[PATCH 6/7] cpukit/libcsupport/src/[g-r]*: Change license to BSD-2
Wed Mar 30 22:45:29 UTC 2022
Updates #3053.
 cpukit/libcsupport/src/getchark.c             | 25 +++++++++++++--
 cpukit/libcsupport/src/getdents.c             | 25 +++++++++++++--
 cpukit/libcsupport/src/getrusage.c            | 25 +++++++++++++--
 cpukit/libcsupport/src/getuid.c               | 25 +++++++++++++--
 cpukit/libcsupport/src/ioctl.c                | 25 +++++++++++++--
 cpukit/libcsupport/src/isatty_r.c             | 25 +++++++++++++--
 cpukit/libcsupport/src/libio.c                | 25 +++++++++++++--
 cpukit/libcsupport/src/libio_exit.c           | 25 +++++++++++++--
 cpukit/libcsupport/src/libio_init.c           | 25 +++++++++++++--
 cpukit/libcsupport/src/link.c                 | 25 +++++++++++++--
 cpukit/libcsupport/src/lseek.c                | 32 ++++++++++++++++---
 cpukit/libcsupport/src/lstat.c                | 25 +++++++++++++--
 cpukit/libcsupport/src/malloc.c               | 25 +++++++++++++--
 cpukit/libcsupport/src/malloc_deferred.c      | 25 +++++++++++++--
 cpukit/libcsupport/src/malloc_dirtier.c       | 25 +++++++++++++--
 cpukit/libcsupport/src/malloc_p.h             | 25 +++++++++++++--
 cpukit/libcsupport/src/malloc_walk.c          | 25 +++++++++++++--
 cpukit/libcsupport/src/mallocfreespace.c      | 25 +++++++++++++--
 cpukit/libcsupport/src/mallocgetheapptr.c     | 25 +++++++++++++--
 cpukit/libcsupport/src/mallocinfo.c           | 25 +++++++++++++--
 cpukit/libcsupport/src/mallocsetheapptr.c     | 25 +++++++++++++--
 cpukit/libcsupport/src/mkdir.c                | 25 +++++++++++++--
 cpukit/libcsupport/src/mkfifo.c               | 25 +++++++++++++--
 cpukit/libcsupport/src/mknod.c                | 25 +++++++++++++--
 cpukit/libcsupport/src/mount-mgr.c            | 25 +++++++++++++--
 cpukit/libcsupport/src/mount-mktgt.c          | 25 +++++++++++++--
 cpukit/libcsupport/src/mount.c                | 25 +++++++++++++--
 cpukit/libcsupport/src/open.c                 | 25 +++++++++++++--
 cpukit/libcsupport/src/open_dev_console.c     | 32 ++++++++++++++++---
 cpukit/libcsupport/src/pathconf.c             | 25 +++++++++++++--
 cpukit/libcsupport/src/posix_memalign.c       | 25 +++++++++++++--
 cpukit/libcsupport/src/print_fprintf.c        | 25 +++++++++++++--
 cpukit/libcsupport/src/print_printf.c         | 25 +++++++++++++--
 cpukit/libcsupport/src/printerfprintfputc.c   | 25 +++++++++++++--
 cpukit/libcsupport/src/printertask.c          | 25 +++++++++++++--
 cpukit/libcsupport/src/printf_plugin.c        | 25 +++++++++++++--
 cpukit/libcsupport/src/printk_plugin.c        | 25 +++++++++++++--
 cpukit/libcsupport/src/privateenv.c           | 25 +++++++++++++--
 cpukit/libcsupport/src/putk.c                 | 25 +++++++++++++--
 cpukit/libcsupport/src/pwdgrp.h               | 25 +++++++++++++--
 cpukit/libcsupport/src/read.c                 | 25 +++++++++++++--
 cpukit/libcsupport/src/readlink.c             | 25 +++++++++++++--
 cpukit/libcsupport/src/readv.c                | 25 +++++++++++++--
 cpukit/libcsupport/src/realloc.c              | 25 +++++++++++++--
 cpukit/libcsupport/src/resource_snapshot.c    | 25 +++++++++++++--
 cpukit/libcsupport/src/rmdir.c                | 25 +++++++++++++--
 cpukit/libcsupport/src/rtems_heap_extend.c    | 25 +++++++++++++--
