[PATCH] bsp/arm: allocate .rtemsstack on REGION_STACK instead of on REGION_WORK
Sebastian Huber
Thu May 19 07:03:51 UTC 2022
On 19/05/2022 08:59, Karel Gardas wrote:
> On 5/19/22 08:53, Sebastian Huber wrote:
>> On 07/04/2022 21:15, Karel Gardas wrote:
>>> REGION_WORK may be backed by external RAM which may not be initialized
>>> in a time we need stack to work well. E.g. code loaded in flash,
>>> stack allocated on in-cpu SRAM and data (REGION_WORK) on external SDRAM.
>>> Sponsored-By: Precidata
>> This change could have an impact if test programs can be linked or
>> not. We have to build all arm BSPs to check this.
> Thanks for looking into it! "We have to", that means who exactly? Does
> RTEMS do have CI in place to be able to check for that when committed?
> Or am I responsible for proving it? Or anybody else?
I will build the arm BSPs with your patch and see what happens to the
tests programs.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
