[PATCH] sb/setbuilder: Control buildsets using the --with-* command line option
Chris Johns
chrisj at rtems.org
Thu May 5 22:35:53 UTC 2022
On 5/5/2022 10:48 pm, Frank Kühndel wrote:
> Hi Chris,
> On 5/5/22 04:52, chrisj at rtems.org wrote:
>> From: Chris Johns <chrisj at rtems.org>
>> - Expand macros in buildset file names
>> - Add support to buildsets for `%defineifnot`
>> - Update 6 and 7 to support command line build overrides
>> Closes #4646
> Useful feature. Just two comments:
> 1) There exist other packages. Have these been forgotten or are they
> irrelevant for this purpose?
> mips: mipstx39-rtems6-gdb-11.2-x86_64-linux-gnu-1
> riscv: sis-2.29-x86_64-linux-gnu-1
> sparc: sis-2.29-x86_64-linux-gnu-1
> x86_64: grub2-2.06-x86_64-linux-gnu-1
Not irrelevant, may be forgotten but I would settle on limited time to check all
possible places, make the changes and test. The pattern to manage this is now
set so please feel free to post patches with further changes.
> 2) Are these new options worth documenting?
A great question and yes I would love to see this happen.
> Currently:
> source-builder/sb-set-builder --help
> --with-<label> : Add the --with-<label> to the build
> --without-<label> : Add the --without-<label> to the build
The `--with-*` and `--without-*` is modelled after the configure option. There
is no means to know in the config scripts where and how they are used so there
is no simple way to produce relevant help messages. Updating the python based on
script does not seem wise to me.
> There at least exist the following (from source-builder/config/checks.cfg):
Yeah and this is what makes it difficult to link back to the python `--help`.
The parser is too slow to scan all the sources to build a list when --help is used.
A file in the `source-builder` directory called `help.ini` (or whatever) could
hold a list that is checked when a with or without macro is referenced in a
config file might work. If there is no help present a warning is printed. The
problem is updating the file when an option is removed from the config scripts?
Another possible solution is to add something like:
%help with-rtems-gcc Set the path to a BSET build configuration for GCC
And a tool could be written to parse the configs and update the file?
> # Process the command line --with-/--without- options.
> %{?with_cxx:%define enable_cxx 1}
> %{?without_cxx:%define enable_cxx 0}
> %{?with_ada:%define enable_ada 1}
> %{?without_ada:%define enable_ada 0}
> %{?with_fortran:%define enable_fortran 1}
> %{?without_fortran:%define enable_fortran 0}
> %{?with_java:%define enable_java 1}
> %{?without_java:%define enable_java 0}
> %{?with_objc:%define enable_objc 1}
> %{?without_objc:%define enable_objc 0}
> (Note: --with-java does not work. GCC configure does not known language
> "java". See https://gcc.gnu.org/install/configure.html option
> --enable-languages)
Please raise a ticket ... a patch would also be welcome? :)
