[PATCH 2/3] 6.1: update 6 references to 6.1
Karel Gardas
karel at functional.vision
Thu May 5 09:05:05 UTC 2022
rtems/config/6.1/rtems-aarch64.bset | 2 +-
rtems/config/6.1/rtems-arm.bset | 2 +-
rtems/config/6.1/rtems-bfin.bset | 2 +-
rtems/config/6.1/rtems-default.bset | 2 +-
rtems/config/6.1/rtems-i386.bset | 2 +-
rtems/config/6.1/rtems-lm32.bset | 2 +-
rtems/config/6.1/rtems-m68k.bset | 2 +-
rtems/config/6.1/rtems-microblaze.bset | 2 +-
rtems/config/6.1/rtems-mips.bset | 2 +-
rtems/config/6.1/rtems-moxie.bset | 2 +-
rtems/config/6.1/rtems-nios2.bset | 2 +-
rtems/config/6.1/rtems-or1k.bset | 2 +-
rtems/config/6.1/rtems-powerpc.bset | 2 +-
rtems/config/6.1/rtems-riscv.bset | 2 +-
rtems/config/6.1/rtems-sh.bset | 2 +-
rtems/config/6.1/rtems-sparc.bset | 2 +-
rtems/config/6.1/rtems-sparc64.bset | 2 +-
rtems/config/6.1/rtems-v850.bset | 2 +-
rtems/config/6.1/rtems-x86_64.bset | 2 +-
19 files changed, 19 insertions(+), 19 deletions(-)
diff --git a/rtems/config/6.1/rtems-aarch64.bset b/rtems/config/6.1/rtems-aarch64.bset
index e3c91af..bb66d70 100644
--- a/rtems/config/6.1/rtems-aarch64.bset
+++ b/rtems/config/6.1/rtems-aarch64.bset
@@ -1,4 +1,4 @@
%define release 1
%define rtems_arch aarch64
%define with_libgomp
-%include 6/rtems-default.bset
+%include 6.1/rtems-default.bset
diff --git a/rtems/config/6.1/rtems-arm.bset b/rtems/config/6.1/rtems-arm.bset
index 425d66b..030f713 100644
--- a/rtems/config/6.1/rtems-arm.bset
+++ b/rtems/config/6.1/rtems-arm.bset
@@ -1,4 +1,4 @@
%define release 1
%define rtems_arch arm
diff --git a/rtems/config/6.1/rtems-bfin.bset b/rtems/config/6.1/rtems-bfin.bset
index 12a215e..a308a69 100644
--- a/rtems/config/6.1/rtems-bfin.bset
+++ b/rtems/config/6.1/rtems-bfin.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch bfin
diff --git a/rtems/config/6.1/rtems-default.bset b/rtems/config/6.1/rtems-default.bset
