[PATCH 7/8] bsp/stm32h7: copy system files to nucleo-h743zi board directory
Karel Gardas karel at functional.vision
Sun May 15 20:10:43 UTC 2022
Also adjust BSP spec file to make it buildable with board files.
Sponsored-By:	Precidata
 .../boards/stm/nucleo-h743zi/ext-mem-ctl.c    | 478 ++++++++++++++++++
 .../stm/nucleo-h743zi/stm32h7-config-clk.c    |  45 ++
 .../stm/nucleo-h743zi/stm32h7-config-osc.c    |  52 ++
 .../stm/nucleo-h743zi/stm32h7-config-per.c    |  62 +++
 .../stm/nucleo-h743zi/system_stm32h7xx.c      | 416 +++++++++++++++
 .../bsps/arm/stm32h7/bspnucleoh743zi.yml      |  10 +-
 6 files changed, 1058 insertions(+), 5 deletions(-)
 create mode 100644 bsps/arm/stm32h7/boards/stm/nucleo-h743zi/ext-mem-ctl.c
 create mode 100644 bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-clk.c
 create mode 100644 bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-osc.c
 create mode 100644 bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-per.c
 create mode 100644 bsps/arm/stm32h7/boards/stm/nucleo-h743zi/system_stm32h7xx.c
diff --git a/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/ext-mem-ctl.c b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/ext-mem-ctl.c
new file mode 100644
index 0000000000..a2ab9d8f1f
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/ext-mem-ctl.c
@@ -0,0 +1,478 @@
+  * @file    system_stm32h7xx.c
+  * @author  MCD Application Team
+  * @brief   CMSIS Cortex-M Device Peripheral Access Layer System Source File.
+  *   This file provides two functions and one global variable to be called from
+  *   user application:
+  *      - SystemInit(): This function is called at startup just after reset and
+  *                      before branch to main program. This call is made inside
+  *                      the "startup_stm32h7xx.s" file.
+  *      - SystemCoreClock variable: Contains the core clock (HCLK), it can be used
+  *                                  by the user application to setup the SysTick
+  *                                  timer or configure other parameters.
+  *      - SystemCoreClockUpdate(): Updates the variable SystemCoreClock and must
+  *                                 be called whenever the core clock is changed
+  *                                 during program execution.
+  * @attention
+  * <h2><center>© Copyright (c) 2017 STMicroelectronics.
+  * All rights reserved.</center></h2>
+  * This software component is licensed by ST under BSD 3-Clause license,
+  * the "License"; You may not use this file except in compliance with the
+  * License. You may obtain a copy of the License at:
+  *                        opensource.org/licenses/BSD-3-Clause
+#include <stm32h7xx_hal.h>
+#define DATA_IN_ExtSRAM
+#define DATA_IN_ExtSDRAM
+void  SystemInit_ExtMemCtl(void)
+  #define  FMC_BMAP_Value    0x02000000    /* FMC Bank Mapping 2 (SDRAM Bank2 remapped) */
+  __IO uint32_t  tmp = 0;
+  /********** SDRAM + SRAM ***********************************************************************/
+  #if defined (DATA_IN_ExtSDRAM) && defined (DATA_IN_ExtSRAM)
+  register uint32_t       tmpreg = 0, timeout = 0xFFFF;
+  register __IO uint32_t  index;
+  /*-- I/O Ports Configuration ------------------------------------------------------*/
+  /* Enable GPIOD, GPIOE, GPIOF, GPIOG, GPIOH and GPIOI interface clock */
+  RCC->AHB4ENR |= 0x000001F8;
+  /* Delay after an RCC peripheral clock enabling */
+  tmp = READ_BIT(RCC->AHB4ENR, RCC_AHB4ENR_GPIOEEN);
