access.h | 36 ++++++++++++++++---
cpukit/include/pci/cfg.h | 32 ++++++++++++++---
cpukit/include/pci/cfg_auto.h | 32 ++++++++++++++---
cpukit/include/pci/cfg_peripheral.h | 32 ++++++++++++++---
cpukit/include/pci/cfg_read.h | 35 +++++++++++++++---
cpukit/include/pci/cfg_static.h | 32 ++++++++++++++---
cpukit/include/pci/irq.h | 32 ++++++++++++++---
cpukit/include/rtems/bdpart.h | 25 +++++++++++--
cpukit/include/rtems/bsd.h | 25 +++++++++++--
cpukit/include/rtems/bspcmdline.h | 25 +++++++++++--
cpukit/include/rtems/btimer.h | 25 +++++++++++--
cpukit/include/rtems/chain.h | 25 +++++++++++--
cpukit/include/rtems/clockdrv.h | 25 +++++++++++--
cpukit/include/rtems/concat.h | 25 +++++++++++--
cpukit/include/rtems/confdefs/libpci.h | 25 +++++++++++--
cpukit/include/rtems/console.h | 25 +++++++++++--
cpukit/include/rtems/counter.h | 25 +++++++++++--
cpukit/include/rtems/deviceio.h | 25 +++++++++++--
cpukit/include/rtems/devnull.h | 25 +++++++++++--
cpukit/include/rtems/devzero.h | 25 +++++++++++--
cpukit/include/rtems/dosfs.h | 25 +++++++++++--
cpukit/include/rtems/dumpbuf.h | 29 ++++++++++++---
cpukit/include/rtems/extensiondata.h | 25 +++++++++++--
cpukit/include/rtems/extensionimpl.h | 25 +++++++++++--
cpukit/include/rtems/flashdisk.h | 25 +++++++++++--
cpukit/include/rtems/framebuffer.h | 25 +++++++++++--
cpukit/include/rtems/fs.h | 25 +++++++++++--
cpukit/include/rtems/fsmount.h | 25 +++++++++++--
cpukit/include/rtems/ftpfs.h | 25 +++++++++++--
cpukit/include/rtems/ide_part_table.h | 25 +++++++++++--
cpukit/include/rtems/inttypes.h | 25 +++++++++++--
cpukit/include/rtems/ioimpl.h | 25 +++++++++++--
cpukit/include/rtems/iosupp.h | 25 +++++++++++--
cpukit/include/rtems/irq.h | 25 +++++++++++--
cpukit/include/rtems/jffs2.h | 25 +++++++++++--
cpukit/include/rtems/libcsupport.h | 25 +++++++++++--
cpukit/include/rtems/linkersets.h | 25 +++++++++++--
cpukit/include/rtems/malloc.h | 29 ++++++++++++---
cpukit/include/rtems/media.h | 25 +++++++++++--
cpukit/include/rtems/mptables.h | 25 +++++++++++--
cpukit/include/rtems/nvdisk.h | 25 +++++++++++--
cpukit/include/rtems/pipe.h | 25 +++++++++++--
cpukit/include/rtems/print.h | 25 +++++++++++--
cpukit/include/rtems/printer.h | 25 +++++++++++--
cpukit/include/rtems/profiling.h | 25 +++++++++++--
cpukit/include/rtems/qreslib.h | 25 +++++++++++--
cpukit/include/rtems/rbheap.h | 25 +++++++++++--
cpukit/include/rtems/rbtree.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-bitmaps.h | 25 +++++++++++--
.../include/rtems/rfs/rtems-rfs-block-pos.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-block.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-buffer.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-data.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-dir-hash.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-dir.h | 25 +++++++++++--
.../rtems/rfs/rtems-rfs-file-system-fwd.h | 25 +++++++++++--
.../include/rtems/rfs/rtems-rfs-file-system.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-file.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-group.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-inode.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-link.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-mutex.h | 25 +++++++++++--
cpukit/include/rtems/rfs/rtems-rfs-trace.h | 25 +++++++++++--
cpukit/include/rtems/rtc.h | 25 +++++++++++--
cpukit/include/rtems/rtems-fdt-shell.h | 25 +++++++++++--
cpukit/include/rtems/rtems-fdt.h | 25 +++++++++++--
cpukit/include/rtems/rtems-rfs-format.h | 25 +++++++++++--
cpukit/include/rtems/rtems-rfs-shell.h | 25 +++++++++++--
cpukit/include/rtems/rtems-rfs.h | 25 +++++++++++--
cpukit/include/rtems/rtl/dlfcn-shell.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rap-shell.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rap.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-allocator.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-archive.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-fwd.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-indirect-ptr.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-obj-cache.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-obj-comp.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-obj-fwd.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-obj.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-shell.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-sym.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-trace.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl-unresolved.h | 25 +++++++++++--
cpukit/include/rtems/rtl/rtl.h | 25 +++++++++++--
cpukit/include/rtems/scheduler.h | 25 +++++++++++--
cpukit/include/rtems/serdbg.h | 25 +++++++++++--
cpukit/include/rtems/serdbgcnf.h | 25 +++++++++++--
cpukit/include/rtems/serial_mouse.h | 25 +++++++++++--
cpukit/include/rtems/seterr.h | 25 +++++++++++--
cpukit/include/rtems/shellconfig.h | 25 +++++++++++--
cpukit/include/rtems/sparse-disk.h | 25 +++++++++++--
cpukit/include/rtems/spurious.h | 25 +++++++++++--
cpukit/include/rtems/stackchk.h | 25 +++++++++++--
cpukit/include/rtems/status-checks.h | 25 +++++++++++--
cpukit/include/rtems/stringto.h | 25 +++++++++++--
cpukit/include/rtems/sysinit.h | 25 +++++++++++--
cpukit/include/rtems/termios_printk.h | 25 +++++++++++--
cpukit/include/rtems/termios_printk_cnf.h | 25 +++++++++++--
cpukit/include/rtems/termiostypes.h | 25 +++++++++++--
cpukit/include/rtems/test-info.h | 25 +++++++++++--
cpukit/include/rtems/thread.h | 25 +++++++++++--
cpukit/include/rtems/timecounter.h | 25 +++++++++++--
cpukit/include/rtems/tm27-default.h | 25 +++++++++++--
.../rtems/trace/rtems-trace-buffer-vars.h | 25 +++++++++++--
cpukit/include/rtems/untar.h | 25 +++++++++++--
cpukit/include/rtems/userenv.h | 25 +++++++++++--
cpukit/include/rtems/version.h | 25 +++++++++++--
cpukit/include/rtems/vmeintr.h | 25 +++++++++++--
cpukit/include/rtems/watchdogdrv.h | 25 +++++++++++--
cpukit/include/sys/statvfs.h | 25 +++++++++++--
cpukit/include/sys/utsname.h | 25 +++++++++++--
135 files changed, 3054 insertions(+), 424 deletions(-)
2.24.4
