[libbsd 02/22] README.md: Update to RTEMS 6
Sebastian Huber
Mon May 23 14:33:25 UTC 2022
README.md | 93 ++++++++++++++++++++++---------------------------------
1 file changed, 37 insertions(+), 56 deletions(-)
diff --git a/README.md b/README.md
index d12aeb7b..d1c4a5b0 100644
--- a/README.md
+++ b/README.md
@@ -8,23 +8,22 @@ package is designed to be updated from the FreeBSD kernel sources and contains
more than just the networking code.
To build this package you need a current RTEMS tool set for your architecture,
-and a recent RTEMS kernel for your BSP configured with networking disabled
-built and installed. If you already have this you can skip to step 3 of the
-build procedure.
+and a recent RTEMS kernel for your BSP installed. If you already have this, you
+can skip to step 5 of the build procedure.
Building and Installing LibBSD
-The following instructions show you how to build and install RTEMS Tools and
-RTEMS kernel for your BSP in separate paths. Using separate paths for the tools
-and BSPs lets you manage what you have installed. If you are happy with a
-single path you can use the same path in each stage.
+The following instructions show you how to build and install the RTEMS Tool
+Suite for the `arm` target, the RTEMS kernel using the
+`arm/xilinx_zynq_a9_qemu` Board Support Package (BSP), and the LibBSD for this
+BSP.
The Waf build support for RTEMS requires you provide your BSP name as an
architecture and BSP pair. You must provide both or Waf will generate an error
message during the configure phase.
-We will build an Xilinx Zynq QEMU BSP using the name
+We will build an Xilinx Zynq Qemu BSP using the name
*arm/xilinx_zynq_a9_qemu*. You can copy and paste the shell commands below to
do this. The individual steps are explained afterwards.
@@ -37,30 +36,23 @@ git clone git://git.rtems.org/rtems.git
git clone git://git.rtems.org/rtems-libbsd.git
cd "$sandbox"
cd rtems-source-builder/rtems
-../source-builder/sb-set-builder --prefix="$sandbox/rtems/5" 5/rtems-arm
+../source-builder/sb-set-builder --prefix="$sandbox/rtems/6" 6/rtems-arm
cd "$sandbox"
cd rtems
-PATH="$sandbox/rtems/5/bin:$PATH" ./bootstrap
-cd "$sandbox"
-mkdir b-xilinx_zynq_a9_qemu
-cd b-xilinx_zynq_a9_qemu
-PATH="$sandbox/rtems/5/bin:$PATH" "$sandbox/rtems/configure" \
- --target=arm-rtems5 --prefix="$sandbox/rtems/5" \
- --disable-networking --enable-rtemsbsp=xilinx_zynq_a9_qemu
-PATH="$sandbox/rtems/5/bin:$PATH" make
-PATH="$sandbox/rtems/5/bin:$PATH" make install
+echo -e "[arm/xilinx_zynq_a9_qemu]\nRTEMS_POSIX_API = True" > config.ini
+./waf configure --prefix "$sandbox/rtems/6"
+./waf
+./waf install
cd "$sandbox"
cd rtems-libbsd
git submodule init
git submodule update rtems_waf
-./waf configure --prefix="$sandbox/rtems/5" \
+./waf configure --prefix="$sandbox/rtems/6" \
--rtems-bsps=arm/xilinx_zynq_a9_qemu \
--buildset=buildset/default.ini
./waf
./waf install
-qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none \
- -nographic -M xilinx-zynq-a9 -m 256M \
- -kernel build/arm-rtems5-xilinx_zynq_a9_qemu-default/selectpollkqueue01.exe
+../rtems/6/bin/rtems-test --rtems-bsp=xilinx_zynq_a9_qemu build
1. Create a sandbox directory:
@@ -84,31 +76,21 @@ $ git clone git://git.rtems.org/rtems-libbsd.git
$ cd "$sandbox"
$ cd rtems-source-builder/rtems
-$ ../source-builder/sb-set-builder --prefix="$sandbox/rtems/5" 5/rtems-arm
+$ ../source-builder/sb-set-builder --prefix="$sandbox/rtems/6" 6/rtems-arm
-4. Bootstrap the RTEMS sources:
+4. Build and install the RTEMS Board Support Packages (BSP) you want to use:
