[PATCH 5/7] cpukit/libcsupport/src/[s-z]*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Wed Mar 30 22:45:28 UTC 2022
Updates #3053.
cpukit/libcsupport/src/setegid.c | 25 ++++++++++--
cpukit/libcsupport/src/seteuid.c | 25 ++++++++++--
cpukit/libcsupport/src/setgroups.c | 25 ++++++++++--
cpukit/libcsupport/src/setuid.c | 25 ++++++++++--
cpukit/libcsupport/src/stat.c | 25 ++++++++++--
cpukit/libcsupport/src/statvfs.c | 25 ++++++++++--
.../src/sup_fs_check_permissions.c | 25 ++++++++++--
cpukit/libcsupport/src/sup_fs_deviceio.c | 25 ++++++++++--
cpukit/libcsupport/src/sup_fs_eval_path.c | 25 ++++++++++--
.../src/sup_fs_eval_path_generic.c | 25 ++++++++++--
.../src/sup_fs_exist_in_same_instance.c | 25 ++++++++++--
cpukit/libcsupport/src/sup_fs_location.c | 25 ++++++++++--
cpukit/libcsupport/src/sup_fs_mount_iterate.c | 25 ++++++++++--
cpukit/libcsupport/src/sup_fs_next_token.c | 25 ++++++++++--
cpukit/libcsupport/src/symlink.c | 25 ++++++++++--
cpukit/libcsupport/src/sync.c | 25 ++++++++++--
cpukit/libcsupport/src/tcdrain.c | 25 ++++++++++--
cpukit/libcsupport/src/tcflow.c | 25 ++++++++++--
cpukit/libcsupport/src/tcflush.c | 32 +++++++++++++---
cpukit/libcsupport/src/tcgetattr.c | 25 ++++++++++--
cpukit/libcsupport/src/tcgetpgrp.c | 25 ++++++++++--
cpukit/libcsupport/src/tcsendbreak.c | 25 ++++++++++--
cpukit/libcsupport/src/tcsetattr.c | 25 ++++++++++--
cpukit/libcsupport/src/tcsetpgrp.c | 25 ++++++++++--
cpukit/libcsupport/src/termios_baud2index.c | 25 ++++++++++--
cpukit/libcsupport/src/termios_baud2num.c | 25 ++++++++++--
cpukit/libcsupport/src/termios_baudtable.c | 25 ++++++++++--
cpukit/libcsupport/src/termios_num2baud.c | 25 ++++++++++--
cpukit/libcsupport/src/termios_setbestbaud.c | 25 ++++++++++--
.../libcsupport/src/termios_setinitialbaud.c | 25 ++++++++++--
cpukit/libcsupport/src/truncate.c | 25 ++++++++++--
cpukit/libcsupport/src/uenvgetgroups.c | 25 ++++++++++--
cpukit/libcsupport/src/umask.c | 25 ++++++++++--
cpukit/libcsupport/src/unlink.c | 25 ++++++++++--
cpukit/libcsupport/src/unmount.c | 25 ++++++++++--
cpukit/libcsupport/src/utsname.c | 25 ++++++++++--
cpukit/libcsupport/src/vprintk.c | 25 ++++++++++--
cpukit/libcsupport/src/write.c | 25 ++++++++++--
cpukit/libcsupport/src/write_r.c | 25 ++++++++++--
cpukit/libcsupport/src/writev.c | 38 +++++++++++++++----
40 files changed, 893 insertions(+), 127 deletions(-)
diff --git a/cpukit/libcsupport/src/setegid.c b/cpukit/libcsupport/src/setegid.c
index 4303e73ebe..35fe006932 100644
--- a/cpukit/libcsupport/src/setegid.c
+++ b/cpukit/libcsupport/src/setegid.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2007.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/libcsupport/src/seteuid.c b/cpukit/libcsupport/src/seteuid.c
index 5d05968d62..4776a09bee 100644
--- a/cpukit/libcsupport/src/seteuid.c
+++ b/cpukit/libcsupport/src/seteuid.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-2010.