+  /* Connect PDx pins to FMC Alternate function */
+  GPIOD->AFR[0]  = 0x00CC00CC;
+  GPIOD->AFR[1]  = 0xCCCCCCCC;
+  /* Configure PDx pins in Alternate function mode */
+  GPIOD->MODER   = 0xAAAAFAFA;
+  /* Configure PDx pins speed to 100 MHz */
+  GPIOD->OSPEEDR = 0xFFFF0F0F;
+  /* Configure PDx pins Output type to push-pull */
+  GPIOD->OTYPER  = 0x00000000;
+  /* Configure PDx pins in Pull-up */
+  GPIOD->PUPDR   = 0x55550505;
+  /* Connect PEx pins to FMC Alternate function */
+  GPIOE->AFR[0]  = 0xC00CC0CC;
+  GPIOE->AFR[1]  = 0xCCCCCCCC;
+  /* Configure PEx pins in Alternate function mode */
+  GPIOE->MODER   = 0xAAAABEBA;
+  /* Configure PEx pins speed to 100 MHz */
+  GPIOE->OSPEEDR = 0xFFFFC3CF;
+  /* Configure PEx pins Output type to push-pull */
+  GPIOE->OTYPER  = 0x00000000;
+  /* Configure PEx pins in Pull-up */
+  GPIOE->PUPDR   = 0x55554145;
+  /* Connect PFx pins to FMC Alternate function */
+  GPIOF->AFR[0]  = 0x00CCCCCC;
+  GPIOF->AFR[1]  = 0xCCCCC000;
+  /* Configure PFx pins in Alternate function mode */
+  GPIOF->MODER   = 0xAABFFAAA;
+  /* Configure PFx pins speed to 100 MHz */
+  GPIOF->OSPEEDR = 0xFFC00FFF;
+  /* Configure PFx pins Output type to push-pull */
+  GPIOF->OTYPER  = 0x00000000;
+  /* Configure PFx pins in Pull-up */
+  GPIOF->PUPDR   = 0x55400555;
+  /* Connect PGx pins to FMC Alternate function */
+  GPIOG->AFR[0]  = 0x00CCCCCC;
+  GPIOG->AFR[1]  = 0xC0000C0C;
+  /* Configure PGx pins in Alternate function mode */
+  GPIOG->MODER   = 0xBFEEFAAA;
+  /* Configure PGx pins speed to 100 MHz */
+  GPIOG->OSPEEDR = 0xC0330FFF;
+  /* Configure PGx pins Output type to push-pull */
+  GPIOG->OTYPER  = 0x00000000;
+  /* Configure PGx pins in Pull-up */
+  GPIOG->PUPDR   = 0x40110555;
+  /* Connect PHx pins to FMC Alternate function */
+  GPIOH->AFR[0]  = 0xCCC00000;
+  GPIOH->AFR[1]  = 0xCCCCCCCC;
+  /* Configure PHx pins in Alternate function mode */
+  GPIOH->MODER   = 0xAAAAABFF;
+  /* Configure PHx pins speed to 100 MHz */
+  GPIOH->OSPEEDR = 0xFFFFFC00;
+  /* Configure PHx pins Output type to push-pull */
+  GPIOH->OTYPER  = 0x00000000;
+  /* Configure PHx pins in Pull-up */
+  GPIOH->PUPDR   = 0x55555400;
+  /* Connect PIx pins to FMC Alternate function */
+  GPIOI->AFR[0]  = 0xCCCCCCCC;
+  GPIOI->AFR[1]  = 0x00000CC0;
+  /* Configure PIx pins in Alternate function mode */
+  GPIOI->MODER   = 0xFFEBAAAA;
+  /* Configure PIx pins speed to 100 MHz */
+  GPIOI->OSPEEDR = 0x003CFFFF;
+  /* Configure PIx pins Output type to push-pull */
+  GPIOI->OTYPER  = 0x00000000;
+  /* Configure PIx pins in Pull-up */
+  GPIOI->PUPDR   = 0x00145555;
+  /*-- FMC Configuration ------------------------------------------------------*/
+  /* Enable the FMC/FSMC interface clock */
+  (RCC->AHB3ENR |= (RCC_AHB3ENR_FMCEN));
+  /* Configure and enable Bank1_SRAM2 */
+  FMC_Bank1_R->BTCR[4]  = 0x00001091;
+  FMC_Bank1_R->BTCR[5]  = 0x00110212;
+  FMC_Bank1E_R->BWTR[4] = 0x0FFFFFFF;
+  /* SDRAM Timing and access interface configuration */
+  /*SDBank               = FMC_SDRAM_BANK2
+    ColumnBitsNumber     = FMC_SDRAM_COLUMN_BITS_NUM_9           CC
+    RowBitsNumber        = FMC_SDRAM_ROW_BITS_NUM_12             RR
+    MemoryDataWidth      = FMC_SDRAM_MEM_BUS_WIDTH_32            MM
+    InternalBankNumber   = FMC_SDRAM_INTERN_BANKS_NUM_4          N
+    CASLatency           = FMC_SDRAM_CAS_LATENCY_2               LL   // 2 oder 3, s.u.