$ cd "$sandbox"
$ cd rtems
-$ PATH="$sandbox/rtems/5/bin:$PATH" ./bootstrap
-5. Build and install the RTEMS Board Support Packages (BSP) you want to use:
-$ cd "$sandbox"
-$ mkdir b-xilinx_zynq_a9_qemu
-$ cd b-xilinx_zynq_a9_qemu
-$ PATH="$sandbox/rtems/5/bin:$PATH" "$sandbox/rtems/configure" \
-$ PATH="$sandbox/rtems/5/bin:$PATH" make
-$ PATH="$sandbox/rtems/5/bin:$PATH" make install
+$ echo -e "[arm/xilinx_zynq_a9_qemu]\nRTEMS_POSIX_API = True" > config.ini
+$ ./waf configure --prefix "$sandbox/rtems/6"
+$ ./waf
+$ ./waf install
-6. Populate the rtems_waf git submodule. Note, make sure you specify
+5. Populate the rtems_waf git submodule. Note, make sure you specify
'rtems_waf' or the FreeBSD kernel source will be cloned:
@@ -118,7 +100,7 @@ $ git submodule init
$ git submodule update rtems_waf
-7. Run Waf's configure with your specific settings. In this case the path to
+6. Run Waf's configure with your specific settings. In this case the path to
the tools and RTEMS are provided on the command line and so do not need to
be in your path or environment [1]. You can use
'--rtems-archs=arm,sparc,i386' or
@@ -133,12 +115,12 @@ $ git submodule update rtems_waf
$ cd "$sandbox"
$ cd rtems-libbsd
-$ ./waf configure --prefix="$sandbox/rtems/5" \
+$ ./waf configure --prefix="$sandbox/rtems/6" \
-8. Build and install. The LibBSD package will be installed into the prefix
+7. Build and install. The LibBSD package will be installed into the prefix
provided to configure:
@@ -148,23 +130,22 @@ $ ./waf
$ ./waf install
-9. Run the tests on QEMU, for example using VDE:
+9. Run the tests:
-$ qemu-system-arm -no-reboot -serial null -serial mon:stdio \
- -net nic,model=cadence_gem -net vde,id=vde0,sock=/tmp/vde1 \
- -kernel build/arm-rtems5-xilinx_zynq_a9_qemu/selectpollkqueue01.exe
+$ cd "$sandbox"
+$ cd rtems-libbsd
+$ ../rtems/6/bin/rtems-test --rtems-bsp=xilinx_zynq_a9_qemu build
-[1] It is good practice to keep your environment as empty as possible. Setting
- paths to tools or specific values to configure or control a build is
- dangerous because settings can leak between different builds and change
- what you expect a build to do. The Waf tool used here lets you specify on
- the command line the tools and RTEMS paths and this is embedded in Waf's
- configuration information. If you have a few source trees working at any
- one time with different tool sets or configurations you can easly move
- between them safe in the knowledge that one build will not infect another.
+It is good practice to keep your environment as empty as possible. Setting
+paths to tools or specific values to configure or control a build is dangerous
+because settings can leak between different builds and change what you expect a
+build to do. The Waf tool used here lets you specify on the command line the
+tools and RTEMS paths and this is embedded in Waf's configuration information.
+If you have a few source trees working at any one time with different tool sets
+or configurations you can easly move between them safe in the knowledge that
+one build will not infect another.
Branches
@@ -273,7 +254,7 @@ qemu-system-arm -serial null -serial mon:stdio -nographic \
-net tap,ifname=qtap,script=no,downscript=no \
-net nic,model=cadence_gem,macaddr=0e:b0:ba:5e:ba:12 \
- -kernel build/arm-rtems5-xilinx_zynq_a9_qemu-default/media01.exe
+ -kernel build/arm-rtems6-xilinx_zynq_a9_qemu-default/media01.exe
After some seconds it will acquire a IPv4 link-local address, e.g.
2.35.3
