[PATCH] rtemstoolkit:libelf: sync _libelf_config.h with FreeBSD
Karel Gardas karel at functional.vision
Thu May 12 07:19:23 UTC 2022
This fixes compilation issue on Apple M1.
 .../elftoolchain/libelf/_libelf_config.h      | 62 +++++++------------
 1 file changed, 21 insertions(+), 41 deletions(-)
diff --git a/rtemstoolkit/elftoolchain/libelf/_libelf_config.h b/rtemstoolkit/elftoolchain/libelf/_libelf_config.h
index 102aa01..0f16f3a 100644
--- a/rtemstoolkit/elftoolchain/libelf/_libelf_config.h
+++ b/rtemstoolkit/elftoolchain/libelf/_libelf_config.h
@@ -23,28 +23,14 @@
  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
  * SUCH DAMAGE.
- * $Id: _libelf_config.h 3566 2017-08-31 02:28:40Z emaste $
+ * $Id: _libelf_config.h 3764 2019-06-28 21:44:46Z emaste $
-#if defined(__APPLE__) || defined(__DragonFly__)
-#if	defined(__amd64__)
-#define	LIBELF_ARCH		EM_X86_64
-#define	LIBELF_BYTEORDER	ELFDATA2LSB
-#define	LIBELF_CLASS		ELFCLASS64
-#elif	defined(__i386__)
-#define	LIBELF_ARCH		EM_386
-#define	LIBELF_CLASS		ELFCLASS32
-#endif
-#endif	/* __DragonFly__ */
-#ifdef __FreeBSD__
+#if defined(__APPLE__) || defined(__DragonFly__) || defined(__FreeBSD__)
  * Define LIBELF_{ARCH,BYTEORDER,CLASS} based on the machine architecture.
- * See also: <machine/elf.h>.
+ * See also: <machine/elf.h> on FreeBSD.
@@ -91,6 +77,16 @@
 #endif
+#elif	defined(__powerpc64__)
+#define	LIBELF_ARCH		EM_PPC64
+#if	__BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__
+#define	LIBELF_BYTEORDER	ELFDATA2LSB
+#else
+#define	LIBELF_BYTEORDER	ELFDATA2MSB
+#endif
+#define	LIBELF_CLASS		ELFCLASS64
 #elif	defined(__powerpc__)
@@ -103,6 +99,12 @@
+#elif	defined(__riscv64)
+#define	LIBELF_ARCH		EM_RISCV
 #elif	defined(__sparc__)
 #define	LIBELF_ARCH		EM_SPARCV9
@@ -110,9 +112,9 @@
 #else
-#error	Unknown FreeBSD architecture.
+#error	Unknown architecture.
 #endif
-#endif  /* __FreeBSD__ */
+#endif  /*  defined(__APPLE__) || defined(__DragonFly__) || defined(__FreeBSD__) */
  * Definitions for Minix3.
@@ -187,25 +189,3 @@
 #endif
 #endif /* defined(__linux__) || defined(__GNU__) || defined(__GLIBC__) */
-#if defined(__WIN32__) || defined(__CYGWIN__)
-#define LIBELF_VCSID(ID)
-#else
-#error  Unknown Windows architecture.
-#endif
-#endif  /* __WIN32__ || __CYGWIN__ */
2.25.1
