[PATCH 8/8] bsp/stm32h7: remove system files from start directory
Karel Gardas karel at functional.vision
Sun May 15 20:10:44 UTC 2022
The files are already presented in boards directories and are not needed
in start directory anymore.
Sponsored-By:	Precidata
 bsps/arm/stm32h7/start/stm32h7-config-clk.c |  45 ---
 bsps/arm/stm32h7/start/stm32h7-config-osc.c |  52 ---
 bsps/arm/stm32h7/start/stm32h7-config-per.c |  62 ---
 bsps/arm/stm32h7/start/system_stm32h7xx.c   | 416 --------------------
 4 files changed, 575 deletions(-)
 delete mode 100644 bsps/arm/stm32h7/start/stm32h7-config-clk.c
 delete mode 100644 bsps/arm/stm32h7/start/stm32h7-config-osc.c
 delete mode 100644 bsps/arm/stm32h7/start/stm32h7-config-per.c
 delete mode 100644 bsps/arm/stm32h7/start/system_stm32h7xx.c
diff --git a/bsps/arm/stm32h7/start/stm32h7-config-clk.c b/bsps/arm/stm32h7/start/stm32h7-config-clk.c
deleted file mode 100644
index 3e7c930201..0000000000
--- a/bsps/arm/stm32h7/start/stm32h7-config-clk.c
+++ /dev/null
@@ -1,45 +0,0 @@
-/* SPDX-License-Identifier: BSD-2-Clause */
- * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <stm32h7/hal.h>
-const RCC_ClkInitTypeDef stm32h7_config_clocks = {
-  .ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
-    | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2
-    | RCC_CLOCKTYPE_D3PCLK1 | RCC_CLOCKTYPE_D1PCLK1,
-  .SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK,
-  .SYSCLKDivider = RCC_SYSCLK_DIV1,
-  .AHBCLKDivider = RCC_HCLK_DIV2,
-  .APB3CLKDivider = RCC_APB3_DIV2,
-  .APB1CLKDivider = RCC_APB1_DIV2,
-  .APB2CLKDivider = RCC_APB2_DIV2,
-  .APB4CLKDivider = RCC_APB4_DIV2
diff --git a/bsps/arm/stm32h7/start/stm32h7-config-osc.c b/bsps/arm/stm32h7/start/stm32h7-config-osc.c
index b639c7ca36..0000000000
--- a/bsps/arm/stm32h7/start/stm32h7-config-osc.c
+++ /dev/null
@@ -1,52 +0,0 @@
- * are met:
-#endif
-const RCC_OscInitTypeDef stm32h7_config_oscillator = {
-  .OscillatorType = RCC_OSCILLATORTYPE_HSI | RCC_OSCILLATORTYPE_HSE
-    | RCC_OSCILLATORTYPE_LSE | RCC_OSCILLATORTYPE_HSI48,
-  .HSEState = RCC_HSE_ON,
-  .LSEState = RCC_LSE_ON,
-  .HSIState = RCC_HSI_DIV1,
-  .HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT,
-  .HSI48State = RCC_HSI48_ON,
-  .PLL.PLLState = RCC_PLL_ON,
-  .PLL.PLLSource = RCC_PLLSOURCE_HSE,
-  .PLL.PLLM = 5,
-  .PLL.PLLN = 192,
-  .PLL.PLLP = 2,
-  .PLL.PLLQ = 12,
-  .PLL.PLLR = 2,
-  .PLL.PLLRGE = RCC_PLL1VCIRANGE_2,
-  .PLL.PLLVCOSEL = RCC_PLL1VCOWIDE,
-  .PLL.PLLFRACN = 0
diff --git a/bsps/arm/stm32h7/start/stm32h7-config-per.c b/bsps/arm/stm32h7/start/stm32h7-config-per.c
index 79aa1494dd..0000000000
--- a/bsps/arm/stm32h7/start/stm32h7-config-per.c
+++ /dev/null
@@ -1,62 +0,0 @@
- * are met:
-#endif
-const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
-  .PeriphClockSelection = RCC_PERIPHCLK_RTC | RCC_PERIPHCLK_USART3
-    | RCC_PERIPHCLK_FDCAN | RCC_PERIPHCLK_USART1 | RCC_PERIPHCLK_I2C1
-    | RCC_PERIPHCLK_USB | RCC_PERIPHCLK_FMC | RCC_PERIPHCLK_RNG,
-  .PLL2.PLL2M = 3,
-  .PLL2.PLL2N = 48,
-  .PLL2.PLL2P = 1,
-  .PLL2.PLL2Q = 2,
-  .PLL2.PLL2R = 2,
-  .PLL2.PLL2RGE = RCC_PLL2VCIRANGE_3,
-  .PLL2.PLL2VCOSEL = RCC_PLL2VCOWIDE,
-  .PLL2.PLL2FRACN = 0,
-  .PLL3.PLL3M = 25,
-  .PLL3.PLL3N = 192,
-  .PLL3.PLL3P = 2,