+    WriteProtection      = FMC_SDRAM_WRITE_PROTECTION_DISABLE    W
+    SDClockPeriod        = FMC_SDRAM_CLOCK_PERIOD_2              KK
+    ReadBurst            = FMC_SDRAM_RBURST_ENABLE               B
+    ReadPipeDelay        = FMC_SDRAM_RPIPE_DELAY_0               PP
+    LoadToActiveDelay    = 2  -> 1     LLLL     TMRD
+    ExitSelfRefreshDelay = 6  -> 5     EEEE     TXSR
+    SelfRefreshTime      = 4  -> 3     SSSS     TRAS
+    RowCycleDelay        = 6  -> 5     RRRR     TRC
+    WriteRecoveryTime    = 2  -> 1     WWWW     TWR
+    RPDelay              = 2  -> 1     PPPP     TRP
+    RCDDelay             = 2  -> 1     CCCC     TRCD              */
+  #if 0
+  FMC_Bank5_6_R->SDCR[0] = 0x00005965;  // 0000 0000 0000 0000 0101 1001 0110 0101  Bank 1
+                                        //                      PPB KKWL LNMM RRCC
+  FMC_Bank5_6_R->SDCR[1] = 0x00005965;  // 0000 0000 0000 0000 0101 1001 0110 0101  Bank 2  // CAS Latency = 2
+                                        //                            WL LNMM RRCC
+  FMC_Bank5_6_R->SDTR[0] = 0x00105000;  // 0000 0000 0001 0000 0101 0000 0000 0000  Bank 1  // Original,
+                                        //      CCCC PPPP WWWW RRRR SSSS EEEE LLLL          // mit CAS Latency = 2 (s.o.)
+  FMC_Bank5_6_R->SDTR[1] = 0x01010351;  // 0000 0001 0000 0001 0000 0011 0101 0001  Bank 2
+                                        //      CCCC      WWWW      SSSS EEEE LLLL
+  #endif
+  #if 0
+  FMC_Bank5_6_R->SDTR[0] = 0x00206000;  // 0000 0000 0010 0000 0110 0000 0000 0000  Bank 1  // Original + 1 bei allen Werten,
+                                        //      CCCC PPPP WWWW RRRR SSSS EEEE LLLL          // mit CAS Latency = 3 (s.o.)
+  FMC_Bank5_6_R->SDTR[1] = 0x02020462;  // 0000 0010 0000 0010 0000 0100 0110 0010  Bank 2
+  #endif
+  #if 0
+  FMC_Bank5_6_R->SDTR[0] = 0x00209000;  // 0000 0000 0010 0000 1001 0000 0000 0000  Bank 1  // Versuch anhand ISSI-Datenblatt,
+  FMC_Bank5_6_R->SDTR[1] = 0x020306B1;  // 0000 0010 0000 0011 0000 0110 1011 0001  Bank 2
+  #endif
+  FMC_Bank5_6_R->SDCR[0] = 0x00001800;
+  FMC_Bank5_6_R->SDCR[1] = 0x00000165;
+  /* SDRAM initialization sequence */
+  /* Clock enable command */
+  FMC_Bank5_6_R->SDCMR = 0x00000009;
+  tmpreg = FMC_Bank5_6_R->SDSR & 0x00000020;
+  while ((tmpreg != 0) && (timeout-- > 0))
+  /* Delay */
+  for (index=0; index<1000; index++);
+  /* PALL command */
+  FMC_Bank5_6_R->SDCMR = 0x0000000A;
+  timeout = 0xFFFF;
+  FMC_Bank5_6_R->SDCMR = 0x000000EB;
+  timeout = 0xFFFF;
+  FMC_Bank5_6_R->SDCMR = 0x0004400C;
+  timeout = 0xFFFF;
+  /* Set refresh count */
+  tmpreg = FMC_Bank5_6_R->SDRTR;
+  FMC_Bank5_6_R->SDRTR = (tmpreg | (0x00000603 << 1));
+  /* Disable write protection */
+  tmpreg = FMC_Bank5_6_R->SDCR[1];
+  FMC_Bank5_6_R->SDCR[1] = (tmpreg & 0xFFFFFDFF);
+  /* Configure FMC Bank Mapping */
+  FMC_Bank1_R->BTCR[0] |= FMC_BMAP_Value;
+   /* FMC controller Enable */
+  FMC_Bank1_R->BTCR[0] |= 0x80000000;
+  /********** SDRAM only *************************************************************************/
+  #elif defined (DATA_IN_ExtSDRAM)
+  GPIOD->AFR[0]  = 0x000000CC;
+  GPIOD->AFR[1]  = 0xCC000CCC;
+  GPIOD->MODER   = 0xAFEAFFFA;
+  GPIOD->OSPEEDR = 0xF03F000F;
+  GPIOD->PUPDR   = 0x50150005;
+  GPIOE->AFR[0]  = 0xC00000CC;
+  GPIOE->MODER   = 0xAAAABFFA;
