[PATCH 01/11] testsuites/sptests/sp0*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Thu Mar 31 22:24:34 UTC 2022
Updates #3053.
testsuites/sptests/sp01/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp01/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp01/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp02/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp02/preempt.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp02/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp02/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp02/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp02/task3.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp03/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp03/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp03/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp03/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp04/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp04/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp04/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp04/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp04/task3.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp04/tswitch.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp05/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp05/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp05/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp05/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp05/task3.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp06/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp06/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp06/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp06/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp06/task3.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp07/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp07/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp07/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp07/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp07/task3.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp07/task4.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp07/taskexit.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp07/tcreate.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp07/tdelete.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp07/trestart.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp07/tstart.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp08/init.c | 25 ++++++++++++++++++++++---
41 files changed, 902 insertions(+), 123 deletions(-)
diff --git a/testsuites/sptests/sp01/init.c b/testsuites/sptests/sp01/init.c
index a630184651..2384430824 100644
--- a/testsuites/sptests/sp01/init.c
+++ b/testsuites/sptests/sp01/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2011.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/testsuites/sptests/sp01/system.h b/testsuites/sptests/sp01/system.h
index 82354b801e..46fa76f1e4 100644
--- a/testsuites/sptests/sp01/system.h
+++ b/testsuites/sptests/sp01/system.h
@@ -1,10 +1,29 @@
+ * are met:
#include <tmacros.h>
diff --git a/testsuites/sptests/sp01/task1.c b/testsuites/sptests/sp01/task1.c
index dcf2ba068c..13d55de3f4 100644
--- a/testsuites/sptests/sp01/task1.c
+++ b/testsuites/sptests/sp01/task1.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp02/init.c b/testsuites/sptests/sp02/init.c
index 170e5441d0..7a3e446a4d 100644
--- a/testsuites/sptests/sp02/init.c
+++ b/testsuites/sptests/sp02/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp02/preempt.c b/testsuites/sptests/sp02/preempt.c
index ebc484bcb9..182f2d044e 100644
--- a/testsuites/sptests/sp02/preempt.c
+++ b/testsuites/sptests/sp02/preempt.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp02/system.h b/testsuites/sptests/sp02/system.h
index aea6dbc217..0f23f013a8 100644
--- a/testsuites/sptests/sp02/system.h
+++ b/testsuites/sptests/sp02/system.h
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp02/task1.c b/testsuites/sptests/sp02/task1.c
index 6abed245a7..6b6b73d500 100644
--- a/testsuites/sptests/sp02/task1.c
+++ b/testsuites/sptests/sp02/task1.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp02/task2.c b/testsuites/sptests/sp02/task2.c
index 21df951c0a..e3da167955 100644
--- a/testsuites/sptests/sp02/task2.c
+++ b/testsuites/sptests/sp02/task2.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp02/task3.c b/testsuites/sptests/sp02/task3.c
index 9c43bbac1b..e6c8f0a1c2 100644
--- a/testsuites/sptests/sp02/task3.c
+++ b/testsuites/sptests/sp02/task3.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp03/init.c b/testsuites/sptests/sp03/init.c
index fa423fceb0..cfb3ce20b8 100644
--- a/testsuites/sptests/sp03/init.c
+++ b/testsuites/sptests/sp03/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp03/system.h b/testsuites/sptests/sp03/system.h
index 53e7b56323..ff28a9cc5f 100644
--- a/testsuites/sptests/sp03/system.h
+++ b/testsuites/sptests/sp03/system.h
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp03/task1.c b/testsuites/sptests/sp03/task1.c
index af05691fe4..de81850e0c 100644
--- a/testsuites/sptests/sp03/task1.c
+++ b/testsuites/sptests/sp03/task1.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp03/task2.c b/testsuites/sptests/sp03/task2.c
index 9e33c2bf4b..24ac739bc7 100644
--- a/testsuites/sptests/sp03/task2.c
+++ b/testsuites/sptests/sp03/task2.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp04/init.c b/testsuites/sptests/sp04/init.c
index b163aec8ed..fb1bb323ed 100644
--- a/testsuites/sptests/sp04/init.c
+++ b/testsuites/sptests/sp04/init.c
@@ -1,3 +1,5 @@
/* Init
* This routine is the initialization task for this test program.
