GCC version for RTEMS 6?
Thu May 5 16:28:17 UTC 2022
Weighing in late but shouldn't gcc 12 have been in the RTEMS 7 tools for a
bit to allow testing. Then moved to RTEMS 6. My understanding is that the 7
tools are forward looking and this seems to have been exactly that use
case.
They can be ignored by most folks most.of the time but if we say 7 has gcc
next and if folks test and nothing bad is reported, those will be RTEMS 6
tools.
Seems like the period for public testing as 7 didn't happen correctly.
On Thu, May 5, 2022, 5:50 AM Karel Gardas <karel at functional.vision> wrote:
> On 5/5/22 11:35, Chris Johns wrote:
> >>> I think this is a use case where something added to the RSB may be
> required to
> >>> make this easier. For example logic in a bset file would be nice.
> >> Your idea is excellent, but I think we also may need something more
> simple and
> >> history preserving for the time releases are already done.
> >> Hence I sent a patch series creating config/6.1 as a preparation for
> 6.1 release
> >> with gcc 10 and update 6 (as a 6 branch dev) with Sebastian's updated
> GCC 12).
> >> Just meant as material for discussion.
> > I understand and thank you for contributing.
> > A release is the tarfiles and that is fixed.
> Just checked https://ftp.rtems.org/pub/rtems/releases/5/5.1/ and you are
> right! I stand corrected, in this case indeed my patch series is useless.
> Thanks,
> Karel
> devel mailing list
> devel at rtems.org