-  .PLL3.PLL3Q = 4,
-  .PLL3.PLL3R = 2,
-  .PLL3.PLL3RGE = RCC_PLL3VCIRANGE_0,
-  .PLL3.PLL3VCOSEL = RCC_PLL3VCOWIDE,
-  .PLL3.PLL3FRACN = 0,
-  .FmcClockSelection = RCC_FMCCLKSOURCE_PLL2,
-  .FdcanClockSelection = RCC_FDCANCLKSOURCE_PLL,
-  .Usart234578ClockSelection = RCC_USART234578CLKSOURCE_D2PCLK1,
-  .Usart16ClockSelection = RCC_USART16CLKSOURCE_D2PCLK2,
-  .I2c123ClockSelection = RCC_I2C123CLKSOURCE_D2PCLK1,
-  .UsbClockSelection = RCC_USBCLKSOURCE_PLL3,
-  .RTCClockSelection = RCC_RTCCLKSOURCE_LSE,
-  .RngClockSelection = RCC_RNGCLKSOURCE_HSI48
diff --git a/bsps/arm/stm32h7/start/system_stm32h7xx.c b/bsps/arm/stm32h7/start/system_stm32h7xx.c
index a8a9ff0b4b..0000000000
--- a/bsps/arm/stm32h7/start/system_stm32h7xx.c
+++ /dev/null
@@ -1,416 +0,0 @@
-  * @file    system_stm32h7xx.c
-  * @author  MCD Application Team
-  * @brief   CMSIS Cortex-Mx Device Peripheral Access Layer System Source File.
-  *   This file provides two functions and one global variable to be called from
-  *   user application:
-  *      - SystemInit(): This function is called at startup just after reset and
-  *                      before branch to main program. This call is made inside
-  *                      the "startup_stm32h7xx.s" file.
-  *      - SystemCoreClock variable: Contains the core clock, it can be used
-  *                                  by the user application to setup the SysTick
-  *                                  timer or configure other parameters.
-  *      - SystemCoreClockUpdate(): Updates the variable SystemCoreClock and must
-  *                                 be called whenever the core clock is changed
-  *                                 during program execution.
-  * @attention
-  * <h2><center>© Copyright (c) 2017 STMicroelectronics.
-  * All rights reserved.</center></h2>
-  * This software component is licensed by ST under BSD 3-Clause license,
-  * the "License"; You may not use this file except in compliance with the
-  * License. You may obtain a copy of the License at:
-  *                        opensource.org/licenses/BSD-3-Clause
-/** @addtogroup CMSIS
-/** @addtogroup stm32h7xx_system
-/** @addtogroup STM32H7xx_System_Private_Includes
-#include "stm32h7xx.h"
-#include <math.h>
-#ifdef __rtems__
-#include <bsp/linker-symbols.h>
-#endif /* __rtems__ */
-#if !defined  (HSE_VALUE)
-#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
-#endif /* HSE_VALUE */
-#if !defined  (CSI_VALUE)
-  #define CSI_VALUE    ((uint32_t)4000000) /*!< Value of the Internal oscillator in Hz*/
-#endif /* CSI_VALUE */
-#if !defined  (HSI_VALUE)
-  #define HSI_VALUE    ((uint32_t)64000000) /*!< Value of the Internal oscillator in Hz*/
-#endif /* HSI_VALUE */
-/** @addtogroup STM32H7xx_System_Private_TypesDefinitions
-/** @addtogroup STM32H7xx_System_Private_Defines
-/************************* Miscellaneous Configuration ************************/
-/*!< Uncomment the following line if you need to use initialized data in D2 domain SRAM (AHB SRAM) */
-/* #define DATA_IN_D2_SRAM */
-/*!< Uncomment the following line if you need to relocate your vector Table in
-     Internal SRAM. */
-/* #define VECT_TAB_SRAM */
-#define VECT_TAB_OFFSET  0x00000000UL /*!< Vector Table base offset field.
