[PATCH 1/8] tcpdump01: New test
Wed May 11 06:56:34 UTC 2022
Update #4650.
 libbsd.py                       |   1 +
 testsuite/tcpdump01/test_main.c | 292 ++++++++++++++++++++++++++++++++
 2 files changed, 293 insertions(+)
 create mode 100644 testsuite/tcpdump01/test_main.c
diff --git a/libbsd.py b/libbsd.py
index 2d3b718d..983f41a1 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -5588,6 +5588,7 @@ class tests(builder.Module):
         self.addTest(mm.generator['test']('ipsec01', ['test_main']))
         self.addTest(mm.generator['test']('openssl01', ['test_main']))
         self.addTest(mm.generator['test']('openssl02', ['test_main']))
+        self.addTest(mm.generator['test']('tcpdump01', ['test_main']))
 def load(mm):
diff --git a/testsuite/tcpdump01/test_main.c b/testsuite/tcpdump01/test_main.c
new file mode 100644
index 00000000..0f31cdde
--- /dev/null
+++ b/testsuite/tcpdump01/test_main.c
@@ -0,0 +1,292 @@
+ * @file
+ * @brief Tests the tcpdump command.
+ * Copyright (C) 2022 embedded brains GmbH
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+#include <sys/types.h>
+#include <sys/socket.h>
+#include <vm/uma.h>
+#include <netinet/in.h>
+#include <arpa/inet.h>
+#include <err.h>
+#include <assert.h>
+#include <ck_epoch.h>
+#include <errno.h>
+#include <limits.h>
+#include <stdbool.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+#include <rtems.h>
+#include <rtems/bsd/bsd.h>
+#include <rtems/console.h>
+#include <rtems/libcsupport.h>
+#include <machine/rtems-bsd-commands.h>
+#define TEST_NAME "LIBBSD TCPDUMP 1"
+typedef struct {
+	rtems_id main_id;
+	int sp[2];
+} test_context;
+static test_context test_instance;
+static void
+epoch_cleanup(void)
+	rtems_status_code sc;
+	sc = rtems_task_wake_after(CK_EPOCH_LENGTH);
+	assert(sc == RTEMS_SUCCESSFUL);
+static void
+init_addr(struct sockaddr_in *addr)
+	int ok;
+	memset(addr, 0, sizeof(*addr));
+	addr->sin_family = AF_INET;
+	addr->sin_port = htons(1234);
+	ok = inet_aton("127.0.0.1", &addr->sin_addr);
+	assert(ok != 0);
+static rtems_id
+start_task(rtems_task_entry entry, void *arg)
+	rtems_task_priority prio;
+	rtems_id id;
+	sc = rtems_task_set_priority(RTEMS_SELF, RTEMS_CURRENT_PRIORITY, &prio);
+	sc = rtems_task_create(rtems_build_name('T', 'E', 'S', 'T' ), prio - 1,
+	    32 * 1024, RTEMS_DEFAULT_MODES, RTEMS_DEFAULT_ATTRIBUTES, &id);
+	sc = rtems_task_start(id, entry, (rtems_task_argument)arg);
+	return id;
+static void
+test_tcpdump_help(void)
+	char *argv[] = {
+		"tcpdump",
+		"-h",
+		NULL
+	rtems_resource_snapshot snapshot;
+	int exit_code;
+	rtems_resource_snapshot_take(&snapshot);
+	exit_code = rtems_bsd_command_tcpdump(RTEMS_BSD_ARGC(argv), argv);
+	assert(exit_code == 0);
+	assert(rtems_resource_snapshot_check(&snapshot));
+static const char raw_packets_file[] = "packets.bin";
+static void
+run_tcpdump_write_raw_packets(rtems_task_argument arg)
+	test_context *ctx;
+	FILE *file;
+	FILE *saved_stdin;
+	FILE *saved_stdout;
+	FILE *saved_stderr;
+	int rv;
+	char *argv[] = {
+		"tcpdump",
+		"-n",
+		"-i",
+		"lo0",
+		"-w",
+		RTEMS_DECONST(char *, raw_packets_file),
+		NULL
+	int exit_code;
+	ctx = (test_context *)arg;
+	saved_stdin = stdin;
+	saved_stdout = stdout;
+	saved_stderr = stderr;
+	file = fdopen(ctx->sp[1], "r+");
+	assert(file != NULL);
+	stdin = file;
+	stdout = file;
+	stderr = file;
+	stdin = saved_stdin;
+	stdout = saved_stdout;
+	stderr = saved_stderr;
+	rv = fclose(file);
+	assert(rv == 0);
+	sc = rtems_event_transient_send(ctx->main_id);
+	rtems_task_exit();
+static void
+test_tcpdump_write_raw_packets(test_context *ctx)
+	char *argv[] = {
+		"tcpdump",
+		"-n",
+		"-r",
+		NULL
+	int in;
+	int out;
+	int rv;
+	char c;
+	ssize_t n;
+	struct sockaddr_in addr;
+	socklen_t addr_len;
+	int exit_code;
+	rv = socketpair(PF_UNIX, SOCK_STREAM, 0, ctx->sp);
+	assert(rv == 0);
+	start_task(run_tcpdump_write_raw_packets, ctx);
+	init_addr(&addr);
+	in = socket(PF_INET, SOCK_DGRAM, 0);
+	assert(out >= 0);
+	rv = bind(in, (const struct sockaddr *) &addr, sizeof(addr));
+	assert(rv == 0);
+	out = socket(PF_INET, SOCK_DGRAM, 0);
+	assert(out >= 0);
+	c = 'x';
+	n = sendto(out, &c, sizeof(c), 0,
+	    (const struct sockaddr *) &addr, sizeof(addr));
+	assert(n == 1);
+	c = 'y';
+	addr_len = sizeof(addr);
+	n = recvfrom(in, &c, sizeof(c), 0,
+	    (struct sockaddr *) &addr, &addr_len);
+	assert(n == 1);
+	assert(c == 'x');
+	/* The tcpdump pcap read timeout is 1000ms */
+	sc = rtems_task_wake_after(rtems_clock_get_ticks_per_second());
+	c = 'q';
+	n = write(ctx->sp[0], &c, sizeof(c));
+	assert(n == 1);
+	rv = close(out);
+	assert(rv == 0);
+	rv = close(in);
+	assert(rv == 0);
+	sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+	rv = close(ctx->sp[0]);
+	assert(rv == 0);
+	rv = unlink(raw_packets_file);
+	assert(rv == 0);
+	epoch_cleanup();
+static void
+test_main(void)
+	FILE *file;
+	int rv;
+	ctx = &test_instance;
+	ctx->main_id = rtems_task_self();
+	/* Fill dynamic file pool in Newlib */
+	file = fopen(CONSOLE_DEVICE_NAME, "r+");
+	assert(rv == 0);
+	 * Stop interferences of uma_timeout() which may need some dynamic
+	 * memory.
+	rtems_uma_drain_timeout();
+	rtems_bsd_ifconfig_lo0();
+	epoch_cleanup();
+	test_tcpdump_help();
+	test_tcpdump_write_raw_packets(ctx);
+	exit(0);
+#include <rtems/bsd/test/default-init.h>
2.35.3
