[PATCH] bsp/arm: allocate .rtemsstack on REGION_STACK instead of on REGION_WORK
Mon May 23 06:37:35 UTC 2022
On 19/05/2022 09:03, Sebastian Huber wrote:
> On 19/05/2022 08:59, Karel Gardas wrote:
>> On 5/19/22 08:53, Sebastian Huber wrote:
>>> On 07/04/2022 21:15, Karel Gardas wrote:
>>>> REGION_WORK may be backed by external RAM which may not be initialized
>>>> in a time we need stack to work well. E.g. code loaded in flash,
>>>> stack allocated on in-cpu SRAM and data (REGION_WORK) on external
>>>> SDRAM.
>>>> Sponsored-By:    Precidata
>>> This change could have an impact if test programs can be linked or
>>> not. We have to build all arm BSPs to check this.
>> Thanks for looking into it! "We have to", that means who exactly? Does
>> RTEMS do have CI in place to be able to check for that when committed?
>> Or am I responsible for proving it? Or anybody else?
> I will build the arm BSPs with your patch and see what happens to the
> tests programs.
I didn't observe new linker errors in the tests, so I checked in the patch.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