@@ -14,9 +16,26 @@
* COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/testsuites/sptests/sp04/system.h b/testsuites/sptests/sp04/system.h
index 67ed49cba6..242a17ea61 100644
--- a/testsuites/sptests/sp04/system.h
+++ b/testsuites/sptests/sp04/system.h
@@ -1,3 +1,5 @@
/* system.h
* This include file contains information that is included in every
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/testsuites/sptests/sp04/task1.c b/testsuites/sptests/sp04/task1.c
index eac1bf6d51..f55b44e8ca 100644
--- a/testsuites/sptests/sp04/task1.c
+++ b/testsuites/sptests/sp04/task1.c
@@ -1,3 +1,5 @@
/* Task_1
* This test serves as a test task. It verifies timeslicing activities
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp04/task2.c b/testsuites/sptests/sp04/task2.c
index 1e2645ed98..35d95466f4 100644
--- a/testsuites/sptests/sp04/task2.c
+++ b/testsuites/sptests/sp04/task2.c
@@ -1,3 +1,5 @@
/* Task_2
* This routine serves as a test task. It is just a CPU bound task
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp04/task3.c b/testsuites/sptests/sp04/task3.c
index 77b6206e6b..ae40b14b66 100644
--- a/testsuites/sptests/sp04/task3.c
+++ b/testsuites/sptests/sp04/task3.c
@@ -1,3 +1,5 @@
/* Task_3
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp04/tswitch.c b/testsuites/sptests/sp04/tswitch.c
index 25263ef02c..81100bdc1d 100644
--- a/testsuites/sptests/sp04/tswitch.c
+++ b/testsuites/sptests/sp04/tswitch.c
@@ -1,11 +1,30 @@
+ * are met:
diff --git a/testsuites/sptests/sp05/init.c b/testsuites/sptests/sp05/init.c
index 18286a2606..5a04d0c3bb 100644
--- a/testsuites/sptests/sp05/init.c
+++ b/testsuites/sptests/sp05/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp05/system.h b/testsuites/sptests/sp05/system.h
index d20217105e..c8ef19efb2 100644
--- a/testsuites/sptests/sp05/system.h
+++ b/testsuites/sptests/sp05/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp05/task1.c b/testsuites/sptests/sp05/task1.c
index b529768c7e..29b10c5f64 100644
--- a/testsuites/sptests/sp05/task1.c
+++ b/testsuites/sptests/sp05/task1.c
@@ -1,3 +1,5 @@
/* Task_1
* This routine serves as a test task. It verifies that tasks can
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp05/task2.c b/testsuites/sptests/sp05/task2.c
index 1cf52cabea..d4e7c16562 100644
--- a/testsuites/sptests/sp05/task2.c
+++ b/testsuites/sptests/sp05/task2.c
@@ -1,3 +1,5 @@
/* Task_2
* This routine serves as a test task. Makes sure a task can suspend
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp05/task3.c b/testsuites/sptests/sp05/task3.c
index a8addade00..7662b2afbb 100644
--- a/testsuites/sptests/sp05/task3.c
+++ b/testsuites/sptests/sp05/task3.c
@@ -1,3 +1,5 @@
/* Task_3
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp06/init.c b/testsuites/sptests/sp06/init.c
index 4fa723057f..c88d9eb8c4 100644
--- a/testsuites/sptests/sp06/init.c
+++ b/testsuites/sptests/sp06/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp06/system.h b/testsuites/sptests/sp06/system.h
index 272399ab6f..41624899f2 100644
--- a/testsuites/sptests/sp06/system.h
+++ b/testsuites/sptests/sp06/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp06/task1.c b/testsuites/sptests/sp06/task1.c
index cc66000c45..61d8c38881 100644
--- a/testsuites/sptests/sp06/task1.c
+++ b/testsuites/sptests/sp06/task1.c
@@ -1,3 +1,5 @@
/* Task_1
* This task serves as a test task. Verifies that a task can restart
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp06/task2.c b/testsuites/sptests/sp06/task2.c
index 8b07b58e4a..1aa9a25264 100644
--- a/testsuites/sptests/sp06/task2.c
+++ b/testsuites/sptests/sp06/task2.c
@@ -1,3 +1,5 @@
