[PATCH 02/11] testsuites/sptests/sp1*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Thu Mar 31 22:24:35 UTC 2022
Updates #3053.
testsuites/sptests/sp11/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp11/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp11/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp11/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp11/timer.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp12/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp12/pridrv.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp12/pritask.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp12/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp12/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp12/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp12/task3.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp12/task4.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp12/task5.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp13/fillbuff.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp13/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp13/putbuff.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp13/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp13/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp13/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp13/task3.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp14/asr.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp14/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp14/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp14/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp14/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp15/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp15/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp15/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp16/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp16/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp16/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp16/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp16/task3.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp16/task4.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp16/task5.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp17/asr.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp17/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp17/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp17/task1.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp17/task2.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp18/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp19/first.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp19/fptask.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp19/fptest.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp19/init.c | 25 ++++++++++++++++++++++---
testsuites/sptests/sp19/inttest.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp19/system.h | 25 ++++++++++++++++++++++---
testsuites/sptests/sp19/task1.c | 25 ++++++++++++++++++++++---
49 files changed, 1078 insertions(+), 147 deletions(-)
diff --git a/testsuites/sptests/sp11/init.c b/testsuites/sptests/sp11/init.c
index 729cbf052f..9c8e3eeb19 100644
--- a/testsuites/sptests/sp11/init.c
+++ b/testsuites/sptests/sp11/init.c
@@ -1,3 +1,5 @@
/* Init
* This routine is the initialization task for this test program.
@@ -14,9 +16,26 @@
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/testsuites/sptests/sp11/system.h b/testsuites/sptests/sp11/system.h
index a3ce85daea..e717eae143 100644
--- a/testsuites/sptests/sp11/system.h
+++ b/testsuites/sptests/sp11/system.h
@@ -1,3 +1,5 @@
/* system.h
* This include file contains information that is included in every
@@ -6,9 +8,26 @@
+ * are met:
#include <tmacros.h>
diff --git a/testsuites/sptests/sp11/task1.c b/testsuites/sptests/sp11/task1.c
index d10746bae9..720aab70cc 100644
--- a/testsuites/sptests/sp11/task1.c
+++ b/testsuites/sptests/sp11/task1.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
diff --git a/testsuites/sptests/sp11/task2.c b/testsuites/sptests/sp11/task2.c
index 7cda7a773c..c2a05a9269 100644
--- a/testsuites/sptests/sp11/task2.c
+++ b/testsuites/sptests/sp11/task2.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp11/timer.c b/testsuites/sptests/sp11/timer.c
index e606503159..17fdea3a2a 100644
--- a/testsuites/sptests/sp11/timer.c
+++ b/testsuites/sptests/sp11/timer.c
@@ -1,3 +1,5 @@
/* Timer_functions
* These routines are the timer service routines used by this test.
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp12/init.c b/testsuites/sptests/sp12/init.c
index 7aa09d3676..5120a2303c 100644
--- a/testsuites/sptests/sp12/init.c
+++ b/testsuites/sptests/sp12/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
* COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/testsuites/sptests/sp12/pridrv.c b/testsuites/sptests/sp12/pridrv.c
index 83fe65bf0b..33b454125e 100644
--- a/testsuites/sptests/sp12/pridrv.c
+++ b/testsuites/sptests/sp12/pridrv.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp12/pritask.c b/testsuites/sptests/sp12/pritask.c
index 2de764a524..33f2c0a4c9 100644
--- a/testsuites/sptests/sp12/pritask.c
+++ b/testsuites/sptests/sp12/pritask.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp12/system.h b/testsuites/sptests/sp12/system.h
index 107831b3a0..f81e492154 100644
--- a/testsuites/sptests/sp12/system.h
+++ b/testsuites/sptests/sp12/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
* COPYRIGHT (c) 1989-2008.
