[PATCH 1/1] newlib01: Test exit procs for global FILE object
Matthew Joyce
matthew.joyce at embedded-brains.de
Fri Mar 25 13:10:33 UTC 2022
From: Matt Joyce <matthew.joyce at embedded-brains.de>
testsuites/libtests/newlib01/init.c | 102 ++++++++++++++++++++++++++--
1 file changed, 96 insertions(+), 6 deletions(-)
diff --git a/testsuites/libtests/newlib01/init.c b/testsuites/libtests/newlib01/init.c
index c58154023b..c20e0a04ff 100644
--- a/testsuites/libtests/newlib01/init.c
+++ b/testsuites/libtests/newlib01/init.c
@@ -28,6 +28,8 @@ const char rtems_test_name[] = "NEWLIB 1";
static const char file_path[] = "/file";
+static const char file_path2[] = "/file2";
typedef enum {
INIT,
OPEN,
@@ -39,6 +41,8 @@ typedef struct {
rtems_id main_task_id;
rtems_id worker_task_id;
test_state current;
+ FILE *glob_file_stream;
+ int glob_fd;
} test_context;
static test_context test_instance;
@@ -59,7 +63,7 @@ static void wait(void)
rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-static void worker_task(rtems_task_argument arg)
+static void worker_task1(rtems_task_argument arg)
test_context *ctx = &test_instance;
struct _reent *reent = _REENT;
@@ -90,6 +94,41 @@ static void worker_task(rtems_task_argument arg)
rtems_test_assert(0);
+static void worker_task2(rtems_task_argument arg)
+ test_context *ctx = &test_instance;
+ struct _reent *reent = _REENT;
+ FILE *fp;
+ char buf[1] = { 'y' };
+ size_t n;
+ int fd;
+ rtems_test_assert(reent->__cleanup == NULL);
+ fp = ctx->glob_file_stream = fopen(&file_path2[0], "w");
+ rtems_test_assert(fp != NULL);
+ * Check newlib's __sinit does not touch our assigned file pointer.
+ rtems_test_assert(fflush(fp) == 0);
+ rtems_test_assert(reent->__cleanup != NULL);
+ rtems_test_assert(ctx->glob_file_stream == fp);
+ /* Get file descriptor of new global file stream, store it in text context */
+ fd = fileno(fp);
+ rtems_test_assert(fd != -1);
+ ctx->glob_fd = fd;
+ n = fwrite(&buf[0], sizeof(buf), 1, fp);
+ rtems_test_assert(n == 1);
+ wake_up_main(ctx);
+ rtems_test_assert(0);
static int handler_open(
rtems_libio_t *iop,
const char *path,
@@ -267,7 +306,7 @@ static void test_thread_specific_close(test_context *ctx)
rtems_test_assert(rv == 0);
sc = rtems_task_create(
- rtems_build_name('W', 'O', 'R', 'K'),
+ rtems_build_name('W', 'R', 'K', '1'),
2,
RTEMS_MINIMUM_STACK_SIZE,
RTEMS_DEFAULT_MODES,
@@ -276,7 +315,7 @@ static void test_thread_specific_close(test_context *ctx)
- sc = rtems_task_start(ctx->worker_task_id, worker_task, 0);
+ sc = rtems_task_start(ctx->worker_task_id, worker_task1, 0);
wait();
@@ -290,6 +329,33 @@ static void test_thread_specific_close(test_context *ctx)
rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
+static void test_global_file_object_close(test_context *ctx)
+ int rv;
+ rtems_status_code sc;
+ sc = rtems_task_create(
+ rtems_build_name('W', 'R', 'K', '2'),
+ 2,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &ctx->worker_task_id
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_task_start(ctx->worker_task_id, worker_task2, 0);
+ wait();
+ sc = rtems_task_delete(ctx->worker_task_id);
+ rv = unlink(&file_path2[0]);
+ rtems_test_assert(rv == 0);
* This exit handler will be called last among the functions registered with
* atexit(). Check that stdio file descriptors are closed. The Newlib cleanup
@@ -298,6 +364,7 @@ static void test_thread_specific_close(test_context *ctx)
static void check_after_libio_exit(void)
struct stat unused;
int rv;
@@ -319,6 +386,11 @@ static void check_after_libio_exit(void)
rtems_test_assert(stdin->_flags != 0);
rtems_test_assert(stdout->_flags != 0);
rtems_test_assert(stderr->_flags != 0);
+ /* Global file tests. Global fd still open at this point. */
+ rv = fstat(ctx->glob_fd, &unused);
+ rtems_test_assert(ctx->glob_file_stream->_flags != 0);
static void register_exit_handler_before_libio_exit(void)
@@ -342,7 +414,7 @@ RTEMS_SYSINIT_ITEM(register_exit_handler_before_libio_exit,
* cleanup procedures have been called. Therefore, stdio file descriptors
* should be open and stdio FILE object flags should be non-zero.
-static void test_exit_handling(void)
+static void test_exit_handling(test_context *ctx)
struct stat unused;
int rv;
@@ -360,6 +432,14 @@ static void test_exit_handling(void)
+ * Global file descriptor should still be open; global FILE object flags
+ * should still be non-zero.
/* Run exit handlers and Newlib cleanup procedures */
exit(0);
@@ -380,7 +460,8 @@ static void Init(rtems_task_argument arg)
test_thread_specific_close(ctx);
- test_exit_handling();
+ test_global_file_object_close(ctx);
+ test_exit_handling(ctx);
static void fatal_extension(
@@ -400,6 +481,7 @@ static void fatal_extension(
struct stat unused;
int rv;
errno = 0;
rv = fstat(0, &unused);
@@ -419,6 +501,14 @@ static void fatal_extension(
rtems_test_assert(stdin->_flags == 0);
rtems_test_assert(stdout->_flags == 0);
rtems_test_assert(stderr->_flags == 0);
+ /* Global file tests */
+ errno = 0;
+ rtems_test_assert(rv == -1);
+ rtems_test_assert(errno == EBADF);
+ rtems_test_assert(ctx->glob_file_stream->_flags == 0);
TEST_END();
@@ -426,7 +516,7 @@ static void fatal_extension(
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 4
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 5
#define CONFIGURE_MAXIMUM_TASKS 2
2.31.1
