[PATCH 4/7] cpukit/libcsupport/src/[a-f]*: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Wed Mar 30 22:45:27 UTC 2022
Updates #3053.
cpukit/libcsupport/src/access.c | 25 ++++++++++++--
.../src/arc4random_getentropy_fail.c | 25 ++++++++++++--
cpukit/libcsupport/src/assoc32tostring.c | 25 ++++++++++++--
cpukit/libcsupport/src/assoclocalbyname.c | 25 ++++++++++++--
.../src/assocremotebylocalbitfield.c | 25 ++++++++++++--
.../src/assocthreadstatestostring.c | 25 ++++++++++++--
cpukit/libcsupport/src/base_fs.c | 25 ++++++++++++--
cpukit/libcsupport/src/cachealignedalloc.c | 33 +++++++++++++++----
cpukit/libcsupport/src/cachecoherentalloc.c | 25 ++++++++++++--
cpukit/libcsupport/src/calloc.c | 25 ++++++++++++--
cpukit/libcsupport/src/cfgetispeed.c | 25 ++++++++++++--
cpukit/libcsupport/src/cfgetospeed.c | 25 ++++++++++++--
cpukit/libcsupport/src/cfsetispeed.c | 25 ++++++++++++--
cpukit/libcsupport/src/cfsetospeed.c | 25 ++++++++++++--
cpukit/libcsupport/src/cfsetspeed.c | 25 ++++++++++++--
cpukit/libcsupport/src/chdir.c | 25 ++++++++++++--
cpukit/libcsupport/src/chmod.c | 25 ++++++++++++--
cpukit/libcsupport/src/chown.c | 25 ++++++++++++--
cpukit/libcsupport/src/chroot.c | 25 ++++++++++++--
cpukit/libcsupport/src/clock.c | 25 ++++++++++++--
cpukit/libcsupport/src/clonenode.c | 25 ++++++++++++--
cpukit/libcsupport/src/close.c | 25 ++++++++++++--
cpukit/libcsupport/src/consolesimple.h | 25 ++++++++++++--
cpukit/libcsupport/src/consolesimpleread.c | 25 ++++++++++++--
cpukit/libcsupport/src/ctermid.c | 25 ++++++++++++--
cpukit/libcsupport/src/dup.c | 25 ++++++++++++--
cpukit/libcsupport/src/dup2.c | 25 ++++++++++++--
cpukit/libcsupport/src/fchdir.c | 25 ++++++++++++--
cpukit/libcsupport/src/fchmod.c | 25 ++++++++++++--
cpukit/libcsupport/src/fchown.c | 25 ++++++++++++--
cpukit/libcsupport/src/fcntl.c | 25 ++++++++++++--
cpukit/libcsupport/src/fdatasync.c | 25 ++++++++++++--
cpukit/libcsupport/src/fpathconf.c | 25 ++++++++++++--
cpukit/libcsupport/src/free.c | 25 ++++++++++++--
cpukit/libcsupport/src/freenode.c | 25 ++++++++++++--
cpukit/libcsupport/src/fstat.c | 25 ++++++++++++--
cpukit/libcsupport/src/fsync.c | 25 ++++++++++++--
cpukit/libcsupport/src/ftruncate.c | 25 ++++++++++++--
38 files changed, 841 insertions(+), 117 deletions(-)
diff --git a/cpukit/libcsupport/src/access.c b/cpukit/libcsupport/src/access.c
index 57276305ac..15d913f4c2 100644
--- a/cpukit/libcsupport/src/access.c
+++ b/cpukit/libcsupport/src/access.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-1999.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/libcsupport/src/arc4random_getentropy_fail.c b/cpukit/libcsupport/src/arc4random_getentropy_fail.c
index 8670064126..16b1e6b9a2 100644
--- a/cpukit/libcsupport/src/arc4random_getentropy_fail.c
+++ b/cpukit/libcsupport/src/arc4random_getentropy_fail.c
@@ -1,9 +1,28 @@
* Copyright (c) 2017 embedded brains GmbH. All rights reserved.
+ * are met:
#include <machine/_arc4random.h>
diff --git a/cpukit/libcsupport/src/assoc32tostring.c b/cpukit/libcsupport/src/assoc32tostring.c
index 3fac292360..7b7856342c 100644
--- a/cpukit/libcsupport/src/assoc32tostring.c
+++ b/cpukit/libcsupport/src/assoc32tostring.c
@@ -1,9 +1,28 @@
* Copyright (c) 2016 embedded brains GmbH.
+ * are met:
diff --git a/cpukit/libcsupport/src/assoclocalbyname.c b/cpukit/libcsupport/src/assoclocalbyname.c
index c0267f3f53..304d5f723c 100644
--- a/cpukit/libcsupport/src/assoclocalbyname.c
+++ b/cpukit/libcsupport/src/assoclocalbyname.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2008.
