[PATCH 1/3] 6.1: make as verbatim copy of files in 6
Karel Gardas
karel at functional.vision
Thu May 5 09:05:04 UTC 2022
rtems/config/6.1/rtems-aarch64.bset | 4 ++++
rtems/config/6.1/rtems-all.bset | 18 ++++++++++++++++++
rtems/config/6.1/rtems-arm.bset | 4 ++++
rtems/config/6.1/rtems-base.bset | 13 +++++++++++++
rtems/config/6.1/rtems-bfin.bset | 3 +++
rtems/config/6.1/rtems-default.bset | 19 +++++++++++++++++++
rtems/config/6.1/rtems-i386.bset | 4 ++++
rtems/config/6.1/rtems-kernel.bset | 15 +++++++++++++++
rtems/config/6.1/rtems-libbsd.bset | 8 ++++++++
rtems/config/6.1/rtems-llvm.bset | 21 +++++++++++++++++++++
rtems/config/6.1/rtems-lm32.bset | 3 +++
rtems/config/6.1/rtems-m68k.bset | 3 +++
rtems/config/6.1/rtems-microblaze.bset | 20 ++++++++++++++++++++
rtems/config/6.1/rtems-mips.bset | 6 ++++++
rtems/config/6.1/rtems-moxie.bset | 5 +++++
rtems/config/6.1/rtems-net-legacy.bset | 4 ++++
rtems/config/6.1/rtems-nios2.bset | 3 +++
rtems/config/6.1/rtems-or1k.bset | 3 +++
rtems/config/6.1/rtems-packages.bset | 24 ++++++++++++++++++++++++
rtems/config/6.1/rtems-powerpc.bset | 4 ++++
rtems/config/6.1/rtems-riscv.bset | 5 +++++
rtems/config/6.1/rtems-sh.bset | 3 +++
rtems/config/6.1/rtems-sparc.bset | 6 ++++++
rtems/config/6.1/rtems-sparc64.bset | 3 +++
rtems/config/6.1/rtems-tools.bset | 17 +++++++++++++++++
rtems/config/6.1/rtems-v850.bset | 3 +++
rtems/config/6.1/rtems-x86_64.bset | 9 +++++++++
27 files changed, 230 insertions(+)
create mode 100644 rtems/config/6.1/rtems-aarch64.bset
create mode 100644 rtems/config/6.1/rtems-all.bset
create mode 100644 rtems/config/6.1/rtems-arm.bset
create mode 100644 rtems/config/6.1/rtems-base.bset
create mode 100644 rtems/config/6.1/rtems-bfin.bset
create mode 100644 rtems/config/6.1/rtems-default.bset
create mode 100644 rtems/config/6.1/rtems-i386.bset
create mode 100644 rtems/config/6.1/rtems-kernel.bset
create mode 100644 rtems/config/6.1/rtems-libbsd.bset
create mode 100644 rtems/config/6.1/rtems-llvm.bset
create mode 100644 rtems/config/6.1/rtems-lm32.bset
create mode 100644 rtems/config/6.1/rtems-m68k.bset
create mode 100644 rtems/config/6.1/rtems-microblaze.bset
create mode 100644 rtems/config/6.1/rtems-mips.bset
create mode 100644 rtems/config/6.1/rtems-moxie.bset
create mode 100644 rtems/config/6.1/rtems-net-legacy.bset
create mode 100644 rtems/config/6.1/rtems-nios2.bset
create mode 100644 rtems/config/6.1/rtems-or1k.bset
create mode 100644 rtems/config/6.1/rtems-packages.bset
create mode 100644 rtems/config/6.1/rtems-powerpc.bset
create mode 100644 rtems/config/6.1/rtems-riscv.bset
create mode 100644 rtems/config/6.1/rtems-sh.bset
create mode 100644 rtems/config/6.1/rtems-sparc.bset
create mode 100644 rtems/config/6.1/rtems-sparc64.bset
create mode 100644 rtems/config/6.1/rtems-tools.bset