+ * are met:
diff --git a/testsuites/sptests/sp12/task1.c b/testsuites/sptests/sp12/task1.c
index 633e0ab32f..60a31f3368 100644
--- a/testsuites/sptests/sp12/task1.c
+++ b/testsuites/sptests/sp12/task1.c
@@ -1,3 +1,5 @@
/* Task_1
* This routine serves as a test task. It verifies the semaphore manager.
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp12/task2.c b/testsuites/sptests/sp12/task2.c
index b701b4b6f1..04e2e1dc11 100644
--- a/testsuites/sptests/sp12/task2.c
+++ b/testsuites/sptests/sp12/task2.c
@@ -1,3 +1,5 @@
/* Task_2
* This routine serves as a test task. It simply obtains semaphores
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp12/task3.c b/testsuites/sptests/sp12/task3.c
index 0045f94767..1e1c1fe163 100644
--- a/testsuites/sptests/sp12/task3.c
+++ b/testsuites/sptests/sp12/task3.c
@@ -1,3 +1,5 @@
/* Task_3
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp12/task4.c b/testsuites/sptests/sp12/task4.c
index b5c2585198..cfaccbb4a1 100644
--- a/testsuites/sptests/sp12/task4.c
+++ b/testsuites/sptests/sp12/task4.c
@@ -1,3 +1,5 @@
/* Task_4
* This routine serves as a test task. It waits forever attempting
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp12/task5.c b/testsuites/sptests/sp12/task5.c
index a8dfa333fc..9f6411c8db 100644
--- a/testsuites/sptests/sp12/task5.c
+++ b/testsuites/sptests/sp12/task5.c
@@ -1,3 +1,5 @@
/* Task5
* This routine serves as a test task. It obtains semaphore 1 correctly
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp13/fillbuff.c b/testsuites/sptests/sp13/fillbuff.c
index d39d073fc0..5a559af7e4 100644
--- a/testsuites/sptests/sp13/fillbuff.c
+++ b/testsuites/sptests/sp13/fillbuff.c
@@ -1,3 +1,5 @@
/* Fill_buffer
* This test routine copies a given source string to a given destination
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp13/init.c b/testsuites/sptests/sp13/init.c
index f8ffd55426..1dfb457955 100644
--- a/testsuites/sptests/sp13/init.c
+++ b/testsuites/sptests/sp13/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp13/putbuff.c b/testsuites/sptests/sp13/putbuff.c
index d6c22568d6..0bc9d7c51f 100644
--- a/testsuites/sptests/sp13/putbuff.c
+++ b/testsuites/sptests/sp13/putbuff.c
@@ -1,3 +1,5 @@
/* Put_buffer
* This test routine prints the given buffer.
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp13/system.h b/testsuites/sptests/sp13/system.h
index 1abfc96b1d..522ac9db41 100644
--- a/testsuites/sptests/sp13/system.h
+++ b/testsuites/sptests/sp13/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp13/task1.c b/testsuites/sptests/sp13/task1.c
index ccf543b791..df98d24101 100644
--- a/testsuites/sptests/sp13/task1.c
+++ b/testsuites/sptests/sp13/task1.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2011, 2016.