+ * are met:
diff --git a/cpukit/libcsupport/src/assocremotebylocalbitfield.c b/cpukit/libcsupport/src/assocremotebylocalbitfield.c
index 4a9cc0b175..a5fcc711b2 100644
--- a/cpukit/libcsupport/src/assocremotebylocalbitfield.c
+++ b/cpukit/libcsupport/src/assocremotebylocalbitfield.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/assocthreadstatestostring.c b/cpukit/libcsupport/src/assocthreadstatestostring.c
index cd1b72d7ab..19aae4b8d8 100644
--- a/cpukit/libcsupport/src/assocthreadstatestostring.c
+++ b/cpukit/libcsupport/src/assocthreadstatestostring.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/base_fs.c b/cpukit/libcsupport/src/base_fs.c
index 0eb4c35293..c596b12d04 100644
--- a/cpukit/libcsupport/src/base_fs.c
+++ b/cpukit/libcsupport/src/base_fs.c
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* Modifications to support reference counting in the file system are
* Copyright (c) 2012 embedded brains GmbH.
+ * are met:
diff --git a/cpukit/libcsupport/src/cachealignedalloc.c b/cpukit/libcsupport/src/cachealignedalloc.c
index 764fdfb331..4acfab80c6 100644
--- a/cpukit/libcsupport/src/cachealignedalloc.c
+++ b/cpukit/libcsupport/src/cachealignedalloc.c
@@ -1,13 +1,34 @@
+ * @file
+ * @brief RTEMS Cache Aligned Malloc
- * RTEMS Cache Aligned Malloc
+ * are met:
diff --git a/cpukit/libcsupport/src/cachecoherentalloc.c b/cpukit/libcsupport/src/cachecoherentalloc.c
index 16275c061a..bcf557a92c 100644
--- a/cpukit/libcsupport/src/cachecoherentalloc.c
+++ b/cpukit/libcsupport/src/cachecoherentalloc.c
@@ -1,3 +1,5 @@
* @file
@@ -7,9 +9,26 @@
* Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/calloc.c b/cpukit/libcsupport/src/calloc.c
index d5cefb382a..59a6ae9d3f 100644
--- a/cpukit/libcsupport/src/calloc.c
+++ b/cpukit/libcsupport/src/calloc.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-2014.
+ * are met:
diff --git a/cpukit/libcsupport/src/cfgetispeed.c b/cpukit/libcsupport/src/cfgetispeed.c
index 050991d468..d857be0cde 100644
--- a/cpukit/libcsupport/src/cfgetispeed.c
+++ b/cpukit/libcsupport/src/cfgetispeed.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/cfgetospeed.c b/cpukit/libcsupport/src/cfgetospeed.c
index ac44b6de72..5e6403d9de 100644
--- a/cpukit/libcsupport/src/cfgetospeed.c
+++ b/cpukit/libcsupport/src/cfgetospeed.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/cfsetispeed.c b/cpukit/libcsupport/src/cfsetispeed.c
index e46036d24e..47b715a304 100644
--- a/cpukit/libcsupport/src/cfsetispeed.c
+++ b/cpukit/libcsupport/src/cfsetispeed.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/cfsetospeed.c b/cpukit/libcsupport/src/cfsetospeed.c
index a85e2c1cfd..d07922af4b 100644
--- a/cpukit/libcsupport/src/cfsetospeed.c
+++ b/cpukit/libcsupport/src/cfsetospeed.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/cfsetspeed.c b/cpukit/libcsupport/src/cfsetspeed.c
index f3d73ed755..16940e1174 100644
--- a/cpukit/libcsupport/src/cfsetspeed.c
+++ b/cpukit/libcsupport/src/cfsetspeed.c
@@ -1,3 +1,5 @@
/* @file
* @brief Baud Rate Functions
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/chdir.c b/cpukit/libcsupport/src/chdir.c
index 6ef551f06d..259987c0df 100644
--- a/cpukit/libcsupport/src/chdir.c
+++ b/cpukit/libcsupport/src/chdir.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/chmod.c b/cpukit/libcsupport/src/chmod.c
index b53a407d72..e387b79ca9 100644
--- a/cpukit/libcsupport/src/chmod.c
+++ b/cpukit/libcsupport/src/chmod.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/chown.c b/cpukit/libcsupport/src/chown.c
index 45d041f812..5c9c0aa5ca 100644
--- a/cpukit/libcsupport/src/chown.c
+++ b/cpukit/libcsupport/src/chown.c
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/chroot.c b/cpukit/libcsupport/src/chroot.c
index 9db340174b..fc0f3f92ed 100644
--- a/cpukit/libcsupport/src/chroot.c
+++ b/cpukit/libcsupport/src/chroot.c
@@ -1,3 +1,5 @@
* @file
@@ -15,9 +17,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/clock.c b/cpukit/libcsupport/src/clock.c
index f6c92fa5ab..f9cb693132 100644
--- a/cpukit/libcsupport/src/clock.c
+++ b/cpukit/libcsupport/src/clock.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/clonenode.c b/cpukit/libcsupport/src/clonenode.c
index e943fc4c59..1b94401642 100644
--- a/cpukit/libcsupport/src/clonenode.c
+++ b/cpukit/libcsupport/src/clonenode.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/cpukit/libcsupport/src/close.c b/cpukit/libcsupport/src/close.c
index 5e6aa2c041..5a6fb30163 100644
--- a/cpukit/libcsupport/src/close.c
+++ b/cpukit/libcsupport/src/close.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/consolesimple.h b/cpukit/libcsupport/src/consolesimple.h
index ba1c1eb220..659ec2f4f7 100644
--- a/cpukit/libcsupport/src/consolesimple.h
+++ b/cpukit/libcsupport/src/consolesimple.h
@@ -1,9 +1,28 @@
* Copyright (c) 2018 embedded brains GmbH. All rights reserved.
