[PATCH 04/11] testsuites/sptests/sp[4-7]*: Change license to BSD-2
Thu Mar 31 22:24:37 UTC 2022
Updates #3053.
 testsuites/sptests/sp40/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp41/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp42/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp43/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp43/system.h   | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp45/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp46/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp48/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp49/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp50/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp51/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp54/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp55/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp56/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp57/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp58/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp59/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp60/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp62/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp63/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp64/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp65/sp65impl.h | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp68/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp69/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp70/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp71/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp72/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp73/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp74/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp75/init.c     | 25 ++++++++++++++++++++++---
 testsuites/sptests/sp76/init.c     | 25 ++++++++++++++++++++++---
 31 files changed, 682 insertions(+), 93 deletions(-)
diff --git a/testsuites/sptests/sp40/init.c b/testsuites/sptests/sp40/init.c
index ff63f66e7f..ae7aba0a63 100644
--- a/testsuites/sptests/sp40/init.c
+++ b/testsuites/sptests/sp40/init.c
@@ -1,3 +1,5 @@
  *  IO Manager Dynamic Registration
@@ -6,9 +8,26 @@
  *  Copyright (c) 2009 embedded brains GmbH.
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/testsuites/sptests/sp41/init.c b/testsuites/sptests/sp41/init.c
index 02fb5254d7..b3cb74b88e 100644
--- a/testsuites/sptests/sp41/init.c
+++ b/testsuites/sptests/sp41/init.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2012.
  *  On-Line Applications Research Corporation (OAR).
+ * are met:
diff --git a/testsuites/sptests/sp42/init.c b/testsuites/sptests/sp42/init.c
index 0004694741..24d5a68d81 100644
--- a/testsuites/sptests/sp42/init.c
+++ b/testsuites/sptests/sp42/init.c
@@ -1,12 +1,31 @@
  *  Exercise thread queue enqueue and dequeue priority
  *  COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/testsuites/sptests/sp43/init.c b/testsuites/sptests/sp43/init.c
index 09c60cdb0d..c396f680bd 100644
--- a/testsuites/sptests/sp43/init.c
+++ b/testsuites/sptests/sp43/init.c
@@ -1,12 +1,31 @@
  *  Exercise Object Manager Services
  *  COPYRIGHT (c) 1989-2011.
+ * are met:
diff --git a/testsuites/sptests/sp43/system.h b/testsuites/sptests/sp43/system.h
index 333ad972ab..96b122f8ab 100644
--- a/testsuites/sptests/sp43/system.h
+++ b/testsuites/sptests/sp43/system.h
@@ -1,3 +1,5 @@
 /*  system.h
  *  This include file contains information that is included in every
@@ -6,9 +8,26 @@
  *  COPYRIGHT (c) 1989-2008.
+ * are met:
 #include <tmacros.h>
diff --git a/testsuites/sptests/sp45/init.c b/testsuites/sptests/sp45/init.c
index da9e740208..323100ebd5 100644
--- a/testsuites/sptests/sp45/init.c
+++ b/testsuites/sptests/sp45/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp46/init.c b/testsuites/sptests/sp46/init.c
index 3fa907a647..8604dbbed6 100644
--- a/testsuites/sptests/sp46/init.c
+++ b/testsuites/sptests/sp46/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp48/init.c b/testsuites/sptests/sp48/init.c
index 3af65f5f12..397b3295cb 100644
--- a/testsuites/sptests/sp48/init.c
+++ b/testsuites/sptests/sp48/init.c
@@ -1,12 +1,31 @@
  *  Verify creation of semaphores with unlimited attribute works.
