[PATCH] sb/setbuilder: Control buildsets using the --with-* command line option
Frank Kühndel frank.kuehndel at embedded-brains.de
Thu May 5 12:48:54 UTC 2022
Hi Chris,
On 5/5/22 04:52, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Expand macros in buildset file names
> - Add support to buildsets for `%defineifnot`
> - Update 6 and 7 to support command line build overrides
> Closes #4646
Useful feature. Just two comments:
1) There exist other packages. Have these been forgotten or are they
irrelevant for this purpose?
mips: mipstx39-rtems6-gdb-11.2-x86_64-linux-gnu-1
riscv: sis-2.29-x86_64-linux-gnu-1
sparc: sis-2.29-x86_64-linux-gnu-1
x86_64: grub2-2.06-x86_64-linux-gnu-1
2) Are these new options worth documenting? Currently:
source-builder/sb-set-builder --help
--with-<label>         : Add the --with-<label> to the build
--without-<label>      : Add the --without-<label> to the build
There at least exist the following (from source-builder/config/checks.cfg):
# Process the command line --with-/--without- options.
%{?with_cxx:%define enable_cxx 1}
%{?without_cxx:%define enable_cxx 0}
%{?with_ada:%define enable_ada 1}
%{?without_ada:%define enable_ada 0}
%{?with_fortran:%define enable_fortran 1}
%{?without_fortran:%define enable_fortran 0}
%{?with_java:%define enable_java 1}
%{?without_java:%define enable_java 0}
%{?with_objc:%define enable_objc 1}
%{?without_objc:%define enable_objc 0}
(Note: --with-java does not work. GCC configure does not known language
"java". See https://gcc.gnu.org/install/configure.html option
--enable-languages)
Greetings
fk
embedded brains GmbH
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone: +49-89-18 94 741 - 23
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