+ * are met:
diff --git a/cpukit/libcsupport/src/setgroups.c b/cpukit/libcsupport/src/setgroups.c
index 322fa0e27a..4da8d5abf1 100644
--- a/cpukit/libcsupport/src/setgroups.c
+++ b/cpukit/libcsupport/src/setgroups.c
@@ -1,9 +1,28 @@
* Copyright (c) 2016 embedded brains GmbH. All rights reserved.
+ * are met:
#include <unistd.h>
diff --git a/cpukit/libcsupport/src/setuid.c b/cpukit/libcsupport/src/setuid.c
index 0c18ee5ad8..03c741cb71 100644
--- a/cpukit/libcsupport/src/setuid.c
+++ b/cpukit/libcsupport/src/setuid.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/stat.c b/cpukit/libcsupport/src/stat.c
index 1de1c835aa..17aaea7bb8 100644
--- a/cpukit/libcsupport/src/stat.c
+++ b/cpukit/libcsupport/src/stat.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-2013.
+ * are met:
diff --git a/cpukit/libcsupport/src/statvfs.c b/cpukit/libcsupport/src/statvfs.c
index 04f223594d..86fcec17e2 100644
--- a/cpukit/libcsupport/src/statvfs.c
+++ b/cpukit/libcsupport/src/statvfs.c
@@ -1,9 +1,28 @@
* COPYRIGHT (c) 2009 Chris Johns <chrisj at rtems.org>
+ * are met:
* The statvfs as defined by the SUS:
diff --git a/cpukit/libcsupport/src/sup_fs_check_permissions.c b/cpukit/libcsupport/src/sup_fs_check_permissions.c
index 3eeca4c716..6cc23dc82f 100644
--- a/cpukit/libcsupport/src/sup_fs_check_permissions.c
+++ b/cpukit/libcsupport/src/sup_fs_check_permissions.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/sup_fs_deviceio.c b/cpukit/libcsupport/src/sup_fs_deviceio.c
index f7430fbf6a..7b43013d6f 100644
--- a/cpukit/libcsupport/src/sup_fs_deviceio.c
+++ b/cpukit/libcsupport/src/sup_fs_deviceio.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/sup_fs_eval_path.c b/cpukit/libcsupport/src/sup_fs_eval_path.c
index f725606422..00e73a63a2 100644
--- a/cpukit/libcsupport/src/sup_fs_eval_path.c
+++ b/cpukit/libcsupport/src/sup_fs_eval_path.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/sup_fs_eval_path_generic.c b/cpukit/libcsupport/src/sup_fs_eval_path_generic.c
index 9080e70090..ab6ed915f3 100644
--- a/cpukit/libcsupport/src/sup_fs_eval_path_generic.c
+++ b/cpukit/libcsupport/src/sup_fs_eval_path_generic.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c b/cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c
index 33747eec77..f0cf72c33e 100644
--- a/cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c
+++ b/cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/sup_fs_location.c b/cpukit/libcsupport/src/sup_fs_location.c
index a4e9bbc1e7..bbd81d2d48 100644
--- a/cpukit/libcsupport/src/sup_fs_location.c
+++ b/cpukit/libcsupport/src/sup_fs_location.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
* Copyright (c) 2012-2015 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/sup_fs_mount_iterate.c b/cpukit/libcsupport/src/sup_fs_mount_iterate.c
index 2580290ad6..a343abf706 100644
--- a/cpukit/libcsupport/src/sup_fs_mount_iterate.c
+++ b/cpukit/libcsupport/src/sup_fs_mount_iterate.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/sup_fs_next_token.c b/cpukit/libcsupport/src/sup_fs_next_token.c
index 6f0721439c..83abfacaab 100644
--- a/cpukit/libcsupport/src/sup_fs_next_token.c
+++ b/cpukit/libcsupport/src/sup_fs_next_token.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/symlink.c b/cpukit/libcsupport/src/symlink.c
index dfe1cf6f48..e0ad0af33a 100644
--- a/cpukit/libcsupport/src/symlink.c
+++ b/cpukit/libcsupport/src/symlink.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/cpukit/libcsupport/src/sync.c b/cpukit/libcsupport/src/sync.c
index 265c6f07c9..541c87dc33 100644
--- a/cpukit/libcsupport/src/sync.c
+++ b/cpukit/libcsupport/src/sync.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-2008.
