[PATCH v3 1/1] newlib01: Added tests for exit procedures
Matthew Joyce
matthew.joyce at embedded-brains.de
Tue Mar 29 13:18:51 UTC 2022
From: Matt Joyce <matthew.joyce at embedded-brains.de>
Added tests for exit procedures to ensure proper resource
cleanup. The test now checks cleanup for files assigned
to stdio streams and non-stdio streams.
testsuites/libtests/newlib01/init.c | 120 +++++++++++++++++-----
testsuites/libtests/newlib01/newlib01.doc | 5 +-
2 files changed, 101 insertions(+), 24 deletions(-)
diff --git a/testsuites/libtests/newlib01/init.c b/testsuites/libtests/newlib01/init.c
index c58154023b..40d2f683b0 100644
--- a/testsuites/libtests/newlib01/init.c
+++ b/testsuites/libtests/newlib01/init.c
@@ -28,6 +28,8 @@ const char rtems_test_name[] = "NEWLIB 1";
static const char file_path[] = "/file";
+static const char file_path2[] = "/file2";
typedef enum {
INIT,
OPEN,
@@ -39,6 +41,8 @@ typedef struct {
rtems_id main_task_id;
rtems_id worker_task_id;
test_state current;
+ FILE *glob_file_stream;
+ int glob_fd;
} test_context;
static test_context test_instance;
@@ -59,7 +63,7 @@ static void wait(void)
rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-static void worker_task(rtems_task_argument arg)
+static void stdio_file_worker(rtems_task_argument arg)
test_context *ctx = &test_instance;
struct _reent *reent = _REENT;
@@ -90,6 +94,30 @@ static void worker_task(rtems_task_argument arg)
rtems_test_assert(0);
+static void non_stdio_file_worker(rtems_task_argument arg)
+ test_context *ctx = &test_instance;
+ FILE *fp;
+ char buf[1] = { 'y' };
+ size_t n;
+ int fd;
+ fp = ctx->glob_file_stream = fopen(&file_path2[0], "w");
+ rtems_test_assert(fp != NULL);
+ /* Get file descriptor of new global file stream, store it in text context */
+ fd = fileno(fp);
+ rtems_test_assert(fd != -1);
+ ctx->glob_fd = fd;
+ n = fwrite(&buf[0], sizeof(buf), 1, fp);
+ rtems_test_assert(n == 1);
+ wake_up_main(ctx);
+ rtems_test_assert(0);
static int handler_open(
rtems_libio_t *iop,
const char *path,
@@ -250,9 +278,38 @@ static const IMFS_node_control node_control = IMFS_GENERIC_INITIALIZER(
IMFS_node_destroy_default
-static void test_thread_specific_close(test_context *ctx)
+static void task_create_and_delete_helper(
+ test_context *ctx,
+ rtems_task_entry entry
rtems_status_code sc;
+ sc = rtems_task_create(
+ rtems_build_name('W', 'O', 'R', 'K'),
+ 2,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &ctx->worker_task_id
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_task_start(ctx->worker_task_id, entry, 0);
+ wait();
+ sc = rtems_task_delete(ctx->worker_task_id);
+ * Check that a FILE opened by a task and assigned to a stdio stream is closed
+ * during thread termination. Ensure that resources are returned to the system.
+static void test_stdio_file(test_context *ctx)
int rv;
rtems_resource_snapshot snapshot;
@@ -266,23 +323,7 @@ static void test_thread_specific_close(test_context *ctx)
rtems_test_assert(rv == 0);
- sc = rtems_task_create(
- rtems_build_name('W', 'O', 'R', 'K'),
- 2,
- RTEMS_MINIMUM_STACK_SIZE,
- RTEMS_DEFAULT_MODES,
- RTEMS_DEFAULT_ATTRIBUTES,
- &ctx->worker_task_id
- rtems_test_assert(sc == RTEMS_SUCCESSFUL);
- sc = rtems_task_start(ctx->worker_task_id, worker_task, 0);
- wait();
- sc = rtems_task_delete(ctx->worker_task_id);
+ task_create_and_delete_helper(ctx, stdio_file_worker);
rv = unlink(&file_path[0]);
@@ -290,6 +331,15 @@ static void test_thread_specific_close(test_context *ctx)
rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
+ * Open a global FILE object from a task but do not assign it to a stdio
+ * stream. The FILE is not closed upon thread termination.