+ * are met:
diff --git a/testsuites/sptests/sp49/init.c b/testsuites/sptests/sp49/init.c
index d1f6f05216..b48903123c 100644
--- a/testsuites/sptests/sp49/init.c
+++ b/testsuites/sptests/sp49/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp50/init.c b/testsuites/sptests/sp50/init.c
index 6852c4a28c..55e777cc63 100644
--- a/testsuites/sptests/sp50/init.c
+++ b/testsuites/sptests/sp50/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp51/init.c b/testsuites/sptests/sp51/init.c
index ff6b56205b..bb83fd0074 100644
--- a/testsuites/sptests/sp51/init.c
+++ b/testsuites/sptests/sp51/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp54/init.c b/testsuites/sptests/sp54/init.c
index 71437fac8e..712a4ae8db 100644
--- a/testsuites/sptests/sp54/init.c
+++ b/testsuites/sptests/sp54/init.c
@@ -1,3 +1,5 @@
  *  @@file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp55/init.c b/testsuites/sptests/sp55/init.c
index b89aecdad6..58221f2e2c 100644
--- a/testsuites/sptests/sp55/init.c
+++ b/testsuites/sptests/sp55/init.c
@@ -1,3 +1,5 @@
  *  @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp56/init.c b/testsuites/sptests/sp56/init.c
index 5e0fde79ee..7dcab1b01f 100644
--- a/testsuites/sptests/sp56/init.c
+++ b/testsuites/sptests/sp56/init.c
@@ -1,3 +1,5 @@
  *  @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp57/init.c b/testsuites/sptests/sp57/init.c
index 8d1573aede..3c1d4ad73a 100644
--- a/testsuites/sptests/sp57/init.c
+++ b/testsuites/sptests/sp57/init.c
@@ -1,3 +1,5 @@
  *  @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp58/init.c b/testsuites/sptests/sp58/init.c
index f15a9229c4..5d5428777b 100644
--- a/testsuites/sptests/sp58/init.c
+++ b/testsuites/sptests/sp58/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp59/init.c b/testsuites/sptests/sp59/init.c
index a38e59775f..c87b4a5470 100644
--- a/testsuites/sptests/sp59/init.c
+++ b/testsuites/sptests/sp59/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp60/init.c b/testsuites/sptests/sp60/init.c
index 887747fd54..727a3eefb6 100644
--- a/testsuites/sptests/sp60/init.c
+++ b/testsuites/sptests/sp60/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp62/init.c b/testsuites/sptests/sp62/init.c
index 3bb40447bb..47a39dc812 100644
--- a/testsuites/sptests/sp62/init.c
+++ b/testsuites/sptests/sp62/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp63/init.c b/testsuites/sptests/sp63/init.c
index c63917ac1c..b564a9ddb2 100644
--- a/testsuites/sptests/sp63/init.c
+++ b/testsuites/sptests/sp63/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp64/init.c b/testsuites/sptests/sp64/init.c
index 0e1cdd131f..74d2888304 100644
--- a/testsuites/sptests/sp64/init.c
+++ b/testsuites/sptests/sp64/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp65/sp65impl.h b/testsuites/sptests/sp65/sp65impl.h
index c5644b38b9..03e1ba561f 100644
--- a/testsuites/sptests/sp65/sp65impl.h
+++ b/testsuites/sptests/sp65/sp65impl.h
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp68/init.c b/testsuites/sptests/sp68/init.c
index e21dfbb961..5443dfbb5e 100644
--- a/testsuites/sptests/sp68/init.c
+++ b/testsuites/sptests/sp68/init.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2009-2015 embedded brains GmbH.
+ * are met:
diff --git a/testsuites/sptests/sp69/init.c b/testsuites/sptests/sp69/init.c
index e78d922481..558432bae7 100644
--- a/testsuites/sptests/sp69/init.c
+++ b/testsuites/sptests/sp69/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp70/init.c b/testsuites/sptests/sp70/init.c
index becd7fb511..b3b0def1de 100644
--- a/testsuites/sptests/sp70/init.c
+++ b/testsuites/sptests/sp70/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp71/init.c b/testsuites/sptests/sp71/init.c
index cc85f8fdc6..8d2b7dbf83 100644
--- a/testsuites/sptests/sp71/init.c
+++ b/testsuites/sptests/sp71/init.c
@@ -1,10 +1,29 @@
+ * are met:
 #if !defined(PER_ALLOCATION)
diff --git a/testsuites/sptests/sp72/init.c b/testsuites/sptests/sp72/init.c
index 188498f923..49d649a45c 100644
--- a/testsuites/sptests/sp72/init.c
+++ b/testsuites/sptests/sp72/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp73/init.c b/testsuites/sptests/sp73/init.c
index 243fd2c54a..e5c6c5060d 100644
--- a/testsuites/sptests/sp73/init.c
+++ b/testsuites/sptests/sp73/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp74/init.c b/testsuites/sptests/sp74/init.c
index 2dd00861c7..3b983df0e6 100644
--- a/testsuites/sptests/sp74/init.c
+++ b/testsuites/sptests/sp74/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp75/init.c b/testsuites/sptests/sp75/init.c
index dafa775339..0692a1f486 100644
--- a/testsuites/sptests/sp75/init.c
+++ b/testsuites/sptests/sp75/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp76/init.c b/testsuites/sptests/sp76/init.c
index 6315850b51..63d18cacb9 100644
--- a/testsuites/sptests/sp76/init.c
+++ b/testsuites/sptests/sp76/init.c
@@ -1,10 +1,29 @@
+ * are met:
2.24.4