+  GPIOE->OSPEEDR = 0xFFFFC00F;
+  GPIOE->PUPDR   = 0x55554005;
+  GPIOG->AFR[1]  = 0xC000000C;
+  GPIOG->MODER   = 0xBFFEFAAA;
+  GPIOG->OSPEEDR = 0xC0030FFF;
+  GPIOG->PUPDR   = 0x40010555;
+  /* Enable the FMC interface clock */
+  /*LoadToActiveDelay    = 2
+    RowCycleDelay        = 6
+    RPDelay              = 2
+    RCDDelay             = 2
+    SDBank               = FMC_SDRAM_BANK2
+    ReadPipeDelay        = FMC_SDRAM_RPIPE_DELAY_0*/
+  /* Delay */
+  timeout = 0xFFFF;
+  timeout = 0xFFFF;
+  timeout = 0xFFFF;
+  FMC_Bank5_6_R->SDRTR = (tmpreg | (0x00000603<<1));
+  /********** SRAM only **************************************************************************/
+  #elif defined(DATA_IN_ExtSRAM)
+  /*-- I/O Ports Configuration -----------------------------------------------------*/
+  /* Enable GPIOD, GPIOE, GPIOF and GPIOG interface clock */
+  RCC->AHB4ENR |= 0x00000078;
+  GPIOD->MODER   = 0xAAAAFABA;
+  GPIOF->AFR[1]  = 0xCCCC0000;
+  GPIOF->MODER   = 0xAAFFFAAA;
+  GPIOF->OSPEEDR = 0xFF000FFF;
+  GPIOF->PUPDR   = 0x55000555;
+  GPIOG->AFR[1]  = 0x00000C00;
+  GPIOG->MODER   = 0xFFEFFAAA;
+  GPIOG->OSPEEDR = 0x00300FFF;
+  GPIOG->PUPDR   = 0x00100555;
+  /*-- FMC/FSMC Configuration --------------------------------------------------*/
+  #endif /* DATA_IN_ExtSRAM */
+  (void)(tmp);
diff --git a/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-clk.c b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-clk.c
index 0000000000..3e7c930201
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-clk.c
@@ -0,0 +1,45 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <stm32h7/hal.h>
+const RCC_ClkInitTypeDef stm32h7_config_clocks = {
+  .ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
+    | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2
+    | RCC_CLOCKTYPE_D3PCLK1 | RCC_CLOCKTYPE_D1PCLK1,
+  .SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK,
+  .SYSCLKDivider = RCC_SYSCLK_DIV1,
+  .AHBCLKDivider = RCC_HCLK_DIV2,
+  .APB3CLKDivider = RCC_APB3_DIV2,
+  .APB1CLKDivider = RCC_APB1_DIV2,
+  .APB2CLKDivider = RCC_APB2_DIV2,
+  .APB4CLKDivider = RCC_APB4_DIV2
diff --git a/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-osc.c b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-osc.c
index 0000000000..b639c7ca36
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-osc.c
@@ -0,0 +1,52 @@
+ * are met:
+#endif
+const RCC_OscInitTypeDef stm32h7_config_oscillator = {
+  .OscillatorType = RCC_OSCILLATORTYPE_HSI | RCC_OSCILLATORTYPE_HSE
+    | RCC_OSCILLATORTYPE_LSE | RCC_OSCILLATORTYPE_HSI48,
+  .HSEState = RCC_HSE_ON,
+  .LSEState = RCC_LSE_ON,
+  .HSIState = RCC_HSI_DIV1,
+  .HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT,
+  .HSI48State = RCC_HSI48_ON,
+  .PLL.PLLState = RCC_PLL_ON,
+  .PLL.PLLSource = RCC_PLLSOURCE_HSE,
+  .PLL.PLLM = 5,
+  .PLL.PLLN = 192,
+  .PLL.PLLP = 2,
+  .PLL.PLLQ = 12,
+  .PLL.PLLR = 2,
+  .PLL.PLLRGE = RCC_PLL1VCIRANGE_2,
+  .PLL.PLLVCOSEL = RCC_PLL1VCOWIDE,
+  .PLL.PLLFRACN = 0
diff --git a/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-per.c b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-per.c
index 0000000000..79aa1494dd
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-per.c
@@ -0,0 +1,62 @@
+ * are met:
+#endif
+const RCC_PeriphCLKInitTypeDef stm32h7_config_peripheral_clocks = {
