[PATCH 1/2] validation: Use individual names for ident tests
Sebastian Huber
Tue Mar 29 15:21:12 UTC 2022
Make the task configuration reusable.
Update #3716.
.../testsuites/validation/libvalidation.yml | 1 +
testsuites/validation/tc-barrier-ident.c | 5 +-
testsuites/validation/tc-message-ident.c | 5 +-
testsuites/validation/tc-part-ident.c | 5 +-
testsuites/validation/tc-ratemon-ident.c | 5 +-
testsuites/validation/tc-sem-ident.c | 5 +-
testsuites/validation/tc-task-ident.c | 27 +-------
testsuites/validation/tc-timer-ident.c | 5 +-
testsuites/validation/tc-userext-ident.c | 5 +-
testsuites/validation/tr-object-ident-local.c | 10 ++-
testsuites/validation/tr-object-ident-local.h | 9 +--
testsuites/validation/tr-object-ident.c | 10 ++-
testsuites/validation/tr-object-ident.h | 9 +--
.../validation/tx-default-task-config.c | 61 +++++++++++++++++++
testsuites/validation/tx-support.h | 9 +++
15 files changed, 130 insertions(+), 41 deletions(-)
create mode 100644 testsuites/validation/tx-default-task-config.c
diff --git a/spec/build/testsuites/validation/libvalidation.yml b/spec/build/testsuites/validation/libvalidation.yml
index 37603f143e..1ea1976e7a 100644
--- a/spec/build/testsuites/validation/libvalidation.yml
+++ b/spec/build/testsuites/validation/libvalidation.yml
@@ -12,6 +12,7 @@ install-path: null
links: []
source:
- testsuites/validation/tx-call-within-isr.c
+- testsuites/validation/tx-default-task-config.c
- testsuites/validation/tx-interrupt.c
- testsuites/validation/tx-io-relax.c
- testsuites/validation/tx-memory-alloc.c
diff --git a/testsuites/validation/tc-barrier-ident.c b/testsuites/validation/tc-barrier-ident.c
index 71e7051f66..dcb4a1c273 100644
--- a/testsuites/validation/tc-barrier-ident.c
+++ b/testsuites/validation/tc-barrier-ident.c
@@ -71,6 +71,8 @@
+#define NAME_LOCAL_OBJECT rtems_build_name( 'B', 'A', 'R', 'R' )
static rtems_status_code ClassicBarrierIdentAction(
rtems_name name,
rtems_id *id
@@ -89,7 +91,7 @@ static void RtemsBarrierValIdent_Action_0( void )
rtems_id id_local_object;
sc = rtems_barrier_create(
- ClassicObjectLocalIdentName,
+ NAME_LOCAL_OBJECT,
RTEMS_DEFAULT_ATTRIBUTES,
1,
&id_local_object
@@ -98,6 +100,7 @@ static void RtemsBarrierValIdent_Action_0( void )
RtemsReqIdentLocal_Run(
id_local_object,
diff --git a/testsuites/validation/tc-message-ident.c b/testsuites/validation/tc-message-ident.c
index 74759b525e..70e7d53350 100644
--- a/testsuites/validation/tc-message-ident.c
+++ b/testsuites/validation/tc-message-ident.c
@@ -71,10 +71,12 @@
+#define NAME_LOCAL_OBJECT rtems_build_name( 'M', 'E', 'S', 'Q' )
static RTEMS_MESSAGE_QUEUE_BUFFER( 1 ) ClassicMessageIdentBuffers[ 1 ];
static rtems_message_queue_config ClassicObjectIdentConfig = {
- .name = ClassicObjectIdentName,
+ .name = NAME_LOCAL_OBJECT,
.maximum_pending_messages = RTEMS_ARRAY_SIZE( ClassicMessageIdentBuffers ),
.maximum_message_size = 1,
.storage_area = ClassicMessageIdentBuffers,
@@ -108,6 +110,7 @@ static void RtemsMessageValIdent_Action_0( void )
RtemsReqIdent_Run(
id_local_object,