+ * are met:
diff --git a/testsuites/sptests/sp13/task2.c b/testsuites/sptests/sp13/task2.c
index 71a7c1457e..8020ec2d5c 100644
--- a/testsuites/sptests/sp13/task2.c
+++ b/testsuites/sptests/sp13/task2.c
@@ -1,3 +1,5 @@
/* Task_2
* This routine serves as a test task. Multiple tasks are required to
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp13/task3.c b/testsuites/sptests/sp13/task3.c
index af65b88334..827d91c6cd 100644
--- a/testsuites/sptests/sp13/task3.c
+++ b/testsuites/sptests/sp13/task3.c
@@ -1,3 +1,5 @@
/* Task_3
* This routine serves as a test task. Its major function is to
@@ -11,9 +13,26 @@
* COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/testsuites/sptests/sp14/asr.c b/testsuites/sptests/sp14/asr.c
index 4239a34183..9a1c82f04e 100644
--- a/testsuites/sptests/sp14/asr.c
+++ b/testsuites/sptests/sp14/asr.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp14/init.c b/testsuites/sptests/sp14/init.c
index 8baa9b0d74..78c8a3188f 100644
--- a/testsuites/sptests/sp14/init.c
+++ b/testsuites/sptests/sp14/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp14/system.h b/testsuites/sptests/sp14/system.h
index b0e04a129e..307fc8e5c3 100644
--- a/testsuites/sptests/sp14/system.h
+++ b/testsuites/sptests/sp14/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp14/task1.c b/testsuites/sptests/sp14/task1.c
index 07657272dc..5f4ec745b8 100644
--- a/testsuites/sptests/sp14/task1.c
+++ b/testsuites/sptests/sp14/task1.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp14/task2.c b/testsuites/sptests/sp14/task2.c
index da14dc8ce3..4ac8b62649 100644
--- a/testsuites/sptests/sp14/task2.c
+++ b/testsuites/sptests/sp14/task2.c
@@ -1,3 +1,5 @@
/* Task_2
* This routine serves as a test task. It verifies that one task can
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp15/init.c b/testsuites/sptests/sp15/init.c
index 2565495a06..799dc9ae6a 100644
--- a/testsuites/sptests/sp15/init.c
+++ b/testsuites/sptests/sp15/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp15/system.h b/testsuites/sptests/sp15/system.h
index 68fd100a6a..0af8fa486b 100644
--- a/testsuites/sptests/sp15/system.h
+++ b/testsuites/sptests/sp15/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp15/task1.c b/testsuites/sptests/sp15/task1.c
index 609d37fc2e..e411f311a2 100644
--- a/testsuites/sptests/sp15/task1.c
+++ b/testsuites/sptests/sp15/task1.c
@@ -1,3 +1,5 @@
/* Task_1
* This routine serves as a test task. It tests the partition manager.
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp16/init.c b/testsuites/sptests/sp16/init.c
index efb0a3e903..92c18cb44a 100644
--- a/testsuites/sptests/sp16/init.c
+++ b/testsuites/sptests/sp16/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp16/system.h b/testsuites/sptests/sp16/system.h
index 8299e7e8ca..51f6aae008 100644
--- a/testsuites/sptests/sp16/system.h
+++ b/testsuites/sptests/sp16/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp16/task1.c b/testsuites/sptests/sp16/task1.c
index aa147a9260..5b05319dc1 100644
--- a/testsuites/sptests/sp16/task1.c
+++ b/testsuites/sptests/sp16/task1.c
@@ -1,3 +1,5 @@
/* Task_1
* This routine serves as a test task. It tests the region manager.
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp16/task2.c b/testsuites/sptests/sp16/task2.c
index 399517854f..3b4c773cce 100644
--- a/testsuites/sptests/sp16/task2.c
+++ b/testsuites/sptests/sp16/task2.c
@@ -1,3 +1,5 @@
/* Task_2
* This routine serves as a test task. It competes with the other tasks
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp16/task3.c b/testsuites/sptests/sp16/task3.c
index bb7acf1248..fdf66e92a5 100644
--- a/testsuites/sptests/sp16/task3.c
+++ b/testsuites/sptests/sp16/task3.c
@@ -1,3 +1,5 @@
/* Task_3
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp16/task4.c b/testsuites/sptests/sp16/task4.c
