[PATCH v4 05/11] timecounter.h: Rename tc_getfrequency() to _Timecounter_Get_frequency()
Gabriel Moyano gabriel.moyano at dlr.de
Fri May 20 09:29:57 UTC 2022
 cpukit/include/rtems/score/timecounter.h | 8 ++++++++
 cpukit/include/sys/timetc.h              | 3 +++
 cpukit/score/src/kern_tc.c               | 2 +-
 3 files changed, 12 insertions(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/score/timecounter.h b/cpukit/include/rtems/score/timecounter.h
index 1ecfc02085..fdade06128 100644
--- a/cpukit/include/rtems/score/timecounter.h
+++ b/cpukit/include/rtems/score/timecounter.h
@@ -292,6 +292,14 @@ void _Timecounter_Set_NTP_update_second(
 void _Timecounter_NTP_update_second(int64_t *adjustment, time_t *newsec);
+ * @brief Get the frequency in Hz of the current timecounter at some time point
+ * during the call.
+ * @return the frequency in Hz.
+uint64_t _Timecounter_Get_frequency(void);
 #ifdef __cplusplus
diff --git a/cpukit/include/sys/timetc.h b/cpukit/include/sys/timetc.h
index 5cdfdfe9b3..7cc3284b4d 100644
--- a/cpukit/include/sys/timetc.h
+++ b/cpukit/include/sys/timetc.h
@@ -36,6 +36,7 @@ struct vdso_timehands32;
 typedef u_int timecounter_get_t(struct timecounter *);
 #else /* __rtems__ */
 typedef uint32_t timecounter_get_t(struct timecounter *);
+#define tc_getfrequency _Timecounter_Get_frequency
 #endif /* __rtems__ */
 typedef void timecounter_pps_t(struct timecounter *);
 typedef uint32_t timecounter_fill_vdso_timehands_t(struct vdso_timehands *,
@@ -94,7 +95,9 @@ extern int tc_min_ticktock_freq; /*
 				  * required to handle counter wraps.
+#ifndef __rtems__
 u_int64_t tc_getfrequency(void);
+#endif /* __rtems__ */
 void	tc_init(struct timecounter *tc);
 void	tc_setclock(struct timespec *ts);
 void	tc_ticktock(int cnt);
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index c22ce121a4..2e2ffd8ef1 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -1513,7 +1513,6 @@ unlock:
-#ifndef __rtems__
 /* Report the frequency of the current timecounter. */
 uint64_t
@@ -1522,6 +1521,7 @@ tc_getfrequency(void)
 	return (timehands->th_counter->tc_frequency);
+#ifndef __rtems__
 static bool
 sleeping_on_old_rtc(struct thread *td)
2.25.1