 .../src/rtems_heap_extend_via_sbrk.c          | 25 +++++++++++++--
 cpukit/libcsupport/src/rtems_heap_greedy.c    | 25 +++++++++++++--
 .../libcsupport/src/rtems_heap_null_extend.c  | 25 +++++++++++++--
 cpukit/libcsupport/src/rtems_memalign.c       | 25 +++++++++++++--
 51 files changed, 1132 insertions(+), 157 deletions(-)
diff --git a/cpukit/libcsupport/src/getchark.c b/cpukit/libcsupport/src/getchark.c
index 2bb8bc64d2..499b76069e 100644
--- a/cpukit/libcsupport/src/getchark.c
+++ b/cpukit/libcsupport/src/getchark.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
  *  COPYRIGHT (c) 1989-2008.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/libcsupport/src/getdents.c b/cpukit/libcsupport/src/getdents.c
index d8e7efb2ab..23b48f669c 100644
--- a/cpukit/libcsupport/src/getdents.c
+++ b/cpukit/libcsupport/src/getdents.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
  *  COPYRIGHT (c) 1989-2013.
+ * are met:
diff --git a/cpukit/libcsupport/src/getrusage.c b/cpukit/libcsupport/src/getrusage.c
index 99c1ba8072..8d7a0354e3 100644
--- a/cpukit/libcsupport/src/getrusage.c
+++ b/cpukit/libcsupport/src/getrusage.c
@@ -1,10 +1,29 @@
  *  COPYRIGHT (c) 1989-2010.
+ * are met:
diff --git a/cpukit/libcsupport/src/getuid.c b/cpukit/libcsupport/src/getuid.c
index 0faf238094..00c3c6d167 100644
--- a/cpukit/libcsupport/src/getuid.c
+++ b/cpukit/libcsupport/src/getuid.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/ioctl.c b/cpukit/libcsupport/src/ioctl.c
index 203a0aa5ba..0c7cfc63df 100644
--- a/cpukit/libcsupport/src/ioctl.c
+++ b/cpukit/libcsupport/src/ioctl.c
@@ -1,3 +1,5 @@
  * @file
@@ -13,9 +15,26 @@
  *  COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/cpukit/libcsupport/src/isatty_r.c b/cpukit/libcsupport/src/isatty_r.c
index d4c30af92e..7a758c54a8 100644
--- a/cpukit/libcsupport/src/isatty_r.c
+++ b/cpukit/libcsupport/src/isatty_r.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
  *  COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/cpukit/libcsupport/src/libio.c b/cpukit/libcsupport/src/libio.c
index 72015d5a93..6a0fb31e71 100644
--- a/cpukit/libcsupport/src/libio.c
+++ b/cpukit/libcsupport/src/libio.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/libio_exit.c b/cpukit/libcsupport/src/libio_exit.c
index f9afea2037..f4a865c544 100644
--- a/cpukit/libcsupport/src/libio_exit.c
+++ b/cpukit/libcsupport/src/libio_exit.c
@@ -1,3 +1,5 @@
  * @file
@@ -7,9 +9,26 @@
  * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/libio_init.c b/cpukit/libcsupport/src/libio_init.c
index 2bfc7664d7..250112d9d8 100644
--- a/cpukit/libcsupport/src/libio_init.c
+++ b/cpukit/libcsupport/src/libio_init.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/link.c b/cpukit/libcsupport/src/link.c
index 5b2c2743ea..3a5b4ce730 100644
--- a/cpukit/libcsupport/src/link.c
+++ b/cpukit/libcsupport/src/link.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/lseek.c b/cpukit/libcsupport/src/lseek.c
index ca1b59fbbd..095356aee9 100644
--- a/cpukit/libcsupport/src/lseek.c
+++ b/cpukit/libcsupport/src/lseek.c
@@ -1,12 +1,34 @@
+ * @file
+ * @brief lseek() - POSIX 1003.1b 6.5.3 - Reposition Read/Write File Offset
- *  lseek() - POSIX 1003.1b 6.5.3 - Reposition Read/Write File Offset
+ * are met:
diff --git a/cpukit/libcsupport/src/lstat.c b/cpukit/libcsupport/src/lstat.c