-                                      This value must be a multiple of 0x200. */
-/** @addtogroup STM32H7xx_System_Private_Macros
-/** @addtogroup STM32H7xx_System_Private_Variables
-  /* This variable is updated in three ways:
-      1) by calling CMSIS function SystemCoreClockUpdate()
-      2) by calling HAL API function HAL_RCC_GetHCLKFreq()
-      3) each time HAL_RCC_ClockConfig() is called to configure the system clock frequency
-         Note: If you use this function to configure the system clock; then there
-               is no need to call the 2 first functions listed above, since SystemCoreClock
-               variable is updated automatically.
-#ifndef __rtems__
-  uint32_t SystemCoreClock = 64000000;
-  uint32_t SystemD2Clock = 64000000;
-#else /* __rtems__ */
-  RTEMS_SECTION(".rtemsstack") uint32_t SystemCoreClock;
-  RTEMS_SECTION(".rtemsstack") uint32_t SystemD2Clock;
-  const  uint8_t D1CorePrescTable[16] = {0, 0, 0, 0, 1, 2, 3, 4, 1, 2, 3, 4, 6, 7, 8, 9};
-/** @addtogroup STM32H7xx_System_Private_FunctionPrototypes
-/** @addtogroup STM32H7xx_System_Private_Functions
-  * @brief  Setup the microcontroller system
-  *         Initialize the FPU setting and  vector table location
-  *         configuration.
-  * @param  None
-  * @retval None
-void SystemInit (void)
-#if defined (DATA_IN_D2_SRAM)
- __IO uint32_t tmpreg;
-#endif /* DATA_IN_D2_SRAM */
-  /* FPU settings ------------------------------------------------------------*/
-  #if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
-    SCB->CPACR |= ((3UL << (10*2))|(3UL << (11*2)));  /* set CP10 and CP11 Full Access */
-  #endif
-  /* Reset the RCC clock configuration to the default reset state ------------*/
-  /* Set HSION bit */
-  RCC->CR |= RCC_CR_HSION;
-  /* Reset CFGR register */
-  RCC->CFGR = 0x00000000;
-  /* Reset HSEON, CSSON , CSION,RC48ON, CSIKERON PLL1ON, PLL2ON and PLL3ON bits */
-  RCC->CR &= 0xEAF6ED7FU;
-#if defined(D3_SRAM_BASE)
-  /* Reset D1CFGR register */
-  RCC->D1CFGR = 0x00000000;
-  /* Reset D2CFGR register */
-  RCC->D2CFGR = 0x00000000;
-  /* Reset D3CFGR register */
-  RCC->D3CFGR = 0x00000000;
-#else
-  /* Reset CDCFGR1 register */
-  RCC->CDCFGR1 = 0x00000000;
-  /* Reset CDCFGR2 register */
-  RCC->CDCFGR2 = 0x00000000;
-  /* Reset SRDCFGR register */
-  RCC->SRDCFGR = 0x00000000;
-#endif
-  /* Reset PLLCKSELR register */
-  RCC->PLLCKSELR = 0x00000000;
-  /* Reset PLLCFGR register */
-  RCC->PLLCFGR = 0x00000000;
-  /* Reset PLL1DIVR register */
-  RCC->PLL1DIVR = 0x00000000;
-  /* Reset PLL1FRACR register */
-  RCC->PLL1FRACR = 0x00000000;
-  /* Reset PLL2DIVR register */
-  RCC->PLL2DIVR = 0x00000000;
-  /* Reset PLL2FRACR register */
-  RCC->PLL2FRACR = 0x00000000;
-  /* Reset PLL3DIVR register */
-  RCC->PLL3DIVR = 0x00000000;
-  /* Reset PLL3FRACR register */
-  RCC->PLL3FRACR = 0x00000000;
-  /* Reset HSEBYP bit */
-  RCC->CR &= 0xFFFBFFFFU;
-  /* Disable all interrupts */
-  RCC->CIER = 0x00000000;
-#if (STM32H7_DEV_ID == 0x450UL)
-  /* dual core CM7 or single core line */
-  if((DBGMCU->IDCODE & 0xFFFF0000U) < 0x20000000U)
-    /* if stm32h7 revY*/
-    /* Change  the switch matrix read issuing capability to 1 for the AXI SRAM target (Target 7) */
-    *((__IO uint32_t*)0x51008108) = 0x000000001U;