ClassicMessageIdentAction
diff --git a/testsuites/validation/tc-part-ident.c b/testsuites/validation/tc-part-ident.c
index 926c205970..fccdf9671c 100644
--- a/testsuites/validation/tc-part-ident.c
+++ b/testsuites/validation/tc-part-ident.c
@@ -71,6 +71,8 @@
+#define NAME_LOCAL_OBJECT rtems_build_name( 'P', 'A', 'R', 'T' )
static rtems_status_code ClassicPartIdentAction(
rtems_name name,
uint32_t node,
@@ -91,7 +93,7 @@ static void RtemsPartValIdent_Action_0( void )
sc = rtems_partition_create(
- ClassicObjectIdentName,
area,
sizeof( area ),
sizeof( area ),
@@ -102,6 +104,7 @@ static void RtemsPartValIdent_Action_0( void )
RtemsReqIdent_Run(
id_local_object,
diff --git a/testsuites/validation/tc-ratemon-ident.c b/testsuites/validation/tc-ratemon-ident.c
index 1126fcacab..beeb0bfd14 100644
--- a/testsuites/validation/tc-ratemon-ident.c
+++ b/testsuites/validation/tc-ratemon-ident.c
@@ -71,6 +71,8 @@
+#define NAME_LOCAL_OBJECT rtems_build_name( 'R', 'A', 'T', 'E' )
static rtems_status_code ClassicRatemonIdentAction(
rtems_name name,
rtems_id *id
@@ -89,13 +91,14 @@ static void RtemsRatemonValIdent_Action_0( void )
sc = rtems_rate_monotonic_create(
&id_local_object
T_assert_rsc_success( sc );
id_local_object,
diff --git a/testsuites/validation/tc-sem-ident.c b/testsuites/validation/tc-sem-ident.c
index 183680fee0..3014113189 100644
--- a/testsuites/validation/tc-sem-ident.c
+++ b/testsuites/validation/tc-sem-ident.c
@@ -71,6 +71,8 @@
+#define NAME_LOCAL_OBJECT rtems_build_name( 'S', 'E', 'M', 'A' )
static rtems_status_code ClassicSemIdentAction(
rtems_name name,
uint32_t node,
@@ -90,7 +92,7 @@ static void RtemsSemValIdent_Action_0( void )
sc = rtems_semaphore_create(
0,
0,
@@ -100,6 +102,7 @@ static void RtemsSemValIdent_Action_0( void )
RtemsReqIdent_Run(
id_local_object,
diff --git a/testsuites/validation/tc-task-ident.c b/testsuites/validation/tc-task-ident.c
index a61b90330a..c4247f22cf 100644
--- a/testsuites/validation/tc-task-ident.c
+++ b/testsuites/validation/tc-task-ident.c
@@ -53,7 +53,7 @@
#endif
#include "tr-object-ident.h"
-#include "ts-config.h"
+#include "tx-support.h"
#include <rtems/test.h>
@@ -147,28 +147,6 @@ static rtems_status_code ClassicTaskIdentAction(
return rtems_task_ident( name, node, id );
-#define TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
-#define MAX_TLS_SIZE RTEMS_ALIGN_UP( 64, RTEMS_TASK_STORAGE_ALIGNMENT )
-RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT )
-static char ClassicTaskIdentStorage[
- RTEMS_TASK_STORAGE_SIZE(
- MAX_TLS_SIZE + TEST_MINIMUM_STACK_SIZE,
- TASK_ATTRIBUTES
-static const rtems_task_config ClassicTaskIdentConfig = {
- .initial_priority = 1,
- .storage_area = ClassicTaskIdentStorage,
- .storage_size = sizeof( ClassicTaskIdentStorage ),
- .maximum_thread_local_storage_size = MAX_TLS_SIZE,
- .initial_modes = RTEMS_DEFAULT_MODES,
- .attributes = TASK_ATTRIBUTES
static void RtemsTaskReqIdent_Pre_Name_Prepare(
RtemsTaskReqIdent_Context *ctx,
RtemsTaskReqIdent_Pre_Name state
@@ -237,7 +215,7 @@ static void RtemsTaskReqIdent_Setup( RtemsTaskReqIdent_Context *ctx )
