[PATCH 03/11] testsuites/sptests/sp[2-3]*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Thu Mar 31 22:24:36 UTC 2022
Updates #3053.
testsuites/sptests/sp20/getall.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp20/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp20/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp20/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp2038/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp21/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp22/delay.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp22/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp22/prtime.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp22/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp22/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp23/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp23/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp23/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp24/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp24/resume.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp24/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp24/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp25/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp25/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp25/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp26/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp26/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp26/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp27/sp27impl.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp30/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp30/resume.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp30/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp30/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp31/delay.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp31/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp31/prtime.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp31/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp31/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp32/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp33/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp37/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp37/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp38/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp38/system.h | 25 ++++++++++++++++++++++---
40 files changed, 880 insertions(+), 120 deletions(-)
diff --git a/testsuites/sptests/sp20/getall.c b/testsuites/sptests/sp20/getall.c
index 60392a831a..b4b63597fb 100644
--- a/testsuites/sptests/sp20/getall.c
+++ b/testsuites/sptests/sp20/getall.c
@@ -1,3 +1,5 @@
/* Get_all_counters
* This routine allows TA5 to atomically obtain the iteration counters.
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/testsuites/sptests/sp20/init.c b/testsuites/sptests/sp20/init.c
index 24920c15de..9d62beadd7 100644
--- a/testsuites/sptests/sp20/init.c
+++ b/testsuites/sptests/sp20/init.c
@@ -1,3 +1,5 @@
/* Init
* This routine is the initialization task for this test program.
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp20/system.h b/testsuites/sptests/sp20/system.h
index 4585639fe3..f0e339def4 100644
--- a/testsuites/sptests/sp20/system.h
+++ b/testsuites/sptests/sp20/system.h
@@ -1,3 +1,5 @@
/* system.h
* This include file contains information that is included in every
@@ -6,9 +8,26 @@
+ * are met:
#include <tmacros.h>
diff --git a/testsuites/sptests/sp20/task1.c b/testsuites/sptests/sp20/task1.c
index 497b4f09ff..c8072a0181 100644
--- a/testsuites/sptests/sp20/task1.c
+++ b/testsuites/sptests/sp20/task1.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
diff --git a/testsuites/sptests/sp2038/init.c b/testsuites/sptests/sp2038/init.c
index 757a0a8602..c280e79b7c 100644
--- a/testsuites/sptests/sp2038/init.c
+++ b/testsuites/sptests/sp2038/init.c
@@ -1,9 +1,28 @@
* Copyright (c) 2011, 2016 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/testsuites/sptests/sp21/init.c b/testsuites/sptests/sp21/init.c
index bd0ae2b6a1..2dc46dc692 100644
--- a/testsuites/sptests/sp21/init.c
+++ b/testsuites/sptests/sp21/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2012.
+ * are met:
diff --git a/testsuites/sptests/sp22/delay.c b/testsuites/sptests/sp22/delay.c
index 58ad6dc1da..7863800687 100644
--- a/testsuites/sptests/sp22/delay.c
+++ b/testsuites/sptests/sp22/delay.c
@@ -1,3 +1,5 @@
/* Delayed_resume
* This routine is scheduled to be fired as a timer service routine.
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp22/init.c b/testsuites/sptests/sp22/init.c
index f7f9e2e8ed..f60f4279cf 100644
--- a/testsuites/sptests/sp22/init.c
+++ b/testsuites/sptests/sp22/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp22/prtime.c b/testsuites/sptests/sp22/prtime.c
index 865e0fe0d3..9f9d2c463b 100644
--- a/testsuites/sptests/sp22/prtime.c
+++ b/testsuites/sptests/sp22/prtime.c
@@ -1,3 +1,5 @@
/* Print_time
* This routine prints the name of Task_1 and the current time of day.