+static void test_non_stdio_file(test_context *ctx)
+ task_create_and_delete_helper(ctx, non_stdio_file_worker);
* This exit handler will be called last among the functions registered with
* atexit(). Check that stdio file descriptors are closed. The Newlib cleanup
@@ -298,6 +348,7 @@ static void test_thread_specific_close(test_context *ctx)
static void check_after_libio_exit(void)
struct stat unused;
int rv;
@@ -319,6 +370,11 @@ static void check_after_libio_exit(void)
rtems_test_assert(stdin->_flags != 0);
rtems_test_assert(stdout->_flags != 0);
rtems_test_assert(stderr->_flags != 0);
+ /* Global file tests. Global fd still open at this point. */
+ rv = fstat(ctx->glob_fd, &unused);
+ rtems_test_assert(rv == 0);
+ rtems_test_assert(ctx->glob_file_stream->_flags != 0);
static void register_exit_handler_before_libio_exit(void)
@@ -342,7 +398,7 @@ RTEMS_SYSINIT_ITEM(register_exit_handler_before_libio_exit,
* cleanup procedures have been called. Therefore, stdio file descriptors
* should be open and stdio FILE object flags should be non-zero.
-static void test_exit_handling(void)
+static void test_exit_handling(test_context *ctx)
struct stat unused;
int rv;
@@ -360,6 +416,14 @@ static void test_exit_handling(void)
+ * Global file descriptor should still be open; global FILE object flags
+ * should still be non-zero.
/* Run exit handlers and Newlib cleanup procedures */
exit(0);
@@ -379,8 +443,9 @@ static void Init(rtems_task_argument arg)
rv = fclose(file);
- test_thread_specific_close(ctx);
- test_exit_handling();
+ test_stdio_file(ctx);
+ test_non_stdio_file(ctx);
+ test_exit_handling(ctx);
static void fatal_extension(
@@ -400,6 +465,7 @@ static void fatal_extension(
struct stat unused;
int rv;
errno = 0;
rv = fstat(0, &unused);
@@ -419,6 +485,14 @@ static void fatal_extension(
rtems_test_assert(stdin->_flags == 0);
rtems_test_assert(stdout->_flags == 0);
rtems_test_assert(stderr->_flags == 0);
+ /* Global file tests */
+ errno = 0;
+ rtems_test_assert(rv == -1);
+ rtems_test_assert(errno == EBADF);
+ rtems_test_assert(ctx->glob_file_stream->_flags == 0);
TEST_END();
@@ -426,7 +500,7 @@ static void fatal_extension(
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 4
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 5
#define CONFIGURE_MAXIMUM_TASKS 2
diff --git a/testsuites/libtests/newlib01/newlib01.doc b/testsuites/libtests/newlib01/newlib01.doc
index 2bf5959506..fbda12aa98 100644
--- a/testsuites/libtests/newlib01/newlib01.doc
+++ b/testsuites/libtests/newlib01/newlib01.doc
@@ -14,5 +14,8 @@ concepts:
written to the open file during thread termination.
- Ensure that the open file is closed after the write during thread
termination.
- - Ensure that all resources are returned to the system using resouce
+ - Ensure that all resources are returned to the system using resource
snapshots.
+ - Check that exit procedures provide proper resource cleanup. Ensure that
+ a file opened from a worker task--but that is not assigned to a stdio
+ stream--is not closed during thread termination.
2.31.1