rtems_status_code sc;
sc = rtems_task_construct(
- &ClassicTaskIdentConfig,
+ &DefaultTaskConfig,
&ctx->id_local_object
@@ -278,6 +256,7 @@ static void RtemsTaskReqIdent_Action( RtemsTaskReqIdent_Context *ctx )
} else {
RtemsReqIdent_Run(
ctx->id_local_object,
+ DefaultTaskConfig.name,
diff --git a/testsuites/validation/tc-timer-ident.c b/testsuites/validation/tc-timer-ident.c
index 5f121fc55b..bdee3d89d2 100644
--- a/testsuites/validation/tc-timer-ident.c
+++ b/testsuites/validation/tc-timer-ident.c
@@ -71,6 +71,8 @@
+#define NAME_LOCAL_OBJECT rtems_build_name( 'T', 'I', 'M', 'R' )
static rtems_status_code ClassicTimerIdentAction(
rtems_name name,
rtems_id *id
@@ -89,13 +91,14 @@ static void RtemsTimerValIdent_Action_0( void )
sc = rtems_timer_create(
&id_local_object
id_local_object,
diff --git a/testsuites/validation/tc-userext-ident.c b/testsuites/validation/tc-userext-ident.c
index d2adcb313e..2ece528953 100644
--- a/testsuites/validation/tc-userext-ident.c
+++ b/testsuites/validation/tc-userext-ident.c
@@ -71,6 +71,8 @@
+#define NAME_LOCAL_OBJECT rtems_build_name( 'U', 'E', 'X', 'T' )
static rtems_status_code ClassicUserExtIdentAction(
rtems_name name,
rtems_id *id
@@ -90,7 +92,7 @@ static void RtemsUserextValIdent_Action_0( void )
sc = rtems_extension_create(
&table,
&id_local_object
@@ -98,6 +100,7 @@ static void RtemsUserextValIdent_Action_0( void )
id_local_object,
diff --git a/testsuites/validation/tr-object-ident-local.c b/testsuites/validation/tr-object-ident-local.c
index 5ca8c08fab..1b3943fdb1 100644
--- a/testsuites/validation/tr-object-ident-local.c
+++ b/testsuites/validation/tr-object-ident-local.c
@@ -90,6 +90,12 @@ typedef struct {
+ * @brief This member contains a copy of the corresponding
+ * RtemsReqIdentLocal_Run() parameter.
+ rtems_name name_local_object;
@@ -166,7 +172,7 @@ static void RtemsReqIdentLocal_Pre_Name_Prepare(
* While the ``name`` parameter is associated with an active object of
* the specified class .
- ctx->name = ClassicObjectLocalIdentName;
+ ctx->name = ctx->name_local_object;
break;
@@ -346,6 +352,7 @@ static T_fixture_node RtemsReqIdentLocal_Node;
void RtemsReqIdentLocal_Run(
rtems_id id_local_object,
+ rtems_name name_local_object,
rtems_status_code ( *action )( rtems_name, rtems_id * )
@@ -353,6 +360,7 @@ void RtemsReqIdentLocal_Run(
ctx = &RtemsReqIdentLocal_Instance;
ctx->id_local_object = id_local_object;
+ ctx->name_local_object = name_local_object;
ctx->action = action;
ctx = T_push_fixture( &RtemsReqIdentLocal_Node, &RtemsReqIdentLocal_Fixture );
diff --git a/testsuites/validation/tr-object-ident-local.h b/testsuites/validation/tr-object-ident-local.h
index 13f6a09997..83ad7e7416 100644
--- a/testsuites/validation/tr-object-ident-local.h
+++ b/testsuites/validation/tr-object-ident-local.h
@@ -89,19 +89,20 @@ typedef enum {
RtemsReqIdentLocal_Post_Id_NA
} RtemsReqIdentLocal_Post_Id;
-#define ClassicObjectLocalIdentName \
- rtems_build_name( 'I', 'D', 'N', 'T' )
* @brief Runs the parameterized test case.