-#endif
-#ifndef __rtems__
-  /* in case of initialized data in D2 SRAM (AHB SRAM) , enable the D2 SRAM clock (AHB SRAM clock) */
-#if defined(RCC_AHB2ENR_D2SRAM3EN)
-  RCC->AHB2ENR |= (RCC_AHB2ENR_D2SRAM1EN | RCC_AHB2ENR_D2SRAM2EN | RCC_AHB2ENR_D2SRAM3EN);
-#elif defined(RCC_AHB2ENR_D2SRAM2EN)
-  RCC->AHB2ENR |= (RCC_AHB2ENR_D2SRAM1EN | RCC_AHB2ENR_D2SRAM2EN);
-#else
-  RCC->AHB2ENR |= (RCC_AHB2ENR_AHBSRAM1EN | RCC_AHB2ENR_AHBSRAM2EN);
-#endif /* RCC_AHB2ENR_D2SRAM3EN */
-  tmpreg = RCC->AHB2ENR;
-  (void) tmpreg;
-  RCC->AHB2ENR;
-#ifndef __rtems__
-#if defined(DUAL_CORE) && defined(CORE_CM4)
-  /* Configure the Vector Table location add offset address for cortex-M4 ------------------*/
-#ifdef VECT_TAB_SRAM
-  SCB->VTOR = D2_AHBSRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
-#else
-  SCB->VTOR = FLASH_BANK2_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
-#endif /* VECT_TAB_SRAM */
-#else
-  /* Configure the Vector Table location add offset address for cortex-M7 ------------------*/
-  SCB->VTOR = D1_AXISRAM_BASE  | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal AXI-RAM */
-#else
-  SCB->VTOR = FLASH_BANK1_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
-#endif
-#endif /*DUAL_CORE && CORE_CM4*/
-  SCB->VTOR = (uint32_t) bsp_start_vector_table_begin;
-   * @brief  Update SystemCoreClock variable according to Clock Register Values.
-  *         The SystemCoreClock variable contains the core clock , it can
-  *         be used by the user application to setup the SysTick timer or configure
-  *         other parameters.
-  * @note   Each time the core clock changes, this function must be called
-  *         to update SystemCoreClock variable value. Otherwise, any configuration
-  *         based on this variable will be incorrect.
-  * @note   - The system frequency computed by this function is not the real
-  *           frequency in the chip. It is calculated based on the predefined
-  *           constant and the selected clock source:
-  *           - If SYSCLK source is CSI, SystemCoreClock will contain the CSI_VALUE(*)
-  *           - If SYSCLK source is HSI, SystemCoreClock will contain the HSI_VALUE(**)
-  *           - If SYSCLK source is HSE, SystemCoreClock will contain the HSE_VALUE(***)
-  *           - If SYSCLK source is PLL, SystemCoreClock will contain the CSI_VALUE(*),
-  *             HSI_VALUE(**) or HSE_VALUE(***) multiplied/divided by the PLL factors.
-  *         (*) CSI_VALUE is a constant defined in stm32h7xx_hal.h file (default value
-  *             4 MHz) but the real value may vary depending on the variations
-  *             in voltage and temperature.
-  *         (**) HSI_VALUE is a constant defined in stm32h7xx_hal.h file (default value
-  *             64 MHz) but the real value may vary depending on the variations
-  *         (***)HSE_VALUE is a constant defined in stm32h7xx_hal.h file (default value
-  *              25 MHz), user has to ensure that HSE_VALUE is same as the real
-  *              frequency of the crystal used. Otherwise, this function may
-  *              have wrong result.
-  *         - The result of this function could be not correct when using fractional
-  *           value for HSE crystal.
