[libbsd 03/22] README.md: Move SMP Requirements section
Sebastian Huber
Mon May 23 14:33:26 UTC 2022
README.md | 18 +++++++++---------
1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/README.md b/README.md
index d1c4a5b0..63711770 100644
--- a/README.md
+++ b/README.md
@@ -221,6 +221,15 @@ To enable kernel internal consistency checking use:
--freebsd-options=invariants,invariant_support
+SMP Requirements
+In order to support
+[EPOCH(9)](https://www.freebsd.org/cgi/man.cgi?query=epoch&apropos=0&sektion=9)
+a scheduler with thread pinning support is required. This is the case if you
+use the default scheduler configuration. EPOCH(9) is a central synchronization
+mechanism of the network stack.
Qemu and Networking
@@ -275,12 +284,3 @@ Escape character is '^]'.
RTEMS Shell on /dev/pty4. Use 'help' to list commands.
TLNT [/] #
-SMP Requirements
-In order to support
-[EPOCH(9)](https://www.freebsd.org/cgi/man.cgi?query=epoch&apropos=0&sektion=9)
-a scheduler with thread pinning support is required. This is the case if you
-use the default scheduler configuration. EPOCH(9) is a central synchronization
-mechanism of the network stack.
2.35.3
