GCC version for RTEMS 6?
Wed May 4 23:32:02 UTC 2022
On 4/5/2022 8:57 pm, Sebastian Huber wrote:
> On 04/05/2022 09:11, Chris Johns wrote:
>>> I updated the RTEMS 7 tools to use the GCC 12 release branch with a gcov back
>>> port. You can test GCC 12 with a local patch for RTEMS 6:
>>> diff --git a/rtems/config/6/rtems-default.bset
>>> b/rtems/config/6/rtems-default.bset
>>> index 731c9d8..381f916 100644
>>> --- a/rtems/config/6/rtems-default.bset
>>> +++ b/rtems/config/6/rtems-default.bset
>>> @@ -15,5 +15,5 @@ devel/gmp-6.2.1
>>>   tools/rtems-gdb-11.2
>>>   tools/rtems-binutils-2.38
>>> -tools/rtems-gcc-10-newlib-head
>>> +tools/rtems-gcc-head-newlib-head
>>>   tools/rtems-tools-6
>> Ah ok and thanks. I will take a look and report back. It will take a couple of
>> days for me to work through this.
> Ok, thanks.
>> It would be nice to be able to handle this without changing anything.
> I can commit this change if it helps.
This assumes it is ok and I prefer we get posted test results before such a
change. Until we have this we need to wait until we all each do a level of
testing we are happy with. A solution that lets us test would steam line this.
I think this is a use case where something added to the RSB may be required to
make this easier. For example logic in a bset file would be nice.