index ce39191c2f..7f7ce799b5 100644
--- a/testsuites/sptests/sp16/task4.c
+++ b/testsuites/sptests/sp16/task4.c
@@ -1,3 +1,5 @@
/* Task_4
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp16/task5.c b/testsuites/sptests/sp16/task5.c
index e5e524a790..c67a1fa641 100644
--- a/testsuites/sptests/sp16/task5.c
+++ b/testsuites/sptests/sp16/task5.c
@@ -1,3 +1,5 @@
/* Task5
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp17/asr.c b/testsuites/sptests/sp17/asr.c
index fa364a7861..94b0fa365c 100644
--- a/testsuites/sptests/sp17/asr.c
+++ b/testsuites/sptests/sp17/asr.c
@@ -1,3 +1,5 @@
/* Process_asr
* This routine performs the processing for task 1's RTEMS_ASR. It is called
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp17/init.c b/testsuites/sptests/sp17/init.c
index fd6023caa9..bb4a3a353b 100644
--- a/testsuites/sptests/sp17/init.c
+++ b/testsuites/sptests/sp17/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp17/system.h b/testsuites/sptests/sp17/system.h
index 52884269da..0f78218560 100644
--- a/testsuites/sptests/sp17/system.h
+++ b/testsuites/sptests/sp17/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp17/task1.c b/testsuites/sptests/sp17/task1.c
index d21c782ae0..7fcc9bf11b 100644
--- a/testsuites/sptests/sp17/task1.c
+++ b/testsuites/sptests/sp17/task1.c
@@ -1,3 +1,5 @@
/* Task_1
* This task initializes the signal catcher, sends the first signal
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp17/task2.c b/testsuites/sptests/sp17/task2.c
index 34c89f13b8..2254842e09 100644
--- a/testsuites/sptests/sp17/task2.c
+++ b/testsuites/sptests/sp17/task2.c
@@ -1,3 +1,5 @@
/* Task_2
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp18/init.c b/testsuites/sptests/sp18/init.c
index 7a4bb14d26..e38e9d1738 100644
--- a/testsuites/sptests/sp18/init.c
+++ b/testsuites/sptests/sp18/init.c
@@ -1,10 +1,29 @@
* COPYRIGHT (c) 1989-2012.
+ * are met:
diff --git a/testsuites/sptests/sp19/first.c b/testsuites/sptests/sp19/first.c
index 00da9edd6e..f602c927e4 100644
--- a/testsuites/sptests/sp19/first.c
+++ b/testsuites/sptests/sp19/first.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp19/fptask.c b/testsuites/sptests/sp19/fptask.c
index c91a163f47..79e7dbf760 100644
--- a/testsuites/sptests/sp19/fptask.c
+++ b/testsuites/sptests/sp19/fptask.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/testsuites/sptests/sp19/fptest.h b/testsuites/sptests/sp19/fptest.h
index 285b5ddcb1..c9dd5351ac 100644
--- a/testsuites/sptests/sp19/fptest.h
+++ b/testsuites/sptests/sp19/fptest.h
@@ -1,3 +1,5 @@
* @file
* @brief Floating Point Register Pressure and Check
@@ -19,9 +21,26 @@
* COPYRIGHT (c) 1989-2014.
+ * are met:
diff --git a/testsuites/sptests/sp19/init.c b/testsuites/sptests/sp19/init.c
index ca15fb8cfa..eb87a382a3 100644
--- a/testsuites/sptests/sp19/init.c
+++ b/testsuites/sptests/sp19/init.c
@@ -1,3 +1,5 @@
/* Init
@@ -14,9 +16,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp19/inttest.h b/testsuites/sptests/sp19/inttest.h
index bf2156e848..1f07090547 100644
--- a/testsuites/sptests/sp19/inttest.h
+++ b/testsuites/sptests/sp19/inttest.h
@@ -1,3 +1,5 @@
* This include file contains the CPU dependent implementation
* of the following routines needed to test RTEMS floating
@@ -16,9 +18,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp19/system.h b/testsuites/sptests/sp19/system.h
index 59ae0104f0..e99c2a22b6 100644
--- a/testsuites/sptests/sp19/system.h
+++ b/testsuites/sptests/sp19/system.h
@@ -1,3 +1,5 @@
/* system.h
@@ -6,9 +8,26 @@
+ * are met:
diff --git a/testsuites/sptests/sp19/task1.c b/testsuites/sptests/sp19/task1.c
index b5cbdcd181..cd23973ad5 100644
--- a/testsuites/sptests/sp19/task1.c
+++ b/testsuites/sptests/sp19/task1.c
@@ -1,10 +1,29 @@
+ * are met:
2.24.4
