[PATCH v4 04/11] kern_tc.c: Replace FreeBSD event mechanism by adding pointers to function
Gabriel Moyano gabriel.moyano at dlr.de
Fri May 20 09:29:56 UTC 2022
 cpukit/include/sys/timepps.h | 24 +++++++++++++++++++++
 cpukit/score/src/kern_tc.c   | 41 ++++++++++++++++++++++++++++++++++++
 2 files changed, 65 insertions(+)
diff --git a/cpukit/include/sys/timepps.h b/cpukit/include/sys/timepps.h
index 5703381ffa..2513298557 100644
--- a/cpukit/include/sys/timepps.h
+++ b/cpukit/include/sys/timepps.h
@@ -164,6 +164,30 @@ struct pps_state {
 	int		ppscap;
 	struct timecounter *ppstc;
 	unsigned	ppscount[3];
+#ifdef __rtems__
+	 * @brief  Wait for an event.
+	 * Called internally when time_pps_fetch() is used.
+	 * It is initialized by pps_init() to a handler which just returns ETIMEDOUT.
+	 * @param pps is the pointer to the object.
+	 * @param timeout
+	 * @retval 0 A wakeup event was received.
+	 * @retval ETIMEDOUT A timeout occurred while waiting for the event.
+	int (*wait)(struct pps_state *pps, struct timespec timeout);
+	 * @brief Wakeup the tasks waiting for an event.
+	void (*wakeup)(struct pps_state *pps);
+#endif /* __rtems__ */
 	 * The following fields are valid if the driver calls pps_init_abi().
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index f7d0a0b4ba..c22ce121a4 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -1917,9 +1917,15 @@ abi_aware(struct pps_state *pps, int vers)
 static int
 pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
+#ifndef __rtems__
 	int err, timo;
+#else /* __rtems__ */
+	int err;
 	pps_seq_t aseq, cseq;
+#ifndef __rtems__
 	struct timeval tv;
 	if (fapi->tsformat && fapi->tsformat != PPS_TSFMT_TSPEC)
 		return (EINVAL);
@@ -1932,6 +1938,7 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
 	 * sleep a long time.
 	if (fapi->timeout.tv_sec || fapi->timeout.tv_nsec) {
+#ifndef __rtems__
 		if (fapi->timeout.tv_sec == -1)
 			timo = 0x7fffffff;
 		else {
@@ -1939,10 +1946,12 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
 			tv.tv_usec = fapi->timeout.tv_nsec / 1000;
 			timo = tvtohz(&tv);
 		aseq = atomic_load_int(&pps->ppsinfo.assert_sequence);
 		cseq = atomic_load_int(&pps->ppsinfo.clear_sequence);
 		while (aseq == atomic_load_int(&pps->ppsinfo.assert_sequence) &&
 		    cseq == atomic_load_int(&pps->ppsinfo.clear_sequence)) {
+#ifndef __rtems__
 			if (abi_aware(pps, 1) && pps->driver_mtx != NULL) {
 				if (pps->flags & PPSFLAG_MTX_SPIN) {
 					err = msleep_spin(pps, pps->driver_mtx,
@@ -1963,6 +1972,11 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
 			} else if (err != 0) {
 				return (err);
+			_Assert(pps->wait != NULL);
+			err = (*pps->wait)(pps, fapi->timeout);
+			return (err);
@@ -2058,9 +2072,31 @@ pps_ioctl(u_long cmd, caddr_t data, struct pps_state *pps)
+#ifdef __rtems__
+static int
+default_wait(struct pps_state *pps, struct timespec timeout)
+	(void)pps;
+	(void)timeout;
+	return (ETIMEDOUT);
+static void
+default_wakeup(struct pps_state *pps)
+	(void)pps;
 void
 pps_init(struct pps_state *pps)
+#ifdef __rtems__
+	pps->wait = default_wait;
+	pps->wakeup = default_wakeup;
 	pps->ppscap |= PPS_TSFMT_TSPEC | PPS_CANWAIT;
 	if (pps->ppscap & PPS_CAPTUREASSERT)
 		pps->ppscap |= PPS_OFFSETASSERT;
@@ -2227,7 +2263,12 @@ pps_event(struct pps_state *pps, int event)
 #endif
 	/* Wakeup anyone sleeping in pps_fetch().  */
+#ifndef __rtems__
 	wakeup(pps);
+	_Assert(pps->wakeup != NULL);
+	(*pps->wakeup)(pps);
 /* FIXME: https://devel.rtems.org/ticket/2349 */
2.25.1
