[PATCH] rtemstoolkit:libelf: sync _libelf_config.h with FreeBSD
Karel Gardas
karel at functional.vision
Thu May 12 07:26:38 UTC 2022
Chris,
this is one patch for rtems-tools required for compilation on M1. It
would be fantastic if you update the snapshot of tools and either let me
know or make source-builder working with the new snapshot.
I'm going to submit few more patches for source-builder to fix various
compilation issues on M1, but I think it would be silly if I provide a
patch for rtems-tools to be included in source builder instead of
directly fixing the issue in the git.
Thanks!
Karel
On 5/12/22 09:19, Karel Gardas wrote:
> This fixes compilation issue on Apple M1.
> .../elftoolchain/libelf/_libelf_config.h | 62 +++++++------------
> 1 file changed, 21 insertions(+), 41 deletions(-)
> diff --git a/rtemstoolkit/elftoolchain/libelf/_libelf_config.h b/rtemstoolkit/elftoolchain/libelf/_libelf_config.h
> index 102aa01..0f16f3a 100644
> --- a/rtemstoolkit/elftoolchain/libelf/_libelf_config.h
> +++ b/rtemstoolkit/elftoolchain/libelf/_libelf_config.h
> @@ -23,28 +23,14 @@
> * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
> * SUCH DAMAGE.
> - * $Id: _libelf_config.h 3566 2017-08-31 02:28:40Z emaste $
> + * $Id: _libelf_config.h 3764 2019-06-28 21:44:46Z emaste $
> -#if defined(__APPLE__) || defined(__DragonFly__)
> -#if defined(__amd64__)
> -#define LIBELF_ARCH EM_X86_64
> -#define LIBELF_BYTEORDER ELFDATA2LSB
> -#define LIBELF_CLASS ELFCLASS64
> -#elif defined(__i386__)
> -#define LIBELF_ARCH EM_386
> -#define LIBELF_CLASS ELFCLASS32
> -#endif
> -#endif /* __DragonFly__ */
> -#ifdef __FreeBSD__
> +#if defined(__APPLE__) || defined(__DragonFly__) || defined(__FreeBSD__)
> * Define LIBELF_{ARCH,BYTEORDER,CLASS} based on the machine architecture.
> - * See also: <machine/elf.h>.
> + * See also: <machine/elf.h> on FreeBSD.
> @@ -91,6 +77,16 @@
> #endif
> +#elif defined(__powerpc64__)
> +#define LIBELF_ARCH EM_PPC64
> +#if __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__
> +#define LIBELF_BYTEORDER ELFDATA2LSB
> +#else
> +#define LIBELF_BYTEORDER ELFDATA2MSB
> +#endif
> +#define LIBELF_CLASS ELFCLASS64
> #elif defined(__powerpc__)
> @@ -103,6 +99,12 @@
> +#elif defined(__riscv64)
> +#define LIBELF_ARCH EM_RISCV
> #elif defined(__sparc__)
> #define LIBELF_ARCH EM_SPARCV9
> @@ -110,9 +112,9 @@
> #else
> -#error Unknown FreeBSD architecture.
> +#error Unknown architecture.
> #endif
> -#endif /* __FreeBSD__ */
> +#endif /* defined(__APPLE__) || defined(__DragonFly__) || defined(__FreeBSD__) */
> * Definitions for Minix3.
> @@ -187,25 +189,3 @@
> #endif
> #endif /* defined(__linux__) || defined(__GNU__) || defined(__GLIBC__) */
> -#if defined(__WIN32__) || defined(__CYGWIN__)
> -#define LIBELF_VCSID(ID)
> -#else
> -#error Unknown Windows architecture.
> -#endif
> -#endif /* __WIN32__ || __CYGWIN__ */