+ * are met:
diff --git a/cpukit/libcsupport/src/tcdrain.c b/cpukit/libcsupport/src/tcdrain.c
index eef10dd921..2b947819c2 100644
--- a/cpukit/libcsupport/src/tcdrain.c
+++ b/cpukit/libcsupport/src/tcdrain.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/tcflow.c b/cpukit/libcsupport/src/tcflow.c
index a35f2ae1a9..cda9b042e0 100644
--- a/cpukit/libcsupport/src/tcflow.c
+++ b/cpukit/libcsupport/src/tcflow.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/tcflush.c b/cpukit/libcsupport/src/tcflush.c
index 40d3c1e67d..bc44a8fee8 100644
--- a/cpukit/libcsupport/src/tcflush.c
+++ b/cpukit/libcsupport/src/tcflush.c
@@ -1,12 +1,34 @@
+ * @file
+ * @brief tcflush() - POSIX 1003.1b 7.2.2 - Line Control Functions
- * tcflush() - POSIX 1003.1b 7.2.2 - Line Control Functions
+ * are met:
diff --git a/cpukit/libcsupport/src/tcgetattr.c b/cpukit/libcsupport/src/tcgetattr.c
index 41b4152488..730e60e6a1 100644
--- a/cpukit/libcsupport/src/tcgetattr.c
+++ b/cpukit/libcsupport/src/tcgetattr.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/tcgetpgrp.c b/cpukit/libcsupport/src/tcgetpgrp.c
index df2b3f59f9..b6a1213395 100644
--- a/cpukit/libcsupport/src/tcgetpgrp.c
+++ b/cpukit/libcsupport/src/tcgetpgrp.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/tcsendbreak.c b/cpukit/libcsupport/src/tcsendbreak.c
index af6df3bff1..4a8aa7ded6 100644
--- a/cpukit/libcsupport/src/tcsendbreak.c
+++ b/cpukit/libcsupport/src/tcsendbreak.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/tcsetattr.c b/cpukit/libcsupport/src/tcsetattr.c
index f01a7c448e..da931e6a34 100644
--- a/cpukit/libcsupport/src/tcsetattr.c
+++ b/cpukit/libcsupport/src/tcsetattr.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/tcsetpgrp.c b/cpukit/libcsupport/src/tcsetpgrp.c
index b7bc01b48d..b7ee951395 100644
--- a/cpukit/libcsupport/src/tcsetpgrp.c
+++ b/cpukit/libcsupport/src/tcsetpgrp.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/termios_baud2index.c b/cpukit/libcsupport/src/termios_baud2index.c
index 1ead66b29b..17b3c40b29 100644
--- a/cpukit/libcsupport/src/termios_baud2index.c
+++ b/cpukit/libcsupport/src/termios_baud2index.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/termios_baud2num.c b/cpukit/libcsupport/src/termios_baud2num.c
index d91aeed1d1..4a20938ff0 100644
--- a/cpukit/libcsupport/src/termios_baud2num.c
+++ b/cpukit/libcsupport/src/termios_baud2num.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/termios_baudtable.c b/cpukit/libcsupport/src/termios_baudtable.c
index 170883fdfc..62b126f5ac 100644
--- a/cpukit/libcsupport/src/termios_baudtable.c
+++ b/cpukit/libcsupport/src/termios_baudtable.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/termios_num2baud.c b/cpukit/libcsupport/src/termios_num2baud.c
index e4cb8ea2d9..c50afd16f9 100644
--- a/cpukit/libcsupport/src/termios_num2baud.c
+++ b/cpukit/libcsupport/src/termios_num2baud.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/termios_setbestbaud.c b/cpukit/libcsupport/src/termios_setbestbaud.c
