GCC version for RTEMS 6?
Wed May 4 10:57:40 UTC 2022
On 04/05/2022 09:11, Chris Johns wrote:
>> I updated the RTEMS 7 tools to use the GCC 12 release branch with a gcov back
>> port. You can test GCC 12 with a local patch for RTEMS 6:
>> diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
>> index 731c9d8..381f916 100644
>> --- a/rtems/config/6/rtems-default.bset
>> +++ b/rtems/config/6/rtems-default.bset
>> @@ -15,5 +15,5 @@ devel/gmp-6.2.1
>>   tools/rtems-gdb-11.2
>>   tools/rtems-binutils-2.38
>> -tools/rtems-gcc-10-newlib-head
>> +tools/rtems-gcc-head-newlib-head
>>   tools/rtems-tools-6
> Ah ok and thanks. I will take a look and report back. It will take a couple of
> days for me to work through this.
Ok, thanks.
> It would be nice to be able to handle this without changing anything.
I can commit this change if it helps.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