-  * @param  None
-  * @retval None
-void SystemCoreClockUpdate (void)
-  uint32_t pllp, pllsource, pllm, pllfracen, hsivalue, tmp;
-  uint32_t common_system_clock;
-  float_t fracn1, pllvco;
-  /* Get SYSCLK source -------------------------------------------------------*/
-  switch (RCC->CFGR & RCC_CFGR_SWS)
-  case RCC_CFGR_SWS_HSI:  /* HSI used as system clock source */
-    common_system_clock = (uint32_t) (HSI_VALUE >> ((RCC->CR & RCC_CR_HSIDIV)>> 3));
-    break;
-  case RCC_CFGR_SWS_CSI:  /* CSI used as system clock  source */
-    common_system_clock = CSI_VALUE;
-    break;
-  case RCC_CFGR_SWS_HSE:  /* HSE used as system clock  source */
-    common_system_clock = HSE_VALUE;
-    break;
-  case RCC_CFGR_SWS_PLL1:  /* PLL1 used as system clock  source */
-    /* PLL_VCO = (HSE_VALUE or HSI_VALUE or CSI_VALUE/ PLLM) * PLLN
-    SYSCLK = PLL_VCO / PLLR
-    pllsource = (RCC->PLLCKSELR & RCC_PLLCKSELR_PLLSRC);
-    pllm = ((RCC->PLLCKSELR & RCC_PLLCKSELR_DIVM1)>> 4)  ;
-    pllfracen = ((RCC->PLLCFGR & RCC_PLLCFGR_PLL1FRACEN)>>RCC_PLLCFGR_PLL1FRACEN_Pos);
-    fracn1 = (float_t)(uint32_t)(pllfracen* ((RCC->PLL1FRACR & RCC_PLL1FRACR_FRACN1)>> 3));
-    if (pllm != 0U)
-      switch (pllsource)
-        case RCC_PLLCKSELR_PLLSRC_HSI:  /* HSI used as PLL clock source */
-        hsivalue = (HSI_VALUE >> ((RCC->CR & RCC_CR_HSIDIV)>> 3)) ;
-        pllvco = ( (float_t)hsivalue / (float_t)pllm) * ((float_t)(uint32_t)(RCC->PLL1DIVR & RCC_PLL1DIVR_N1) + (fracn1/(float_t)0x2000) +(float_t)1 );
-        break;
-        case RCC_PLLCKSELR_PLLSRC_CSI:  /* CSI used as PLL clock source */
-          pllvco = ((float_t)CSI_VALUE / (float_t)pllm) * ((float_t)(uint32_t)(RCC->PLL1DIVR & RCC_PLL1DIVR_N1) + (fracn1/(float_t)0x2000) +(float_t)1 );
-        break;
-        case RCC_PLLCKSELR_PLLSRC_HSE:  /* HSE used as PLL clock source */
-          pllvco = ((float_t)HSE_VALUE / (float_t)pllm) * ((float_t)(uint32_t)(RCC->PLL1DIVR & RCC_PLL1DIVR_N1) + (fracn1/(float_t)0x2000) +(float_t)1 );
-        break;
-      default:
-        break;
-      pllp = (((RCC->PLL1DIVR & RCC_PLL1DIVR_P1) >>9) + 1U ) ;
-      common_system_clock =  (uint32_t)(float_t)(pllvco/(float_t)pllp);
-    else
-      common_system_clock = 0U;
-    break;
-  default:
-    break;
-  /* Compute SystemClock frequency --------------------------------------------------*/
-#if defined (RCC_D1CFGR_D1CPRE)
-  tmp = D1CorePrescTable[(RCC->D1CFGR & RCC_D1CFGR_D1CPRE)>> RCC_D1CFGR_D1CPRE_Pos];
-  /* common_system_clock frequency : CM7 CPU frequency  */
-  common_system_clock >>= tmp;
-  /* SystemD2Clock frequency : CM4 CPU, AXI and AHBs Clock frequency  */
-  SystemD2Clock = (common_system_clock >> ((D1CorePrescTable[(RCC->D1CFGR & RCC_D1CFGR_HPRE)>> RCC_D1CFGR_HPRE_Pos]) & 0x1FU));
-#else
-  tmp = D1CorePrescTable[(RCC->CDCFGR1 & RCC_CDCFGR1_CDCPRE)>> RCC_CDCFGR1_CDCPRE_Pos];
-  /* SystemD2Clock frequency : AXI and AHBs Clock frequency  */
-  SystemD2Clock = (common_system_clock >> ((D1CorePrescTable[(RCC->CDCFGR1 & RCC_CDCFGR1_HPRE)>> RCC_CDCFGR1_HPRE_Pos]) & 0x1FU));
-#endif
-  SystemCoreClock = SystemD2Clock;
-#else
-  SystemCoreClock = common_system_clock;
-#endif /* DUAL_CORE && CORE_CM4 */
-/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
2.25.1