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp22/system.h b/testsuites/sptests/sp22/system.h
index 9b5ba9f8e7..16a2d5a93d 100644
--- a/testsuites/sptests/sp22/system.h
+++ b/testsuites/sptests/sp22/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp22/task1.c b/testsuites/sptests/sp22/task1.c
index c44be77f7a..239b564a20 100644
--- a/testsuites/sptests/sp22/task1.c
+++ b/testsuites/sptests/sp22/task1.c
@@ -1,3 +1,5 @@
/* Task_1
* This routine serves as a test task. It verifies the basic task
@@ -11,9 +13,26 @@
* COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/testsuites/sptests/sp23/init.c b/testsuites/sptests/sp23/init.c
index 3605dcca55..e2fba33cf9 100644
--- a/testsuites/sptests/sp23/init.c
+++ b/testsuites/sptests/sp23/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp23/system.h b/testsuites/sptests/sp23/system.h
index b7c1107008..b0debbc262 100644
--- a/testsuites/sptests/sp23/system.h
+++ b/testsuites/sptests/sp23/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp23/task1.c b/testsuites/sptests/sp23/task1.c
index 659eef11d8..e7d0dc6696 100644
--- a/testsuites/sptests/sp23/task1.c
+++ b/testsuites/sptests/sp23/task1.c
@@ -1,3 +1,5 @@
/* Task_1
* This task verifies that the dual ported RAM directives work
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp24/init.c b/testsuites/sptests/sp24/init.c
index cac46fdc2a..ef83de1730 100644
--- a/testsuites/sptests/sp24/init.c
+++ b/testsuites/sptests/sp24/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp24/resume.c b/testsuites/sptests/sp24/resume.c
index b4718a564e..7c3e7e0f75 100644
--- a/testsuites/sptests/sp24/resume.c
+++ b/testsuites/sptests/sp24/resume.c
@@ -1,3 +1,5 @@
/* Resume_task
* This subprogram is scheduled as a timer service routine. When
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2008.
+ * are met:
diff --git a/testsuites/sptests/sp24/system.h b/testsuites/sptests/sp24/system.h
index b0bcad44a1..0b4915644d 100644
--- a/testsuites/sptests/sp24/system.h
+++ b/testsuites/sptests/sp24/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp24/task1.c b/testsuites/sptests/sp24/task1.c
index d6f51f6333..85273158a9 100644
--- a/testsuites/sptests/sp24/task1.c
+++ b/testsuites/sptests/sp24/task1.c
@@ -1,3 +1,5 @@
/* Task_1_through_3
* This task is a cyclic version of test1 to asssure that the times
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp25/init.c b/testsuites/sptests/sp25/init.c
index 2a5af0cede..6aaae407c0 100644
--- a/testsuites/sptests/sp25/init.c
+++ b/testsuites/sptests/sp25/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp25/system.h b/testsuites/sptests/sp25/system.h
index 820fee0578..682aa7e12d 100644
--- a/testsuites/sptests/sp25/system.h
+++ b/testsuites/sptests/sp25/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp25/task1.c b/testsuites/sptests/sp25/task1.c
index 69fe6309d4..d52690fec2 100644
--- a/testsuites/sptests/sp25/task1.c
+++ b/testsuites/sptests/sp25/task1.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp26/init.c b/testsuites/sptests/sp26/init.c
index 0ac7157e7c..d0b5f0b472 100644
--- a/testsuites/sptests/sp26/init.c
+++ b/testsuites/sptests/sp26/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp26/system.h b/testsuites/sptests/sp26/system.h
index e1defb94e2..4a1a5e6479 100644
--- a/testsuites/sptests/sp26/system.h
+++ b/testsuites/sptests/sp26/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-2006.
+ * are met:
diff --git a/testsuites/sptests/sp26/task1.c b/testsuites/sptests/sp26/task1.c
index 45aa08d7b3..cc04d53de3 100644
--- a/testsuites/sptests/sp26/task1.c
+++ b/testsuites/sptests/sp26/task1.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp27/sp27impl.h b/testsuites/sptests/sp27/sp27impl.h
index b9522fd364..0b68ed0cd9 100644
--- a/testsuites/sptests/sp27/sp27impl.h
+++ b/testsuites/sptests/sp27/sp27impl.h
@@ -1,12 +1,31 @@
* Test for rtems_semaphore_flush
+ * are met:
diff --git a/testsuites/sptests/sp30/init.c b/testsuites/sptests/sp30/init.c
index df6324b5a7..9a5ea7330c 100644
--- a/testsuites/sptests/sp30/init.c
+++ b/testsuites/sptests/sp30/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
* COPYRIGHT (c) 1989-2002.
