[PATCH v2 0/9] cpukit/include License change and clean up
Fri Mar 25 16:19:31 UTC 2022
Hi
This undoes the license change to Cobham code but leaves intact the
file header clean ups.
Hopefully all OK to commit now.
--joel
Joel Sherrill (9):
  cpukit/include/dev: Change license to BSD-2
  cpukit/include/linux: Change license to BSD-2
  cpukit/include/rtems: Change license to BSD-2
  cpukit/include/sys: Change license to BSD-2.
  cpukit/include/*.h: Change license to BSD-2
  cpukit/include/pci.h: Manual header clean up
  cpukit/include/drvmgr: Manual header file clean up
  cpukit/include/pci: Manual header file clean up
  cpukit/include/rtems/confdefs/libpci.h: Manual file header clean up
 cpukit/include/aio.h                          | 25 ++++++++++++++--
 cpukit/include/dev/i2c/eeprom.h               | 25 ++++++++++++++--
 cpukit/include/dev/i2c/fpga-i2c-slave.h       | 25 ++++++++++++++--
 cpukit/include/dev/i2c/gpio-nxp-pca9535.h     | 25 ++++++++++++++--
 cpukit/include/dev/i2c/i2c.h                  | 25 ++++++++++++++--
 cpukit/include/dev/i2c/sensor-lm75a.h         | 25 ++++++++++++++--
 cpukit/include/dev/i2c/switch-nxp-pca9548a.h  | 25 ++++++++++++++--
 cpukit/include/dev/i2c/ti-ads-16bit-adc.h     | 25 ++++++++++++++--
 cpukit/include/dev/i2c/ti-lm25066a.h          | 25 ++++++++++++++--
 cpukit/include/dev/i2c/ti-tmp112.h            | 25 ++++++++++++++--
 cpukit/include/dev/i2c/xilinx-axi-i2c.h       | 25 ++++++++++++++--
 cpukit/include/dev/serial/sc16is752.h         | 25 ++++++++++++++--
 cpukit/include/dev/spi/spi.h                  | 25 ++++++++++++++--
 cpukit/include/drvmgr/drvmgr.h                |  9 +++++-
 cpukit/include/drvmgr/drvmgr_confdefs.h       |  9 +++++-
 cpukit/include/drvmgr/drvmgr_list.h           |  9 +++++-
 cpukit/include/drvmgr/pci_bus.h               | 15 +++++++---
 cpukit/include/linux/i2c-dev.h                | 25 ++++++++++++++--
 cpukit/include/linux/i2c.h                    | 25 ++++++++++++++--
 cpukit/include/linux/rbtree.h                 | 25 ++++++++++++++--
 cpukit/include/linux/spi/spidev.h             | 25 ++++++++++++++--
 cpukit/include/mqueue.h                       | 25 ++++++++++++++--
 cpukit/include/pci.h                          | 13 +++++++--
 cpukit/include/pci/access.h                   | 13 +++++++--
 cpukit/include/pci/cfg.h                      |  9 +++++-
 cpukit/include/pci/cfg_auto.h                 |  9 +++++-
 cpukit/include/pci/cfg_peripheral.h           |  9 +++++-
 cpukit/include/pci/cfg_read.h                 | 12 ++++++--
 cpukit/include/pci/cfg_static.h               |  9 +++++-
 cpukit/include/pci/irq.h                      |  9 +++++-
 cpukit/include/rtems/bdpart.h                 | 25 ++++++++++++++--
 cpukit/include/rtems/bsd.h                    | 25 ++++++++++++++--
 cpukit/include/rtems/bspcmdline.h             | 25 ++++++++++++++--
 cpukit/include/rtems/btimer.h                 | 25 ++++++++++++++--
 cpukit/include/rtems/chain.h                  | 25 ++++++++++++++--
 cpukit/include/rtems/clockdrv.h               | 25 ++++++++++++++--
 cpukit/include/rtems/concat.h                 | 25 ++++++++++++++--
 cpukit/include/rtems/confdefs/libpci.h        | 16 +++++-----
 cpukit/include/rtems/console.h                | 25 ++++++++++++++--
 cpukit/include/rtems/counter.h                | 25 ++++++++++++++--
 cpukit/include/rtems/deviceio.h               | 25 ++++++++++++++--
 cpukit/include/rtems/devnull.h                | 25 ++++++++++++++--
 cpukit/include/rtems/devzero.h                | 25 ++++++++++++++--
 cpukit/include/rtems/dosfs.h                  | 25 ++++++++++++++--
 cpukit/include/rtems/dumpbuf.h                | 29 +++++++++++++++----
 cpukit/include/rtems/extensiondata.h          | 25 ++++++++++++++--
 cpukit/include/rtems/extensionimpl.h          | 25 ++++++++++++++--
 cpukit/include/rtems/flashdisk.h              | 25 ++++++++++++++--
 cpukit/include/rtems/framebuffer.h            | 25 ++++++++++++++--
 cpukit/include/rtems/fs.h                     | 25 ++++++++++++++--
 cpukit/include/rtems/fsmount.h                | 25 ++++++++++++++--
 cpukit/include/rtems/ftpfs.h                  | 25 ++++++++++++++--
 cpukit/include/rtems/ide_part_table.h         | 25 ++++++++++++++--
 cpukit/include/rtems/inttypes.h               | 25 ++++++++++++++--
 cpukit/include/rtems/ioimpl.h                 | 25 ++++++++++++++--
 cpukit/include/rtems/iosupp.h                 | 25 ++++++++++++++--
 cpukit/include/rtems/irq.h                    | 25 ++++++++++++++--
 cpukit/include/rtems/jffs2.h                  | 25 ++++++++++++++--
 cpukit/include/rtems/libcsupport.h            | 25 ++++++++++++++--
 cpukit/include/rtems/linkersets.h             | 25 ++++++++++++++--
 cpukit/include/rtems/malloc.h                 | 29 +++++++++++++++----
 cpukit/include/rtems/media.h                  | 25 ++++++++++++++--
 cpukit/include/rtems/mptables.h               | 25 ++++++++++++++--
 cpukit/include/rtems/nvdisk.h                 | 25 ++++++++++++++--