+  .PeriphClockSelection = RCC_PERIPHCLK_RTC | RCC_PERIPHCLK_USART3
+    | RCC_PERIPHCLK_FDCAN | RCC_PERIPHCLK_USART1 | RCC_PERIPHCLK_I2C1
+    | RCC_PERIPHCLK_USB | RCC_PERIPHCLK_FMC | RCC_PERIPHCLK_RNG,
+  .PLL2.PLL2M = 3,
+  .PLL2.PLL2N = 48,
+  .PLL2.PLL2P = 1,
+  .PLL2.PLL2Q = 2,
+  .PLL2.PLL2R = 2,
+  .PLL2.PLL2RGE = RCC_PLL2VCIRANGE_3,
+  .PLL2.PLL2VCOSEL = RCC_PLL2VCOWIDE,
+  .PLL2.PLL2FRACN = 0,
+  .PLL3.PLL3M = 25,
+  .PLL3.PLL3N = 192,
+  .PLL3.PLL3P = 2,
+  .PLL3.PLL3Q = 4,
+  .PLL3.PLL3R = 2,
+  .PLL3.PLL3RGE = RCC_PLL3VCIRANGE_0,
+  .PLL3.PLL3VCOSEL = RCC_PLL3VCOWIDE,
+  .PLL3.PLL3FRACN = 0,
+  .FmcClockSelection = RCC_FMCCLKSOURCE_PLL2,
+  .FdcanClockSelection = RCC_FDCANCLKSOURCE_PLL,
+  .Usart234578ClockSelection = RCC_USART234578CLKSOURCE_D2PCLK1,
+  .Usart16ClockSelection = RCC_USART16CLKSOURCE_D2PCLK2,
+  .I2c123ClockSelection = RCC_I2C123CLKSOURCE_D2PCLK1,
+  .UsbClockSelection = RCC_USBCLKSOURCE_PLL3,
+  .RTCClockSelection = RCC_RTCCLKSOURCE_LSE,
+  .RngClockSelection = RCC_RNGCLKSOURCE_HSI48
diff --git a/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/system_stm32h7xx.c b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/system_stm32h7xx.c
index 0000000000..a8a9ff0b4b
--- /dev/null
+++ b/bsps/arm/stm32h7/boards/stm/nucleo-h743zi/system_stm32h7xx.c
@@ -0,0 +1,416 @@
+  * @brief   CMSIS Cortex-Mx Device Peripheral Access Layer System Source File.
+  *      - SystemCoreClock variable: Contains the core clock, it can be used
+  * @attention
+/** @addtogroup CMSIS
+/** @addtogroup stm32h7xx_system
+/** @addtogroup STM32H7xx_System_Private_Includes
+#include "stm32h7xx.h"
+#include <math.h>
+#ifdef __rtems__
+#include <bsp/linker-symbols.h>
+#endif /* __rtems__ */
+#if !defined  (HSE_VALUE)
+#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
+#endif /* HSE_VALUE */
+#if !defined  (CSI_VALUE)
+  #define CSI_VALUE    ((uint32_t)4000000) /*!< Value of the Internal oscillator in Hz*/
+#endif /* CSI_VALUE */
+#if !defined  (HSI_VALUE)
+  #define HSI_VALUE    ((uint32_t)64000000) /*!< Value of the Internal oscillator in Hz*/
+#endif /* HSI_VALUE */
+/** @addtogroup STM32H7xx_System_Private_TypesDefinitions
+/** @addtogroup STM32H7xx_System_Private_Defines
+/************************* Miscellaneous Configuration ************************/
+/*!< Uncomment the following line if you need to use initialized data in D2 domain SRAM (AHB SRAM) */
+/* #define DATA_IN_D2_SRAM */
+/*!< Uncomment the following line if you need to relocate your vector Table in
+     Internal SRAM. */
+/* #define VECT_TAB_SRAM */
+#define VECT_TAB_OFFSET  0x00000000UL /*!< Vector Table base offset field.
+                                      This value must be a multiple of 0x200. */
+/** @addtogroup STM32H7xx_System_Private_Macros
+/** @addtogroup STM32H7xx_System_Private_Variables
+  /* This variable is updated in three ways:
+      1) by calling CMSIS function SystemCoreClockUpdate()
+      2) by calling HAL API function HAL_RCC_GetHCLKFreq()
+      3) each time HAL_RCC_ClockConfig() is called to configure the system clock frequency
+         Note: If you use this function to configure the system clock; then there
+               is no need to call the 2 first functions listed above, since SystemCoreClock
+               variable is updated automatically.