index fe8463f9c3..c5d83eb391 100644
--- a/cpukit/libcsupport/src/termios_setbestbaud.c
+++ b/cpukit/libcsupport/src/termios_setbestbaud.c
@@ -1,9 +1,28 @@
* Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/termios_setinitialbaud.c b/cpukit/libcsupport/src/termios_setinitialbaud.c
index 1e615185ff..9331233927 100644
--- a/cpukit/libcsupport/src/termios_setinitialbaud.c
+++ b/cpukit/libcsupport/src/termios_setinitialbaud.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/truncate.c b/cpukit/libcsupport/src/truncate.c
index adefcb2d18..cfb11b1b0e 100644
--- a/cpukit/libcsupport/src/truncate.c
+++ b/cpukit/libcsupport/src/truncate.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/uenvgetgroups.c b/cpukit/libcsupport/src/uenvgetgroups.c
index 9c53dee95d..da1706e40c 100644
--- a/cpukit/libcsupport/src/uenvgetgroups.c
+++ b/cpukit/libcsupport/src/uenvgetgroups.c
@@ -1,10 +1,29 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/umask.c b/cpukit/libcsupport/src/umask.c
index 616dfb908f..5403834771 100644
--- a/cpukit/libcsupport/src/umask.c
+++ b/cpukit/libcsupport/src/umask.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/unlink.c b/cpukit/libcsupport/src/unlink.c
index 1d09accf3a..ee767f223f 100644
--- a/cpukit/libcsupport/src/unlink.c
+++ b/cpukit/libcsupport/src/unlink.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/unmount.c b/cpukit/libcsupport/src/unmount.c
index dacd0db067..65836a0a0f 100644
--- a/cpukit/libcsupport/src/unmount.c
+++ b/cpukit/libcsupport/src/unmount.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/utsname.c b/cpukit/libcsupport/src/utsname.c
index c1ca216eb3..8089222127 100644
--- a/cpukit/libcsupport/src/utsname.c
+++ b/cpukit/libcsupport/src/utsname.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/vprintk.c b/cpukit/libcsupport/src/vprintk.c
index a9bf30542e..ccc2345c79 100644
--- a/cpukit/libcsupport/src/vprintk.c
+++ b/cpukit/libcsupport/src/vprintk.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2017 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/write.c b/cpukit/libcsupport/src/write.c
index c9e0d37a44..a4a24d932c 100644
--- a/cpukit/libcsupport/src/write.c
+++ b/cpukit/libcsupport/src/write.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
diff --git a/cpukit/libcsupport/src/write_r.c b/cpukit/libcsupport/src/write_r.c
index 6597337efb..f82c5c3a5e 100644
--- a/cpukit/libcsupport/src/write_r.c
+++ b/cpukit/libcsupport/src/write_r.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/writev.c b/cpukit/libcsupport/src/writev.c
index 499017aea1..a43b6fc0d8 100644
--- a/cpukit/libcsupport/src/writev.c
+++ b/cpukit/libcsupport/src/writev.c
@@ -1,16 +1,38 @@
- * writev() - POSIX 1003.1 - Write a Vector
- * OpenGroup URL:
+ * @file
+ * @brief writev() - POSIX 1003.1 - Write a Vector
- * http://www.opengroup.org/onlinepubs/009695399/functions/writev.html
+ * OpenGroup URL:
+ * http://www.opengroup.org/onlinepubs/009695399/functions/writev.html
+ * are met:
2.24.4
