[libbsd 16/22] libbsd.txt: Remove NIC status
Mon May 23 14:33:39 UTC 2022
Details like this should be described in the BSP documentation of the
User Manual.
 libbsd.txt | 43 -------------------------------------------
 1 file changed, 43 deletions(-)
diff --git a/libbsd.txt b/libbsd.txt
index cb8111bf..4b22cec8 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -321,49 +321,6 @@ structure that were not being used were conditionally compiled out. The
 capability of supporting children did not appear to be needed and was
 not implemented in the rtems version of these routines.
-== NICs Status ==
-Driver			Symbol				Status
-RealTek			_bsd_re_pcimodule_sys_init	Links
-EtherExpress		_bsd_fxp_pcimodule_sys_init	Links
-DEC tulip		_bsd_dc_pcimodule_sys_init	Links
-Broadcom BCM57xxx	_bsd_bce_pcimodule_sys_init	Links
-Broadcom BCM4401	_bsd_bfe_pcimodule_sys_init	Links
-Broadcom BCM570x 	_bsd_bge_pcimodule_sys_init	Needs Symbols (A)
-E1000 IGB 		_bsd_igb_pcimodule_sys_init	Links
-E1000 EM		_bsd_em_pcimodule_sys_init	Links
-Cadence			?				Links, works.
-To add a NIC edit rtemsbsd/include/bsp/nexus-devices.h and add the driver
-reference to the architecture and/or BSP. For example to add the RealTek driver
-add:
-SYSINIT_DRIVER_REFERENCE(re, pci);
-and to add the MII PHY driver add:
-SYSINIT_DRIVER_REFERENCE(rge, miibus);
-The PC BSP has these entries.
-Symbols (A)
-         pci_get_vpd_ident
-=== Cadence ===
-The cadence driver works on the Xilinx Zynq platform. The hardware checksum
-support works on real hardware but does not seem to be supported on qemu
-therefore the default state is to disable TXCSUM and RXCSUM and this can be
-enabled from the shell with:
-  # ifconfig cgem0 rxcsum txcsum
-or with an ioctl call to the network interface driver with SIOCSIFCAP and the
-mask IFCAP_TXCSUM and IFCAP_RXCSUM set.
 == PF (Firewall) ==
 It is possible to use PF as a firewall. See
2.35.3