/* Task_2
* This routine serves as a test task. It simply runs forever so
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp06/task3.c b/testsuites/sptests/sp06/task3.c
index c0750fc09b..0baa8d6236 100644
--- a/testsuites/sptests/sp06/task3.c
+++ b/testsuites/sptests/sp06/task3.c
@@ -1,3 +1,5 @@
/* Task_3
* This routine serves as a test task. It is started, has its priority
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp07/init.c b/testsuites/sptests/sp07/init.c
index 083fd21317..e55c0fa474 100644
--- a/testsuites/sptests/sp07/init.c
+++ b/testsuites/sptests/sp07/init.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp07/system.h b/testsuites/sptests/sp07/system.h
index 5e319661e1..cc5f4eb6e7 100644
--- a/testsuites/sptests/sp07/system.h
+++ b/testsuites/sptests/sp07/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp07/task1.c b/testsuites/sptests/sp07/task1.c
index c1896b9c70..56e6c65d39 100644
--- a/testsuites/sptests/sp07/task1.c
+++ b/testsuites/sptests/sp07/task1.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp07/task2.c b/testsuites/sptests/sp07/task2.c
index efa66b6114..74c8d9bdc4 100644
--- a/testsuites/sptests/sp07/task2.c
+++ b/testsuites/sptests/sp07/task2.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp07/task3.c b/testsuites/sptests/sp07/task3.c
index 4277e1e92b..598af3c403 100644
--- a/testsuites/sptests/sp07/task3.c
+++ b/testsuites/sptests/sp07/task3.c
@@ -1,3 +1,5 @@
/* Task_3
* This routine serves as a low priority test task that should never
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp07/task4.c b/testsuites/sptests/sp07/task4.c
index 365b595d81..6b354428e8 100644
--- a/testsuites/sptests/sp07/task4.c
+++ b/testsuites/sptests/sp07/task4.c
@@ -1,3 +1,5 @@
/* Task_4
* This routine serves as a low priority test task that should exit
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp07/taskexit.c b/testsuites/sptests/sp07/taskexit.c
index 6066038d49..8d21b516ae 100644
--- a/testsuites/sptests/sp07/taskexit.c
+++ b/testsuites/sptests/sp07/taskexit.c
@@ -1,3 +1,5 @@
/* Task_exit_extension
* This routine is the task exitted user extension.
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp07/tcreate.c b/testsuites/sptests/sp07/tcreate.c
index 351aacd715..0460358525 100644
--- a/testsuites/sptests/sp07/tcreate.c
+++ b/testsuites/sptests/sp07/tcreate.c
@@ -1,3 +1,5 @@
/* Task_create_extension
* This routine is the tcreate user extension.
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp07/tdelete.c b/testsuites/sptests/sp07/tdelete.c
index a7136e2551..59fe9eeb68 100644
--- a/testsuites/sptests/sp07/tdelete.c
+++ b/testsuites/sptests/sp07/tdelete.c
@@ -1,3 +1,5 @@
/* Task_delete_extension
* This routine is the delete user extension.
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp07/trestart.c b/testsuites/sptests/sp07/trestart.c
index d821562f2b..1f51fec274 100644
--- a/testsuites/sptests/sp07/trestart.c
+++ b/testsuites/sptests/sp07/trestart.c
@@ -1,3 +1,5 @@
/* Task_restart_extension
* This routine is the trestart user extension.
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp07/tstart.c b/testsuites/sptests/sp07/tstart.c
index c2f29cb2dd..6b0ef3ee57 100644
--- a/testsuites/sptests/sp07/tstart.c
+++ b/testsuites/sptests/sp07/tstart.c
@@ -1,3 +1,5 @@
/* Task_start_extension
* This routine is the tstart user extension.
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp08/init.c b/testsuites/sptests/sp08/init.c
index 4229feb15c..4717839a6e 100644
--- a/testsuites/sptests/sp08/init.c
+++ b/testsuites/sptests/sp08/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2012.
+ * are met:
2.24.4
