[PATCH 1/7] include/*.h: Change license to BSD-2
Thu Mar 24 22:06:00 UTC 2022
Updates #3053.
 cpukit/include/aio.h    | 25 ++++++++++++++++++++++---
 cpukit/include/mqueue.h | 25 ++++++++++++++++++++++---
 cpukit/include/pci.h    | 36 +++++++++++++++++++++++++++++++-----
 3 files changed, 75 insertions(+), 11 deletions(-)
diff --git a/cpukit/include/aio.h b/cpukit/include/aio.h
index 95ed0fdb6c..0e428ad86c 100644
--- a/cpukit/include/aio.h
+++ b/cpukit/include/aio.h
@@ -1,3 +1,5 @@
  * @file
@@ -11,9 +13,26 @@
  *  COPYRIGHT (c) 1989-2011.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifndef _AIO_H
diff --git a/cpukit/include/mqueue.h b/cpukit/include/mqueue.h
index 4441629ccb..e0b54beb72 100644
--- a/cpukit/include/mqueue.h
+++ b/cpukit/include/mqueue.h
@@ -1,3 +1,5 @@
  * @file
@@ -22,9 +24,26 @@
+ * are met:
 #ifndef _MQUEUE_H
diff --git a/cpukit/include/pci.h b/cpukit/include/pci.h
index a0e008a2d0..4046168a39 100644
--- a/cpukit/include/pci.h
+++ b/cpukit/include/pci.h
@@ -1,12 +1,38 @@
- * PCI library. Defines in this file was taken from FreeBSD and auto-generated
+ * @file
+ * @brief PCI Library
+ * Defines in this file was taken from FreeBSD and auto-generated
  * pci_ids.h reused from RTEMS.
  * COPYRIGHT (c) 2009 Cobham Gaisler AB.
+ * are met:
 #ifndef __PCI_H__
2.24.4
