[PATCH] sb/setbuilder: Control buildsets using the --with-* command line option
chrisj at rtems.org
chrisj at rtems.org
Thu May 5 02:52:53 UTC 2022
- Expand macros in buildset file names
- Add support to buildsets for `%defineifnot`
- Update 6 and 7 to support command line build overrides
Closes #4646
rtems/config/6/rtems-default.bset | 23 +++++++++---------
rtems/config/7/rtems-default.bset | 26 ++++++++++++---------
rtems/config/tools/rtems-default-tools.bset | 15 ++++++++++++
source-builder/sb/setbuilder.py | 22 +++++++++++------
4 files changed, 57 insertions(+), 29 deletions(-)
create mode 100644 rtems/config/tools/rtems-default-tools.bset
diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
index 731c9d8..cee9091 100644
--- a/rtems/config/6/rtems-default.bset
+++ b/rtems/config/6/rtems-default.bset
@@ -4,16 +4,17 @@
%include 6/rtems-base.bset
-# Build gdb first to raise the Python install error as early as possible.
-# GDB needs expat so it needs to be built before.
+# Default RTEMS build. Override on the command line to the
+# the RSB. For example to test the latest version of gcc use:
+# --with-rtems-gcc=tools/rtems-gcc-head-newlib-head
+%defineifnot with_rtems_dtc devel/dtc-1.6.1-1
+%defineifnot with_rtems_expat devel/expat-2.4.8-1
+%defineifnot with_rtems_gmp devel/gmp-6.2.1
+%defineifnot with_rtems_gdb tools/rtems-gdb-11.2
+%defineifnot with_rtems_binutils tools/rtems-binutils-2.38
+%defineifnot with_rtems_gcc tools/rtems-gcc-10-newlib-head
+%defineifnot with_rtems_tools tools/rtems-tools-6
-devel/dtc-1.6.1-1
-devel/expat-2.4.8-1
-devel/gmp-6.2.1
-tools/rtems-gdb-11.2
-tools/rtems-binutils-2.38
-tools/rtems-gcc-10-newlib-head
-tools/rtems-tools-6
+tools/rtems-default-tools.bset
diff --git a/rtems/config/7/rtems-default.bset b/rtems/config/7/rtems-default.bset
index e94cf21..0a8fcac 100644
--- a/rtems/config/7/rtems-default.bset
+++ b/rtems/config/7/rtems-default.bset
@@ -1,16 +1,20 @@
+# Default tools configuration.
%include 7/rtems-base.bset
+%defineifnot with_rtems_gdb tools/rtems-gdb-head
+%defineifnot with_rtems_binutils tools/rtems-binutils-head
+%defineifnot with_rtems_gcc tools/rtems-gcc-head-newlib-head
-devel/dtc-1.6.1-1
-devel/gmp-6.2.1
-tools/rtems-gdb-head
-tools/rtems-binutils-head
-tools/rtems-gcc-head-newlib-head
diff --git a/rtems/config/tools/rtems-default-tools.bset b/rtems/config/tools/rtems-default-tools.bset
new file mode 100644
index 0000000..7d273cf
--- /dev/null
+++ b/rtems/config/tools/rtems-default-tools.bset
@@ -0,0 +1,15 @@
+# Default tools build
+# Build gdb first to raise the Python install error as early as
+# possible. GDB needs expat so it needs to be built before gdb.
+%{with_rtems_dtc}
+%{with_rtems_expat}
+%{with_rtems_gmp}
+%{with_rtems_gdb}
+%{with_rtems_binutils}
+%{with_rtems_gcc}
+%{with_rtems_tools}
diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
index 63392fe..4d6ca81 100644
--- a/source-builder/sb/setbuilder.py
+++ b/source-builder/sb/setbuilder.py
@@ -284,6 +284,7 @@ class buildset:
line = line[1:b]
return line.strip()
+ bset = macro_expand(self.macros, bset)
bsetname = bset
if not path.exists(bsetname):
@@ -315,15 +316,22 @@ class buildset:
if ls[0][-1] == ':' and ls[0][:-1] == 'package':
self.bset_pkg = ls[1].strip()
self.macros['package'] = self.bset_pkg
- elif ls[0][0] == '%':
+ elif ls[0][0] == '%' and (len(ls[0]) > 1 and ls[0][1] != '{'):
def err(msg):
raise error.general('%s:%d: %s' % (self.bset, lc, msg))
- if ls[0] == '%define':
+ if ls[0] == '%define' or ls[0] == '%defineifnot' :
+ name = ls[1].strip()
+ value = None
if len(ls) > 2:
- self.macros.define(ls[1].strip(),
- ' '.join([f.strip() for f in ls[2:]]))
- else:
- self.macros.define(ls[1].strip())
+ value = ' '.join([f.strip() for f in ls[2:]])
+ if ls[0] == '%defineifnot':
+ if self.macros.defined(name):
+ name = None
+ if name is not None:
+ if value is not None:
+ self.macros.define(name, value)
+ else:
+ self.macros.define(name)
elif ls[0] == '%undefine':
if len(ls) > 2:
raise error.general('%s:%d: %undefine requires ' \
@@ -336,7 +344,7 @@ class buildset:
elif ls[0] == '%hash':
sources.hash(ls[1:], self.macros, err)
else:
- l = l.strip()
+ l = macro_expand(self.macros, l.strip())
c = build.find_config(l, self.configs)
if c is None:
raise error.general('%s:%d: cannot find file: %s' % (self.bset,
2.24.1
