[PATCH 2/8] Add program destructor support
Sebastian Huber
Wed May 11 06:56:35 UTC 2022
Update #4650.
rtemsbsd/include/machine/rtems-bsd-program.h | 6 +++
rtemsbsd/rtems/program-internal.h | 7 +++
rtemsbsd/rtems/rtems-program.c | 51 ++++++++++++++++++++
3 files changed, 64 insertions(+)
diff --git a/rtemsbsd/include/machine/rtems-bsd-program.h b/rtemsbsd/include/machine/rtems-bsd-program.h
index dacd0d69..3062c1a2 100644
--- a/rtemsbsd/include/machine/rtems-bsd-program.h
+++ b/rtemsbsd/include/machine/rtems-bsd-program.h
@@ -60,6 +60,12 @@ rtems_bsd_program_call_main_with_data_restore(const char *name,
int (*main)(int, char **), int argc, char **argv,
void *data_buf, const size_t data_size);
+void *
+rtems_bsd_program_add_destructor(void (*destructor)(void *), void *arg);
+void
+rtems_bsd_program_remove_destructor(void *cookie, bool call);
void
rtems_bsd_program_exit(int exit_code) __dead2;
diff --git a/rtemsbsd/rtems/program-internal.h b/rtemsbsd/rtems/program-internal.h
index da817130..2104c064 100644
--- a/rtemsbsd/rtems/program-internal.h
+++ b/rtemsbsd/rtems/program-internal.h
@@ -60,6 +60,12 @@ struct program_allocmem_item {
LIST_ENTRY(program_allocmem_item) entries;
+struct program_destructor {
+ void (*destructor)(void *);
+ void *arg;
+ LIST_ENTRY(program_destructor) link;
struct rtems_bsd_program_control {
void *context;
int exit_code;
@@ -68,6 +74,7 @@ struct rtems_bsd_program_control {
LIST_HEAD(, program_fd_item) open_fd;
LIST_HEAD(, program_file_item) open_file;
LIST_HEAD(, program_allocmem_item) allocated_mem;
+ LIST_HEAD(, program_destructor) destructors;
struct rtems_bsd_program_control *rtems_bsd_program_get_control_or_null(void);
diff --git a/rtemsbsd/rtems/rtems-program.c b/rtemsbsd/rtems/rtems-program.c
index 370609d4..4d2ce6ef 100644
--- a/rtemsbsd/rtems/rtems-program.c
+++ b/rtemsbsd/rtems/rtems-program.c
@@ -224,6 +224,18 @@ allocmem_free_all(struct rtems_bsd_program_control *prog_ctrl)
+static void
+call_destructors(struct rtems_bsd_program_control *prog_ctrl)
+ struct program_destructor *node;
+ struct program_destructor *tmp;
+ LIST_FOREACH_SAFE(node, &prog_ctrl->destructors, link, tmp) {
+ (*node->destructor)(node->arg);
+ free(node);
int
rtems_bsd_program_call(const char *name, int (*prog)(void *), void *context)
@@ -251,6 +263,7 @@ rtems_bsd_program_call(const char *name, int (*prog)(void *), void *context)
LIST_INIT(&prog_ctrl->open_fd);
LIST_INIT(&prog_ctrl->open_file);
LIST_INIT(&prog_ctrl->allocated_mem);
+ LIST_INIT(&prog_ctrl->destructors);
if (setjmp(prog_ctrl->return_context) == 0) {
exit_code = (*prog)(context);
@@ -262,10 +275,48 @@ rtems_bsd_program_call(const char *name, int (*prog)(void *), void *context)
fd_close_all(prog_ctrl);
file_close_all(prog_ctrl);
allocmem_free_all(prog_ctrl);
+ call_destructors(prog_ctrl);
free(prog_ctrl);
return (exit_code);
+void *
+ struct rtems_bsd_program_control *prog_ctrl;
+ prog_ctrl = rtems_bsd_program_get_control_or_null();
+ if (prog_ctrl == NULL) {
+ return (NULL);
+ node = malloc(sizeof(*node));
+ if (node == NULL) {
+ return (NULL);
+ node->destructor = destructor;
+ node->arg = arg;
+ LIST_INSERT_HEAD(&prog_ctrl->destructors, node, link);
+ return (node);
+void
+ node = cookie;
+ LIST_REMOVE(node, link);
+ if (call) {
+ free(node);
void
2.35.3