index 69e97714a6..327ff75024 100644
--- a/cpukit/libcsupport/src/lstat.c
+++ b/cpukit/libcsupport/src/lstat.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/malloc.c b/cpukit/libcsupport/src/malloc.c
index 3e55a94c83..f2dbdb4464 100644
--- a/cpukit/libcsupport/src/malloc.c
+++ b/cpukit/libcsupport/src/malloc.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
  *  COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/cpukit/libcsupport/src/malloc_deferred.c b/cpukit/libcsupport/src/malloc_deferred.c
index b319d1213e..f8efe8ed22 100644
--- a/cpukit/libcsupport/src/malloc_deferred.c
+++ b/cpukit/libcsupport/src/malloc_deferred.c
@@ -1,3 +1,5 @@
  *  @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/malloc_dirtier.c b/cpukit/libcsupport/src/malloc_dirtier.c
index bff38e584c..173aedc889 100644
--- a/cpukit/libcsupport/src/malloc_dirtier.c
+++ b/cpukit/libcsupport/src/malloc_dirtier.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/malloc_p.h b/cpukit/libcsupport/src/malloc_p.h
index cb26050ff1..ac25cd31d1 100644
--- a/cpukit/libcsupport/src/malloc_p.h
+++ b/cpukit/libcsupport/src/malloc_p.h
@@ -1,12 +1,31 @@
  *  RTEMS Malloc Family Internal Header
+ * are met:
diff --git a/cpukit/libcsupport/src/malloc_walk.c b/cpukit/libcsupport/src/malloc_walk.c
index 9cd84346e3..a693ccc02b 100644
--- a/cpukit/libcsupport/src/malloc_walk.c
+++ b/cpukit/libcsupport/src/malloc_walk.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/mallocfreespace.c b/cpukit/libcsupport/src/mallocfreespace.c
index 7ba8f7d4d4..123c586e98 100644
--- a/cpukit/libcsupport/src/mallocfreespace.c
+++ b/cpukit/libcsupport/src/mallocfreespace.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/mallocgetheapptr.c b/cpukit/libcsupport/src/mallocgetheapptr.c
index 4b2f43c34f..299e1612f2 100644
--- a/cpukit/libcsupport/src/mallocgetheapptr.c
+++ b/cpukit/libcsupport/src/mallocgetheapptr.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/mallocinfo.c b/cpukit/libcsupport/src/mallocinfo.c
index 505dbb3374..d02e8a0017 100644
--- a/cpukit/libcsupport/src/mallocinfo.c
+++ b/cpukit/libcsupport/src/mallocinfo.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/mallocsetheapptr.c b/cpukit/libcsupport/src/mallocsetheapptr.c
index 74ab2593ea..496592e6b3 100644
--- a/cpukit/libcsupport/src/mallocsetheapptr.c
+++ b/cpukit/libcsupport/src/mallocsetheapptr.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/mkdir.c b/cpukit/libcsupport/src/mkdir.c
index c8ac131d90..3f7fad4321 100644
--- a/cpukit/libcsupport/src/mkdir.c
+++ b/cpukit/libcsupport/src/mkdir.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/mkfifo.c b/cpukit/libcsupport/src/mkfifo.c
index 11ad6e9fea..ac5d944898 100644
--- a/cpukit/libcsupport/src/mkfifo.c
+++ b/cpukit/libcsupport/src/mkfifo.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/mknod.c b/cpukit/libcsupport/src/mknod.c
index 24442e3396..cea3370374 100644
--- a/cpukit/libcsupport/src/mknod.c
+++ b/cpukit/libcsupport/src/mknod.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/mount-mgr.c b/cpukit/libcsupport/src/mount-mgr.c
index 065c2d5d69..1f0a2359d2 100644
--- a/cpukit/libcsupport/src/mount-mgr.c
+++ b/cpukit/libcsupport/src/mount-mgr.c
@@ -1,3 +1,5 @@
  *  mount()
@@ -8,9 +10,26 @@
  *  Copyright (c) 2010 embedded brains GmbH.