+ * are met:
diff --git a/testsuites/sptests/sp30/resume.c b/testsuites/sptests/sp30/resume.c
index c5ff7fb60b..6dc874ebfe 100644
--- a/testsuites/sptests/sp30/resume.c
+++ b/testsuites/sptests/sp30/resume.c
@@ -1,3 +1,5 @@
/* Resume_task
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp30/system.h b/testsuites/sptests/sp30/system.h
index 0ec1ed9f57..c19bb62423 100644
--- a/testsuites/sptests/sp30/system.h
+++ b/testsuites/sptests/sp30/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp30/task1.c b/testsuites/sptests/sp30/task1.c
index 56aa6aa4ab..4891dab141 100644
--- a/testsuites/sptests/sp30/task1.c
+++ b/testsuites/sptests/sp30/task1.c
@@ -1,3 +1,5 @@
/* Task_1_through_3
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp31/delay.c b/testsuites/sptests/sp31/delay.c
index 0daac3afa7..d49f578b89 100644
--- a/testsuites/sptests/sp31/delay.c
+++ b/testsuites/sptests/sp31/delay.c
@@ -1,3 +1,5 @@
/* Delayed_resume
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp31/init.c b/testsuites/sptests/sp31/init.c
index adbbcb2366..d1b2873d04 100644
--- a/testsuites/sptests/sp31/init.c
+++ b/testsuites/sptests/sp31/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp31/prtime.c b/testsuites/sptests/sp31/prtime.c
index 7d75a9303b..791e1c3f0f 100644
--- a/testsuites/sptests/sp31/prtime.c
+++ b/testsuites/sptests/sp31/prtime.c
@@ -1,3 +1,5 @@
/* Print_time
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp31/system.h b/testsuites/sptests/sp31/system.h
index 05c0009e5a..7cc1ac7a27 100644
--- a/testsuites/sptests/sp31/system.h
+++ b/testsuites/sptests/sp31/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp31/task1.c b/testsuites/sptests/sp31/task1.c
index 0abc0efc11..3bb56cd99d 100644
--- a/testsuites/sptests/sp31/task1.c
+++ b/testsuites/sptests/sp31/task1.c
@@ -1,12 +1,31 @@
* Copyright (c) 2009 embedded brains GmbH.
+ * are met:
diff --git a/testsuites/sptests/sp32/init.c b/testsuites/sptests/sp32/init.c
index 2432a14d2f..21cdaa21f9 100644
--- a/testsuites/sptests/sp32/init.c
+++ b/testsuites/sptests/sp32/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp33/init.c b/testsuites/sptests/sp33/init.c
index 72945a6fe5..c6fb8c5714 100644
--- a/testsuites/sptests/sp33/init.c
+++ b/testsuites/sptests/sp33/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
index 4c8e1a7f64..2ee21b592e 100644
--- a/testsuites/sptests/sp37/init.c
+++ b/testsuites/sptests/sp37/init.c
@@ -1,3 +1,5 @@
* @brief Test for Bodies of Macros
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp37/system.h b/testsuites/sptests/sp37/system.h
index d7b98e40f5..25df9b4115 100644
--- a/testsuites/sptests/sp37/system.h
+++ b/testsuites/sptests/sp37/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp38/init.c b/testsuites/sptests/sp38/init.c
index d77d5d2a1c..20a6f9066b 100644
--- a/testsuites/sptests/sp38/init.c
+++ b/testsuites/sptests/sp38/init.c
@@ -1,12 +1,31 @@
* Classic API Signal to Task from ISR
+ * are met:
diff --git a/testsuites/sptests/sp38/system.h b/testsuites/sptests/sp38/system.h
index 24fb0e6bf0..91ff72c66e 100644
--- a/testsuites/sptests/sp38/system.h
+++ b/testsuites/sptests/sp38/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-2007.
+ * are met:
2.24.4
