> Hello Gabriel, > > I get a test failure in spntp01 now using the sparc/gr740 and arm/xilinx_zynq_a9_qemu BSP: > > F:23:0:UI1:init.c:84:2 == 0 > > Did you observe this test failure also? > Yes, thanks for noticing it. It is due the changes in [PATCH v3 09/11]. The default value for pps_shift is PPS_FAVG which is equals to 2.