 cpukit/include/rtems/pipe.h                   | 25 ++++++++++++++--
 cpukit/include/rtems/print.h                  | 25 ++++++++++++++--
 cpukit/include/rtems/printer.h                | 25 ++++++++++++++--
 cpukit/include/rtems/profiling.h              | 25 ++++++++++++++--
 cpukit/include/rtems/qreslib.h                | 25 ++++++++++++++--
 cpukit/include/rtems/rbheap.h                 | 25 ++++++++++++++--
 cpukit/include/rtems/rbtree.h                 | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-bitmaps.h  | 25 ++++++++++++++--
 .../include/rtems/rfs/rtems-rfs-block-pos.h   | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-block.h    | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-buffer.h   | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-data.h     | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-dir-hash.h | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-dir.h      | 25 ++++++++++++++--
 .../rtems/rfs/rtems-rfs-file-system-fwd.h     | 25 ++++++++++++++--
 .../include/rtems/rfs/rtems-rfs-file-system.h | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-file.h     | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-group.h    | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-inode.h    | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-link.h     | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-mutex.h    | 25 ++++++++++++++--
 cpukit/include/rtems/rfs/rtems-rfs-trace.h    | 25 ++++++++++++++--
 cpukit/include/rtems/rtc.h                    | 25 ++++++++++++++--
 cpukit/include/rtems/rtems-fdt-shell.h        | 25 ++++++++++++++--
 cpukit/include/rtems/rtems-fdt.h              | 25 ++++++++++++++--
 cpukit/include/rtems/rtems-rfs-format.h       | 25 ++++++++++++++--
 cpukit/include/rtems/rtems-rfs-shell.h        | 25 ++++++++++++++--
 cpukit/include/rtems/rtems-rfs.h              | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/dlfcn-shell.h        | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rap-shell.h          | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rap.h                | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-allocator.h      | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-archive.h        | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-fwd.h            | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-indirect-ptr.h   | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-obj-cache.h      | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-obj-comp.h       | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-obj-fwd.h        | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-obj.h            | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-shell.h          | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-sym.h            | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-trace.h          | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl-unresolved.h     | 25 ++++++++++++++--
 cpukit/include/rtems/rtl/rtl.h                | 25 ++++++++++++++--
 cpukit/include/rtems/scheduler.h              | 25 ++++++++++++++--
 cpukit/include/rtems/serdbg.h                 | 25 ++++++++++++++--
 cpukit/include/rtems/serdbgcnf.h              | 25 ++++++++++++++--
 cpukit/include/rtems/serial_mouse.h           | 25 ++++++++++++++--
 cpukit/include/rtems/seterr.h                 | 25 ++++++++++++++--
 cpukit/include/rtems/shellconfig.h            | 25 ++++++++++++++--
 cpukit/include/rtems/sparse-disk.h            | 25 ++++++++++++++--
 cpukit/include/rtems/spurious.h               | 25 ++++++++++++++--
 cpukit/include/rtems/stackchk.h               | 25 ++++++++++++++--
 cpukit/include/rtems/status-checks.h          | 25 ++++++++++++++--
 cpukit/include/rtems/stringto.h               | 25 ++++++++++++++--
 cpukit/include/rtems/sysinit.h                | 25 ++++++++++++++--
 cpukit/include/rtems/termios_printk.h         | 25 ++++++++++++++--
 cpukit/include/rtems/termios_printk_cnf.h     | 25 ++++++++++++++--
 cpukit/include/rtems/termiostypes.h           | 25 ++++++++++++++--
 cpukit/include/rtems/test-info.h              | 25 ++++++++++++++--
 cpukit/include/rtems/thread.h                 | 25 ++++++++++++++--
 cpukit/include/rtems/timecounter.h            | 25 ++++++++++++++--
 cpukit/include/rtems/tm27-default.h           | 25 ++++++++++++++--
 .../rtems/trace/rtems-trace-buffer-vars.h     | 25 ++++++++++++++--
 cpukit/include/rtems/untar.h                  | 25 ++++++++++++++--
 cpukit/include/rtems/userenv.h                | 25 ++++++++++++++--
 cpukit/include/rtems/version.h                | 25 ++++++++++++++--
 cpukit/include/rtems/vmeintr.h                | 25 ++++++++++++++--
 cpukit/include/rtems/watchdogdrv.h            | 25 ++++++++++++++--
 cpukit/include/sys/statvfs.h                  | 25 ++++++++++++++--
 cpukit/include/sys/utsname.h                  | 25 ++++++++++++++--
 135 files changed, 2803 insertions(+), 396 deletions(-)
2.24.4