create mode 100644 rtems/config/6.1/rtems-v850.bset
create mode 100644 rtems/config/6.1/rtems-x86_64.bset
diff --git a/rtems/config/6.1/rtems-aarch64.bset b/rtems/config/6.1/rtems-aarch64.bset
new file mode 100644
index 0000000..e3c91af
--- /dev/null
+++ b/rtems/config/6.1/rtems-aarch64.bset
@@ -0,0 +1,4 @@
+%define release 1
+%define rtems_arch aarch64
+%define with_libgomp
+%include 6/rtems-default.bset
diff --git a/rtems/config/6.1/rtems-all.bset b/rtems/config/6.1/rtems-all.bset
index 0000000..2503f2a
--- /dev/null
+++ b/rtems/config/6.1/rtems-all.bset
@@ -0,0 +1,18 @@
+6/rtems-aarch64
+6/rtems-arm
+6/rtems-bfin
+6/rtems-i386
+6/rtems-lm32
+6/rtems-m68k
+6/rtems-microblaze
+6/rtems-mips
+6/rtems-moxie
+6/rtems-nios2
+6/rtems-or1k
+6/rtems-powerpc
+6/rtems-riscv
+6/rtems-sh
+6/rtems-sparc
+6/rtems-sparc64
+6/rtems-v850
+6/rtems-x86_64
diff --git a/rtems/config/6.1/rtems-arm.bset b/rtems/config/6.1/rtems-arm.bset
index 0000000..425d66b
--- /dev/null
+++ b/rtems/config/6.1/rtems-arm.bset
@@ -0,0 +1,4 @@
+%define release 1
+%define rtems_arch arm
diff --git a/rtems/config/6.1/rtems-base.bset b/rtems/config/6.1/rtems-base.bset
index 0000000..ba394ef
--- /dev/null
+++ b/rtems/config/6.1/rtems-base.bset
@@ -0,0 +1,13 @@
+%define rtems_version 6
+%define _target %{rtems_arch}-rtems%{rtems_version}
+%define gcc_version_message RTEMS %{rtems_version}, RSB %{_sbgit_id}, Newlib %{newlib_version}
+%include rtems-urls.bset
+%ifos win32 mingw ming32
+ %define rtems_waf_build_root_suffix %{waf_build_root_suffix}
+%else
+ %define rtems_waf_build_root_suffix %{nil}
+%endif
+package: rtems-%{rtems_version}-%{_target}-%{_host}-%{release}
diff --git a/rtems/config/6.1/rtems-bfin.bset b/rtems/config/6.1/rtems-bfin.bset
index 0000000..12a215e
--- /dev/null
+++ b/rtems/config/6.1/rtems-bfin.bset
@@ -0,0 +1,3 @@
+%define release 1
+%define rtems_arch bfin
diff --git a/rtems/config/6.1/rtems-default.bset b/rtems/config/6.1/rtems-default.bset
index 0000000..731c9d8
--- /dev/null
+++ b/rtems/config/6.1/rtems-default.bset
@@ -0,0 +1,19 @@
+# Default tools configuration.
+%include 6/rtems-base.bset
+# Build gdb first to raise the Python install error as early as possible.
+# GDB needs expat so it needs to be built before.
+devel/dtc-1.6.1-1
+devel/expat-2.4.8-1
+devel/gmp-6.2.1
+tools/rtems-gdb-11.2
+tools/rtems-binutils-2.38
+tools/rtems-gcc-10-newlib-head
+tools/rtems-tools-6
diff --git a/rtems/config/6.1/rtems-i386.bset b/rtems/config/6.1/rtems-i386.bset
index 0000000..a27319d
--- /dev/null
+++ b/rtems/config/6.1/rtems-i386.bset
@@ -0,0 +1,4 @@
+%define release 1
+%define rtems_arch i386
diff --git a/rtems/config/6.1/rtems-kernel.bset b/rtems/config/6.1/rtems-kernel.bset
index 0000000..e3402f6
--- /dev/null
+++ b/rtems/config/6.1/rtems-kernel.bset
@@ -0,0 +1,15 @@
+# RTEMS Kernel configuration.