+#ifndef __rtems__
+  uint32_t SystemCoreClock = 64000000;
+  uint32_t SystemD2Clock = 64000000;
+#else /* __rtems__ */
+  RTEMS_SECTION(".rtemsstack") uint32_t SystemCoreClock;
+  RTEMS_SECTION(".rtemsstack") uint32_t SystemD2Clock;
+  const  uint8_t D1CorePrescTable[16] = {0, 0, 0, 0, 1, 2, 3, 4, 1, 2, 3, 4, 6, 7, 8, 9};
+/** @addtogroup STM32H7xx_System_Private_FunctionPrototypes
+/** @addtogroup STM32H7xx_System_Private_Functions
+  * @brief  Setup the microcontroller system
+  *         Initialize the FPU setting and  vector table location
+  *         configuration.
+  * @param  None
+  * @retval None
+void SystemInit (void)
+#if defined (DATA_IN_D2_SRAM)
+ __IO uint32_t tmpreg;
+#endif /* DATA_IN_D2_SRAM */
+  /* FPU settings ------------------------------------------------------------*/
+  #if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
+    SCB->CPACR |= ((3UL << (10*2))|(3UL << (11*2)));  /* set CP10 and CP11 Full Access */
+  #endif
+  /* Reset the RCC clock configuration to the default reset state ------------*/
+  /* Set HSION bit */
+  RCC->CR |= RCC_CR_HSION;
+  /* Reset CFGR register */
+  RCC->CFGR = 0x00000000;
+  /* Reset HSEON, CSSON , CSION,RC48ON, CSIKERON PLL1ON, PLL2ON and PLL3ON bits */
+  RCC->CR &= 0xEAF6ED7FU;
+#if defined(D3_SRAM_BASE)
+  /* Reset D1CFGR register */
+  RCC->D1CFGR = 0x00000000;
+  /* Reset D2CFGR register */
+  RCC->D2CFGR = 0x00000000;
+  /* Reset D3CFGR register */
+  RCC->D3CFGR = 0x00000000;
+#else
+  /* Reset CDCFGR1 register */
+  RCC->CDCFGR1 = 0x00000000;
+  /* Reset CDCFGR2 register */
+  RCC->CDCFGR2 = 0x00000000;
+  /* Reset SRDCFGR register */
+  RCC->SRDCFGR = 0x00000000;
+#endif
+  /* Reset PLLCKSELR register */
+  RCC->PLLCKSELR = 0x00000000;
+  /* Reset PLLCFGR register */
+  RCC->PLLCFGR = 0x00000000;
+  /* Reset PLL1DIVR register */
+  RCC->PLL1DIVR = 0x00000000;
+  /* Reset PLL1FRACR register */
+  RCC->PLL1FRACR = 0x00000000;
+  /* Reset PLL2DIVR register */
+  RCC->PLL2DIVR = 0x00000000;
+  /* Reset PLL2FRACR register */
+  RCC->PLL2FRACR = 0x00000000;
+  /* Reset PLL3DIVR register */
+  RCC->PLL3DIVR = 0x00000000;
+  /* Reset PLL3FRACR register */
+  RCC->PLL3FRACR = 0x00000000;
+  /* Reset HSEBYP bit */
+  RCC->CR &= 0xFFFBFFFFU;
+  /* Disable all interrupts */
+  RCC->CIER = 0x00000000;
+#if (STM32H7_DEV_ID == 0x450UL)
+  /* dual core CM7 or single core line */
+  if((DBGMCU->IDCODE & 0xFFFF0000U) < 0x20000000U)
+    /* if stm32h7 revY*/
+    /* Change  the switch matrix read issuing capability to 1 for the AXI SRAM target (Target 7) */
+    *((__IO uint32_t*)0x51008108) = 0x000000001U;
+#endif
+#ifndef __rtems__
+  /* in case of initialized data in D2 SRAM (AHB SRAM) , enable the D2 SRAM clock (AHB SRAM clock) */
+#if defined(RCC_AHB2ENR_D2SRAM3EN)
+  RCC->AHB2ENR |= (RCC_AHB2ENR_D2SRAM1EN | RCC_AHB2ENR_D2SRAM2EN | RCC_AHB2ENR_D2SRAM3EN);
+#elif defined(RCC_AHB2ENR_D2SRAM2EN)
+  RCC->AHB2ENR |= (RCC_AHB2ENR_D2SRAM1EN | RCC_AHB2ENR_D2SRAM2EN);
+#else
+  RCC->AHB2ENR |= (RCC_AHB2ENR_AHBSRAM1EN | RCC_AHB2ENR_AHBSRAM2EN);
+#endif /* RCC_AHB2ENR_D2SRAM3EN */
+  tmpreg = RCC->AHB2ENR;
+  (void) tmpreg;
+  RCC->AHB2ENR;
+#ifndef __rtems__
+#if defined(DUAL_CORE) && defined(CORE_CM4)
+  /* Configure the Vector Table location add offset address for cortex-M4 ------------------*/
+#ifdef VECT_TAB_SRAM