+ * are met:
diff --git a/cpukit/libcsupport/src/mount-mktgt.c b/cpukit/libcsupport/src/mount-mktgt.c
index a72984e070..adc26f4812 100644
--- a/cpukit/libcsupport/src/mount-mktgt.c
+++ b/cpukit/libcsupport/src/mount-mktgt.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2010 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/mount.c b/cpukit/libcsupport/src/mount.c
index a4f6423c03..e1fa8ce170 100644
--- a/cpukit/libcsupport/src/mount.c
+++ b/cpukit/libcsupport/src/mount.c
@@ -1,3 +1,5 @@
  *  @file
@@ -11,9 +13,26 @@
  *  Copyright (c) 2010-2012 embedded brains GmbH.
+ * are met:
diff --git a/cpukit/libcsupport/src/open.c b/cpukit/libcsupport/src/open.c
index 15cc7d562a..0053c6300f 100644
--- a/cpukit/libcsupport/src/open.c
+++ b/cpukit/libcsupport/src/open.c
@@ -1,3 +1,5 @@
  *  @file
@@ -12,9 +14,26 @@
  *  Modifications to support reference counting in the file system are
  *  Copyright (c) 2012 embedded brains GmbH.
+ * are met:
diff --git a/cpukit/libcsupport/src/open_dev_console.c b/cpukit/libcsupport/src/open_dev_console.c
index 405191d2c3..e5f34068fe 100644
--- a/cpukit/libcsupport/src/open_dev_console.c
+++ b/cpukit/libcsupport/src/open_dev_console.c
@@ -1,12 +1,34 @@
+ * @file
+ * @brief open_dev_console - open /dev/console
- *  open_dev_console - open /dev/console
+ * are met:
diff --git a/cpukit/libcsupport/src/pathconf.c b/cpukit/libcsupport/src/pathconf.c
index 2f232f8d01..ffa69bf2cf 100644
--- a/cpukit/libcsupport/src/pathconf.c
+++ b/cpukit/libcsupport/src/pathconf.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/posix_memalign.c b/cpukit/libcsupport/src/posix_memalign.c
index 418de99275..771eca1a62 100644
--- a/cpukit/libcsupport/src/posix_memalign.c
+++ b/cpukit/libcsupport/src/posix_memalign.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/print_fprintf.c b/cpukit/libcsupport/src/print_fprintf.c
index 251bfc3a14..f747931e32 100644
--- a/cpukit/libcsupport/src/print_fprintf.c
+++ b/cpukit/libcsupport/src/print_fprintf.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2016 Chris Johns <chrisj at rtems.org>
  * All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/print_printf.c b/cpukit/libcsupport/src/print_printf.c
index c817258b54..0972d22e56 100644
--- a/cpukit/libcsupport/src/print_printf.c
+++ b/cpukit/libcsupport/src/print_printf.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/printerfprintfputc.c b/cpukit/libcsupport/src/printerfprintfputc.c
index 23b224b56d..0c49b12d49 100644
--- a/cpukit/libcsupport/src/printerfprintfputc.c
+++ b/cpukit/libcsupport/src/printerfprintfputc.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/printertask.c b/cpukit/libcsupport/src/printertask.c
index 50b743b4ad..7ae24d7a37 100644
--- a/cpukit/libcsupport/src/printertask.c
+++ b/cpukit/libcsupport/src/printertask.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/printf_plugin.c b/cpukit/libcsupport/src/printf_plugin.c
index 34112a0e36..9d60fbb4a3 100644
--- a/cpukit/libcsupport/src/printf_plugin.c
+++ b/cpukit/libcsupport/src/printf_plugin.c
@@ -1,3 +1,5 @@
  *  @file
@@ -8,9 +10,26 @@
  * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/printk_plugin.c b/cpukit/libcsupport/src/printk_plugin.c
index 3ef3919732..caf89e9e06 100644
--- a/cpukit/libcsupport/src/printk_plugin.c
+++ b/cpukit/libcsupport/src/printk_plugin.c
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/privateenv.c b/cpukit/libcsupport/src/privateenv.c