+ * are met:
ssize_t _Console_simple_Read(
diff --git a/cpukit/libcsupport/src/consolesimpleread.c b/cpukit/libcsupport/src/consolesimpleread.c
index ec5ca5491f..29a61f3696 100644
--- a/cpukit/libcsupport/src/consolesimpleread.c
+++ b/cpukit/libcsupport/src/consolesimpleread.c
@@ -1,9 +1,28 @@
+ * are met:
#include <rtems/bspIo.h>
diff --git a/cpukit/libcsupport/src/ctermid.c b/cpukit/libcsupport/src/ctermid.c
index 56dda553a9..2f53d0ed50 100644
--- a/cpukit/libcsupport/src/ctermid.c
+++ b/cpukit/libcsupport/src/ctermid.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-2010.
+ * are met:
diff --git a/cpukit/libcsupport/src/dup.c b/cpukit/libcsupport/src/dup.c
index 8fe2514c7d..50c56d796e 100644
--- a/cpukit/libcsupport/src/dup.c
+++ b/cpukit/libcsupport/src/dup.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/dup2.c b/cpukit/libcsupport/src/dup2.c
index 020d9a350f..9206aae6e0 100644
--- a/cpukit/libcsupport/src/dup2.c
+++ b/cpukit/libcsupport/src/dup2.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/fchdir.c b/cpukit/libcsupport/src/fchdir.c
index f6ff0bdda0..861beb04ce 100644
--- a/cpukit/libcsupport/src/fchdir.c
+++ b/cpukit/libcsupport/src/fchdir.c
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/fchmod.c b/cpukit/libcsupport/src/fchmod.c
index 35c058c19d..bc3d71f96a 100644
--- a/cpukit/libcsupport/src/fchmod.c
+++ b/cpukit/libcsupport/src/fchmod.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
diff --git a/cpukit/libcsupport/src/fchown.c b/cpukit/libcsupport/src/fchown.c
index 0d5597cca3..f0c9d2b23e 100644
--- a/cpukit/libcsupport/src/fchown.c
+++ b/cpukit/libcsupport/src/fchown.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/fcntl.c b/cpukit/libcsupport/src/fcntl.c
index ba824dced1..d070c07613 100644
--- a/cpukit/libcsupport/src/fcntl.c
+++ b/cpukit/libcsupport/src/fcntl.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/fdatasync.c b/cpukit/libcsupport/src/fdatasync.c
index a1ac7bc81e..a2cd2540e1 100644
--- a/cpukit/libcsupport/src/fdatasync.c
+++ b/cpukit/libcsupport/src/fdatasync.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/fpathconf.c b/cpukit/libcsupport/src/fpathconf.c
index d081012ba9..471505bf07 100644
--- a/cpukit/libcsupport/src/fpathconf.c
+++ b/cpukit/libcsupport/src/fpathconf.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/free.c b/cpukit/libcsupport/src/free.c
index 9f7c577852..c5716b214e 100644
--- a/cpukit/libcsupport/src/free.c
+++ b/cpukit/libcsupport/src/free.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2007.
+ * are met:
diff --git a/cpukit/libcsupport/src/freenode.c b/cpukit/libcsupport/src/freenode.c
index 228fd9036a..88e7e8df8b 100644
--- a/cpukit/libcsupport/src/freenode.c
+++ b/cpukit/libcsupport/src/freenode.c
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/fstat.c b/cpukit/libcsupport/src/fstat.c
index 0cdec6d1eb..56f8f84624 100644
--- a/cpukit/libcsupport/src/fstat.c
+++ b/cpukit/libcsupport/src/fstat.c
@@ -1,12 +1,31 @@
* fstat() - POSIX 1003.1b 5.6.2 - Get File Status
+ * are met:
diff --git a/cpukit/libcsupport/src/fsync.c b/cpukit/libcsupport/src/fsync.c
index 8a427390c2..a145d0b1b7 100644
--- a/cpukit/libcsupport/src/fsync.c
+++ b/cpukit/libcsupport/src/fsync.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
diff --git a/cpukit/libcsupport/src/ftruncate.c b/cpukit/libcsupport/src/ftruncate.c
index 6383bfe398..99c9046df7 100644
--- a/cpukit/libcsupport/src/ftruncate.c
+++ b/cpukit/libcsupport/src/ftruncate.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
+ * are met:
2.24.4