index 731c9d8..1d03dc4 100644
--- a/rtems/config/6.1/rtems-default.bset
+++ b/rtems/config/6.1/rtems-default.bset
@@ -1,7 +1,7 @@
# Default tools configuration.
-%include 6/rtems-base.bset
+%include 6.1/rtems-base.bset
# Build gdb first to raise the Python install error as early as possible.
diff --git a/rtems/config/6.1/rtems-i386.bset b/rtems/config/6.1/rtems-i386.bset
index a27319d..d236627 100644
--- a/rtems/config/6.1/rtems-i386.bset
+++ b/rtems/config/6.1/rtems-i386.bset
@@ -1,4 +1,4 @@
%define release 1
%define rtems_arch i386
diff --git a/rtems/config/6.1/rtems-lm32.bset b/rtems/config/6.1/rtems-lm32.bset
index b5afad1..476bc10 100644
--- a/rtems/config/6.1/rtems-lm32.bset
+++ b/rtems/config/6.1/rtems-lm32.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch lm32
diff --git a/rtems/config/6.1/rtems-m68k.bset b/rtems/config/6.1/rtems-m68k.bset
index 0932d20..c10e9e3 100644
--- a/rtems/config/6.1/rtems-m68k.bset
+++ b/rtems/config/6.1/rtems-m68k.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch m68k
diff --git a/rtems/config/6.1/rtems-microblaze.bset b/rtems/config/6.1/rtems-microblaze.bset
index ea59313..ee5689b 100644
--- a/rtems/config/6.1/rtems-microblaze.bset
+++ b/rtems/config/6.1/rtems-microblaze.bset
@@ -4,7 +4,7 @@
diff --git a/rtems/config/6.1/rtems-mips.bset b/rtems/config/6.1/rtems-mips.bset
index 48771f3..1443a07 100644
--- a/rtems/config/6.1/rtems-mips.bset
+++ b/rtems/config/6.1/rtems-mips.bset
@@ -2,5 +2,5 @@
%define rtems_arch mips
%define gdb-sim-options --enable-sim-hardware
%define win32-gdb-disable-sim
tools/rtems-mipstx39-gdb-11.2
diff --git a/rtems/config/6.1/rtems-moxie.bset b/rtems/config/6.1/rtems-moxie.bset
index c86777e..f8a8a71 100644
--- a/rtems/config/6.1/rtems-moxie.bset
+++ b/rtems/config/6.1/rtems-moxie.bset
@@ -2,4 +2,4 @@
%define rtems_arch moxie
diff --git a/rtems/config/6.1/rtems-nios2.bset b/rtems/config/6.1/rtems-nios2.bset
index 522eff5..86640de 100644
--- a/rtems/config/6.1/rtems-nios2.bset
+++ b/rtems/config/6.1/rtems-nios2.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch nios2
diff --git a/rtems/config/6.1/rtems-or1k.bset b/rtems/config/6.1/rtems-or1k.bset
index c299c25..75fbb7b 100644
--- a/rtems/config/6.1/rtems-or1k.bset
+++ b/rtems/config/6.1/rtems-or1k.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch or1k
diff --git a/rtems/config/6.1/rtems-powerpc.bset b/rtems/config/6.1/rtems-powerpc.bset
index c19327a..910fae3 100644
--- a/rtems/config/6.1/rtems-powerpc.bset
+++ b/rtems/config/6.1/rtems-powerpc.bset
@@ -1,4 +1,4 @@
%define release 1
%define rtems_arch powerpc
diff --git a/rtems/config/6.1/rtems-riscv.bset b/rtems/config/6.1/rtems-riscv.bset
index ad7cb5b..d0d1d5f 100644
--- a/rtems/config/6.1/rtems-riscv.bset
+++ b/rtems/config/6.1/rtems-riscv.bset
@@ -1,5 +1,5 @@
%define release 1
%define rtems_arch riscv
devel/sis-2-1
diff --git a/rtems/config/6.1/rtems-sh.bset b/rtems/config/6.1/rtems-sh.bset
index f867962..2dcc952 100644
--- a/rtems/config/6.1/rtems-sh.bset
+++ b/rtems/config/6.1/rtems-sh.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch sh
diff --git a/rtems/config/6.1/rtems-sparc.bset b/rtems/config/6.1/rtems-sparc.bset
index 48d152d..80aa9e6 100644
--- a/rtems/config/6.1/rtems-sparc.bset
+++ b/rtems/config/6.1/rtems-sparc.bset
@@ -2,5 +2,5 @@
%define rtems_arch sparc
%define gdb-disable-sim 1
devel/sis-2-1
diff --git a/rtems/config/6.1/rtems-sparc64.bset b/rtems/config/6.1/rtems-sparc64.bset
index 8da80a6..49efbe5 100644
--- a/rtems/config/6.1/rtems-sparc64.bset
+++ b/rtems/config/6.1/rtems-sparc64.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch sparc64
diff --git a/rtems/config/6.1/rtems-v850.bset b/rtems/config/6.1/rtems-v850.bset
index dd68147..4e8d85a 100644
--- a/rtems/config/6.1/rtems-v850.bset
+++ b/rtems/config/6.1/rtems-v850.bset
@@ -1,3 +1,3 @@
%define release 1
%define rtems_arch v850
diff --git a/rtems/config/6.1/rtems-x86_64.bset b/rtems/config/6.1/rtems-x86_64.bset
index 088c9f5..678b6e4 100644
--- a/rtems/config/6.1/rtems-x86_64.bset
+++ b/rtems/config/6.1/rtems-x86_64.bset
@@ -4,6 +4,6 @@
%define grub2_platform efi
%define grub2_target x86_64
tools/rtems-grub-2.06
2.25.1