* @param id_local_object is the identifier of an active object of the class
- * under test with the name ClassicObjectLocalIdentName.
+ * under test.
+ * @param name_local_object is the name of the active object of the class under
+ * test.
* @param action is the action handler.
diff --git a/testsuites/validation/tr-object-ident.c b/testsuites/validation/tr-object-ident.c
index fac8767175..438c1f3333 100644
--- a/testsuites/validation/tr-object-ident.c
+++ b/testsuites/validation/tr-object-ident.c
@@ -95,6 +95,12 @@ typedef struct {
+ * RtemsReqIdent_Run() parameter.
@@ -182,7 +188,7 @@ static void RtemsReqIdent_Pre_Name_Prepare(
- ctx->name = ClassicObjectIdentName;
break;
@@ -450,6 +456,7 @@ static T_fixture_node RtemsReqIdent_Node;
void RtemsReqIdent_Run(
rtems_status_code ( *action )( rtems_name, uint32_t, rtems_id * )
@@ -457,6 +464,7 @@ void RtemsReqIdent_Run(
ctx = &RtemsReqIdent_Instance;
ctx = T_push_fixture( &RtemsReqIdent_Node, &RtemsReqIdent_Fixture );
diff --git a/testsuites/validation/tr-object-ident.h b/testsuites/validation/tr-object-ident.h
index 2404665272..7917562eab 100644
--- a/testsuites/validation/tr-object-ident.h
+++ b/testsuites/validation/tr-object-ident.h
@@ -101,19 +101,20 @@ typedef enum {
RtemsReqIdent_Post_Id_NA
} RtemsReqIdent_Post_Id;
-#define ClassicObjectIdentName \
- * under test with the name ClassicObjectIdentName.
+ * under test.
+ * test.
diff --git a/testsuites/validation/tx-default-task-config.c b/testsuites/validation/tx-default-task-config.c
new file mode 100644
index 0000000000..59a0fd0ed3
--- /dev/null
+++ b/testsuites/validation/tx-default-task-config.c
@@ -0,0 +1,61 @@
+ * @file
+ * @ingroup RTEMSTestSuites
+ * @brief This source file contains the definition of ::DefaultTaskConfig.
+ * Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "ts-config.h"
+#define TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
+RTEMS_ALIGNED( RTEMS_TASK_STORAGE_ALIGNMENT )
+static char DefaultTaskStorage[
+ RTEMS_TASK_STORAGE_SIZE(
+ TEST_MAXIMUM_TLS_SIZE + TEST_MINIMUM_STACK_SIZE,
+ TASK_ATTRIBUTES
+const rtems_task_config DefaultTaskConfig = {
+ .name = rtems_build_name( 'D', 'T', 'S', 'K' ),
+ .initial_priority = 1,
+ .storage_area = DefaultTaskStorage,
+ .storage_size = sizeof( DefaultTaskStorage ),
+ .maximum_thread_local_storage_size = TEST_MAXIMUM_TLS_SIZE,
+ .initial_modes = RTEMS_DEFAULT_MODES,
+ .attributes = TASK_ATTRIBUTES
diff --git a/testsuites/validation/tx-support.h b/testsuites/validation/tx-support.h
index b647551b4e..592067ca26 100644
--- a/testsuites/validation/tx-support.h
+++ b/testsuites/validation/tx-support.h
@@ -590,6 +590,15 @@ static inline void ISRLockWaitForOthers(
void *IdleBody( uintptr_t ignored );
+ * @brief This task configurations may be used to construct a task during
+ * tests.
+ * Only one task shall use this configuration at a time, otherwise two tasks
+ * would share a stack.
+extern const rtems_task_config DefaultTaskConfig;
#ifdef __cplusplus
2.34.1