+%define release 1
+# The RTEMS version and URLs
+%include rtems-version.bset
+# Build the kernel.
+tools/rtems-kernel-6
diff --git a/rtems/config/6.1/rtems-libbsd.bset b/rtems/config/6.1/rtems-libbsd.bset
index 0000000..3d779bc
--- /dev/null
+++ b/rtems/config/6.1/rtems-libbsd.bset
@@ -0,0 +1,8 @@
+# RTEMS LibBSD configuration.
+# Build the BSD library for RTEMS.
+tools/rtems-libbsd-6
diff --git a/rtems/config/6.1/rtems-llvm.bset b/rtems/config/6.1/rtems-llvm.bset
index 0000000..2b461a0
--- /dev/null
+++ b/rtems/config/6.1/rtems-llvm.bset
@@ -0,0 +1,21 @@
+# LLVM for RTEMS 5 Tools Stable
+%define release 1
+%define rtems_arch none
+# The RTEMS base defines.
+%include rtems-base.bset
+# Build and install into a prefix that is away from the staged area or it will
+# be installed.
+%define swig_prefix %{_tmproot}/swig
+devel/swig
+tools/rtems-llvm-8.0.1
diff --git a/rtems/config/6.1/rtems-lm32.bset b/rtems/config/6.1/rtems-lm32.bset
index 0000000..b5afad1
--- /dev/null
+++ b/rtems/config/6.1/rtems-lm32.bset
@@ -0,0 +1,3 @@
+%define release 1
+%define rtems_arch lm32
diff --git a/rtems/config/6.1/rtems-m68k.bset b/rtems/config/6.1/rtems-m68k.bset
index 0000000..0932d20
--- /dev/null
+++ b/rtems/config/6.1/rtems-m68k.bset
@@ -0,0 +1,3 @@
+%define release 1
+%define rtems_arch m68k
diff --git a/rtems/config/6.1/rtems-microblaze.bset b/rtems/config/6.1/rtems-microblaze.bset
index 0000000..ea59313
--- /dev/null
+++ b/rtems/config/6.1/rtems-microblaze.bset
@@ -0,0 +1,20 @@
+%define release 1
+%define rtems_arch microblaze
+devel/gmp-6.2.1
+tools/rtems-xilinx-binutils-2.36
+tools/rtems-xilinx-gcc-10-newlib-head
diff --git a/rtems/config/6.1/rtems-mips.bset b/rtems/config/6.1/rtems-mips.bset
index 0000000..48771f3
--- /dev/null
+++ b/rtems/config/6.1/rtems-mips.bset
@@ -0,0 +1,6 @@
+%define release 1
+%define rtems_arch mips
+%define gdb-sim-options --enable-sim-hardware
+%define win32-gdb-disable-sim
+tools/rtems-mipstx39-gdb-11.2
diff --git a/rtems/config/6.1/rtems-moxie.bset b/rtems/config/6.1/rtems-moxie.bset
index 0000000..c86777e
--- /dev/null
+++ b/rtems/config/6.1/rtems-moxie.bset
@@ -0,0 +1,5 @@
+%define release 1
+%define rtems_arch moxie
diff --git a/rtems/config/6.1/rtems-net-legacy.bset b/rtems/config/6.1/rtems-net-legacy.bset
index 0000000..424091c
--- /dev/null
+++ b/rtems/config/6.1/rtems-net-legacy.bset
@@ -0,0 +1,4 @@
+# Legacy networking stack
+tools/rtems-net-legacy-6
diff --git a/rtems/config/6.1/rtems-nios2.bset b/rtems/config/6.1/rtems-nios2.bset
index 0000000..522eff5
--- /dev/null
+++ b/rtems/config/6.1/rtems-nios2.bset
@@ -0,0 +1,3 @@
+%define release 1
+%define rtems_arch nios2
diff --git a/rtems/config/6.1/rtems-or1k.bset b/rtems/config/6.1/rtems-or1k.bset
index 0000000..c299c25
--- /dev/null
+++ b/rtems/config/6.1/rtems-or1k.bset
@@ -0,0 +1,3 @@
+%define release 1
+%define rtems_arch or1k
diff --git a/rtems/config/6.1/rtems-packages.bset b/rtems/config/6.1/rtems-packages.bset
index 0000000..edc7e6b
--- /dev/null
+++ b/rtems/config/6.1/rtems-packages.bset
@@ -0,0 +1,24 @@
+# RTEMS Packages that build for this release.