+  SCB->VTOR = D2_AHBSRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM */
+#else
+  SCB->VTOR = FLASH_BANK2_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
+#endif /* VECT_TAB_SRAM */
+#else
+  /* Configure the Vector Table location add offset address for cortex-M7 ------------------*/
+  SCB->VTOR = D1_AXISRAM_BASE  | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal AXI-RAM */
+#else
+  SCB->VTOR = FLASH_BANK1_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH */
+#endif
+#endif /*DUAL_CORE && CORE_CM4*/
+  SCB->VTOR = (uint32_t) bsp_start_vector_table_begin;
+   * @brief  Update SystemCoreClock variable according to Clock Register Values.
+  *         The SystemCoreClock variable contains the core clock , it can
+  *         be used by the user application to setup the SysTick timer or configure
+  *         other parameters.
+  * @note   Each time the core clock changes, this function must be called
+  *         to update SystemCoreClock variable value. Otherwise, any configuration
+  *         based on this variable will be incorrect.
+  * @note   - The system frequency computed by this function is not the real
+  *           frequency in the chip. It is calculated based on the predefined
+  *           constant and the selected clock source:
+  *           - If SYSCLK source is CSI, SystemCoreClock will contain the CSI_VALUE(*)
+  *           - If SYSCLK source is HSI, SystemCoreClock will contain the HSI_VALUE(**)
+  *           - If SYSCLK source is HSE, SystemCoreClock will contain the HSE_VALUE(***)
+  *           - If SYSCLK source is PLL, SystemCoreClock will contain the CSI_VALUE(*),
+  *             HSI_VALUE(**) or HSE_VALUE(***) multiplied/divided by the PLL factors.
+  *         (*) CSI_VALUE is a constant defined in stm32h7xx_hal.h file (default value
+  *             4 MHz) but the real value may vary depending on the variations
+  *             in voltage and temperature.
+  *         (**) HSI_VALUE is a constant defined in stm32h7xx_hal.h file (default value
+  *             64 MHz) but the real value may vary depending on the variations
+  *         (***)HSE_VALUE is a constant defined in stm32h7xx_hal.h file (default value
+  *              25 MHz), user has to ensure that HSE_VALUE is same as the real
+  *              frequency of the crystal used. Otherwise, this function may
+  *              have wrong result.
+  *         - The result of this function could be not correct when using fractional
+  *           value for HSE crystal.
+  * @param  None
+  * @retval None
+void SystemCoreClockUpdate (void)
+  uint32_t pllp, pllsource, pllm, pllfracen, hsivalue, tmp;
+  uint32_t common_system_clock;
+  float_t fracn1, pllvco;
+  /* Get SYSCLK source -------------------------------------------------------*/
+  switch (RCC->CFGR & RCC_CFGR_SWS)
+  case RCC_CFGR_SWS_HSI:  /* HSI used as system clock source */
+    common_system_clock = (uint32_t) (HSI_VALUE >> ((RCC->CR & RCC_CR_HSIDIV)>> 3));
+    break;
+  case RCC_CFGR_SWS_CSI:  /* CSI used as system clock  source */
+    common_system_clock = CSI_VALUE;
+    break;
+  case RCC_CFGR_SWS_HSE:  /* HSE used as system clock  source */
+    common_system_clock = HSE_VALUE;
+    break;
+  case RCC_CFGR_SWS_PLL1:  /* PLL1 used as system clock  source */
+    /* PLL_VCO = (HSE_VALUE or HSI_VALUE or CSI_VALUE/ PLLM) * PLLN