index 05c2bfc1f8..6c6549c9ca 100644
--- a/cpukit/libcsupport/src/privateenv.c
+++ b/cpukit/libcsupport/src/privateenv.c
@@ -1,3 +1,5 @@
  *  @file
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/putk.c b/cpukit/libcsupport/src/putk.c
index 4407405a22..0ee938e3ba 100644
--- a/cpukit/libcsupport/src/putk.c
+++ b/cpukit/libcsupport/src/putk.c
@@ -1,3 +1,5 @@
  * @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/pwdgrp.h b/cpukit/libcsupport/src/pwdgrp.h
index b40696c594..bf0eee9424 100644
--- a/cpukit/libcsupport/src/pwdgrp.h
+++ b/cpukit/libcsupport/src/pwdgrp.h
@@ -1,9 +1,28 @@
  * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef _RTEMS_LIBCSUPPORT_PWDGRP_H
diff --git a/cpukit/libcsupport/src/read.c b/cpukit/libcsupport/src/read.c
index 2f317f48ca..396452cad8 100644
--- a/cpukit/libcsupport/src/read.c
+++ b/cpukit/libcsupport/src/read.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
  *  COPYRIGHT (c) 1989-2011.
+ * are met:
diff --git a/cpukit/libcsupport/src/readlink.c b/cpukit/libcsupport/src/readlink.c
index 0f2c46ee95..198c3b4103 100644
--- a/cpukit/libcsupport/src/readlink.c
+++ b/cpukit/libcsupport/src/readlink.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/readv.c b/cpukit/libcsupport/src/readv.c
index 65c02f75d5..b2b4511e51 100644
--- a/cpukit/libcsupport/src/readv.c
+++ b/cpukit/libcsupport/src/readv.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/realloc.c b/cpukit/libcsupport/src/realloc.c
index e28e3fbc33..6b165fc080 100644
--- a/cpukit/libcsupport/src/realloc.c
+++ b/cpukit/libcsupport/src/realloc.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index 1fde84985a..271d9193c5 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2012-2014 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/rmdir.c b/cpukit/libcsupport/src/rmdir.c
index 6e002c3923..7fe90e8c9d 100644
--- a/cpukit/libcsupport/src/rmdir.c
+++ b/cpukit/libcsupport/src/rmdir.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/rtems_heap_extend.c b/cpukit/libcsupport/src/rtems_heap_extend.c
index 068c15983b..d67989fba0 100644
--- a/cpukit/libcsupport/src/rtems_heap_extend.c
+++ b/cpukit/libcsupport/src/rtems_heap_extend.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2011 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c b/cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c
index 8c50883cc7..3061d9318d 100644
--- a/cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c
+++ b/cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c
@@ -1,3 +1,5 @@
  *  @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/rtems_heap_greedy.c b/cpukit/libcsupport/src/rtems_heap_greedy.c
index 639feb6761..9a4c52bc7b 100644
--- a/cpukit/libcsupport/src/rtems_heap_greedy.c
+++ b/cpukit/libcsupport/src/rtems_heap_greedy.c
@@ -1,3 +1,5 @@
  *  @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/rtems_heap_null_extend.c b/cpukit/libcsupport/src/rtems_heap_null_extend.c
index 63e7b4af73..947d3f4c04 100644
--- a/cpukit/libcsupport/src/rtems_heap_null_extend.c
+++ b/cpukit/libcsupport/src/rtems_heap_null_extend.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/rtems_memalign.c b/cpukit/libcsupport/src/rtems_memalign.c
index aa67c74a29..7b67c73b55 100644
--- a/cpukit/libcsupport/src/rtems_memalign.c
+++ b/cpukit/libcsupport/src/rtems_memalign.c
@@ -1,3 +1,5 @@
  *  @file
@@ -9,9 +11,26 @@
+ * are met:
2.24.4