+# Databases
+databases/sqlite
+# Graphics
+graphics/freetype2
+graphics/libjpeg
+graphics/libpng
+graphics/libtiff
+graphics/t1lib
+# Networking
+ftp/curl
+net/lwip
+net/protobuf
diff --git a/rtems/config/6.1/rtems-powerpc.bset b/rtems/config/6.1/rtems-powerpc.bset
index 0000000..c19327a
--- /dev/null
+++ b/rtems/config/6.1/rtems-powerpc.bset
@@ -0,0 +1,4 @@
+%define release 1
+%define rtems_arch powerpc
diff --git a/rtems/config/6.1/rtems-riscv.bset b/rtems/config/6.1/rtems-riscv.bset
index 0000000..ad7cb5b
--- /dev/null
+++ b/rtems/config/6.1/rtems-riscv.bset
@@ -0,0 +1,5 @@
+%define release 1
+%define rtems_arch riscv
+devel/sis-2-1
diff --git a/rtems/config/6.1/rtems-sh.bset b/rtems/config/6.1/rtems-sh.bset
index 0000000..f867962
--- /dev/null
+++ b/rtems/config/6.1/rtems-sh.bset
@@ -0,0 +1,3 @@
+%define release 1
+%define rtems_arch sh
diff --git a/rtems/config/6.1/rtems-sparc.bset b/rtems/config/6.1/rtems-sparc.bset
index 0000000..48d152d
--- /dev/null
+++ b/rtems/config/6.1/rtems-sparc.bset
@@ -0,0 +1,6 @@
+%define release 1
+%define rtems_arch sparc
+%define gdb-disable-sim 1
+devel/sis-2-1
diff --git a/rtems/config/6.1/rtems-sparc64.bset b/rtems/config/6.1/rtems-sparc64.bset
index 0000000..8da80a6
--- /dev/null
+++ b/rtems/config/6.1/rtems-sparc64.bset
@@ -0,0 +1,3 @@
+%define release 1
+%define rtems_arch sparc64
diff --git a/rtems/config/6.1/rtems-tools.bset b/rtems/config/6.1/rtems-tools.bset
index 0000000..20e2199
--- /dev/null
+++ b/rtems/config/6.1/rtems-tools.bset
@@ -0,0 +1,17 @@
+# Tools Set for RTEMS 6 Tools Stable
+%define release 1
+# We need an arch defined for the common RTEMS files to work.
+%define rtems_arch tools
diff --git a/rtems/config/6.1/rtems-v850.bset b/rtems/config/6.1/rtems-v850.bset
index 0000000..dd68147
--- /dev/null
+++ b/rtems/config/6.1/rtems-v850.bset
@@ -0,0 +1,3 @@
+%define release 1
+%define rtems_arch v850
diff --git a/rtems/config/6.1/rtems-x86_64.bset b/rtems/config/6.1/rtems-x86_64.bset
index 0000000..088c9f5
--- /dev/null
+++ b/rtems/config/6.1/rtems-x86_64.bset
@@ -0,0 +1,9 @@
+%define release 1
+%define rtems_arch x86_64
+%define grub2_platform efi
+%define grub2_target x86_64
+tools/rtems-grub-2.06
2.25.1