+    SYSCLK = PLL_VCO / PLLR
+    pllsource = (RCC->PLLCKSELR & RCC_PLLCKSELR_PLLSRC);
+    pllm = ((RCC->PLLCKSELR & RCC_PLLCKSELR_DIVM1)>> 4)  ;
+    pllfracen = ((RCC->PLLCFGR & RCC_PLLCFGR_PLL1FRACEN)>>RCC_PLLCFGR_PLL1FRACEN_Pos);
+    fracn1 = (float_t)(uint32_t)(pllfracen* ((RCC->PLL1FRACR & RCC_PLL1FRACR_FRACN1)>> 3));
+    if (pllm != 0U)
+      switch (pllsource)
+        case RCC_PLLCKSELR_PLLSRC_HSI:  /* HSI used as PLL clock source */
+        hsivalue = (HSI_VALUE >> ((RCC->CR & RCC_CR_HSIDIV)>> 3)) ;
+        pllvco = ( (float_t)hsivalue / (float_t)pllm) * ((float_t)(uint32_t)(RCC->PLL1DIVR & RCC_PLL1DIVR_N1) + (fracn1/(float_t)0x2000) +(float_t)1 );
+        break;
+        case RCC_PLLCKSELR_PLLSRC_CSI:  /* CSI used as PLL clock source */
+          pllvco = ((float_t)CSI_VALUE / (float_t)pllm) * ((float_t)(uint32_t)(RCC->PLL1DIVR & RCC_PLL1DIVR_N1) + (fracn1/(float_t)0x2000) +(float_t)1 );
+        break;
+        case RCC_PLLCKSELR_PLLSRC_HSE:  /* HSE used as PLL clock source */
+          pllvco = ((float_t)HSE_VALUE / (float_t)pllm) * ((float_t)(uint32_t)(RCC->PLL1DIVR & RCC_PLL1DIVR_N1) + (fracn1/(float_t)0x2000) +(float_t)1 );
+        break;
+      default:
+        break;
+      pllp = (((RCC->PLL1DIVR & RCC_PLL1DIVR_P1) >>9) + 1U ) ;
+      common_system_clock =  (uint32_t)(float_t)(pllvco/(float_t)pllp);
+    else
+      common_system_clock = 0U;
+    break;
+  default:
+    break;
+  /* Compute SystemClock frequency --------------------------------------------------*/
+#if defined (RCC_D1CFGR_D1CPRE)
+  tmp = D1CorePrescTable[(RCC->D1CFGR & RCC_D1CFGR_D1CPRE)>> RCC_D1CFGR_D1CPRE_Pos];
+  /* common_system_clock frequency : CM7 CPU frequency  */
+  common_system_clock >>= tmp;
+  /* SystemD2Clock frequency : CM4 CPU, AXI and AHBs Clock frequency  */
+  SystemD2Clock = (common_system_clock >> ((D1CorePrescTable[(RCC->D1CFGR & RCC_D1CFGR_HPRE)>> RCC_D1CFGR_HPRE_Pos]) & 0x1FU));
+#else
+  tmp = D1CorePrescTable[(RCC->CDCFGR1 & RCC_CDCFGR1_CDCPRE)>> RCC_CDCFGR1_CDCPRE_Pos];
+  /* SystemD2Clock frequency : AXI and AHBs Clock frequency  */
+  SystemD2Clock = (common_system_clock >> ((D1CorePrescTable[(RCC->CDCFGR1 & RCC_CDCFGR1_HPRE)>> RCC_CDCFGR1_HPRE_Pos]) & 0x1FU));
+#endif
+  SystemCoreClock = SystemD2Clock;
+#else
+  SystemCoreClock = common_system_clock;
+#endif /* DUAL_CORE && CORE_CM4 */
+/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
diff --git a/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml b/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml
index 9213500172..1cad10b39d 100644
--- a/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml
+++ b/spec/build/bsps/arm/stm32h7/bspnucleoh743zi.yml
@@ -14,9 +14,9 @@ links:
 - role: build-dependency
   uid: grp
 source:
-- bsps/arm/stm32h7/start/stm32h7-config-clk.c
-- bsps/arm/stm32h7/start/stm32h7-config-osc.c
-- bsps/arm/stm32h7/start/stm32h7-config-per.c
-- bsps/arm/stm32h7/start/system_stm32h7xx.c
-- bsps/arm/stm32h7/start/ext-mem-ctl.c
+- bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-clk.c
+- bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-osc.c
+- bsps/arm/stm32h7/boards/stm/nucleo-h743zi/stm32h7-config-per.c
+- bsps/arm/stm32h7/boards/stm/nucleo-h743zi/system_stm32h7xx.c
+- bsps/arm/stm32h7/boards/stm/nucleo-h743zi/ext-mem-ctl.c
 type: build
2.25.1
