[libbsd 15/22] libbsd.txt: Move ported kernel features
Sebastian Huber
Mon May 23 14:33:38 UTC 2022
Remove obsolete file listing.
CONTRIBUTING.rst | 23 ++++
libbsd.txt | 291 -----------------------------------------------
2 files changed, 23 insertions(+), 291 deletions(-)
diff --git a/CONTRIBUTING.rst b/CONTRIBUTING.rst
index 1113136c..c1268121 100644
--- a/CONTRIBUTING.rst
+++ b/CONTRIBUTING.rst
@@ -430,3 +430,26 @@ DHCPCD(8) client is a consumer of these events for example. Make sure that the
interface flag ``IFF_UP`` and the interface driver flag ``IFF_DRV_RUNNING`` is
set in case the link is up, otherwise ``ether_output()`` will return the error
status ``ENETDOWN``.
+FreeBSD Kernel Features Ported to LibBSD
+All lock based synchronization primitives are implemented through mutexes using
+the priority inheritance protocol.
+* `BUS_DMA(9) <http://www.freebsd.org/cgi/man.cgi?query=bus_dma&sektion=9>`_: Bus and Machine Independent DMA Mapping Interface
+* `BUS_SPACE(9) <http://www.freebsd.org/cgi/man.cgi?query=bus_space&sektion=9>`_: Bus space manipulation functions
+* `CALLOUT(9) <http://www.freebsd.org/cgi/man.cgi?query=callout&sektion=9>`_: Execute a function after a specified length of time
+* `CONDVAR(9) <http://www.freebsd.org/cgi/man.cgi?query=condvar&sektion=9>`_: Kernel condition variable
+* `DEVICE(9) <http://www.freebsd.org/cgi/man.cgi?query=device&sektion=9>`_: An abstract representation of a device
+* `DRIVER(9) <http://www.freebsd.org/cgi/man.cgi?query=driver&sektion=9>`_: Structure describing a device driver
+* `EPOCH(9) <http://www.freebsd.org/cgi/man.cgi?query=epoch&sektion=9>`_: Kernel epoch based reclamation
+* `MUTEX(9) <http://www.freebsd.org/cgi/man.cgi?query=mutex&sektion=9>`_: Kernel synchronization primitives
+* `RMAN(9) <http://www.freebsd.org/cgi/man.cgi?query=rman&sektion=9>`_: Resource management functions
+* `RMLOCK(9) <http://www.freebsd.org/cgi/man.cgi?query=rmlock&sektion=9>`_: Kernel reader/writer lock optimized for read-mostly access patterns
+* `RWLOCK(9) <http://www.freebsd.org/cgi/man.cgi?query=rwlock&sektion=9>`_: Kernel reader/writer lock
+* `SX(9) <http://www.freebsd.org/cgi/man.cgi?query=sx&sektion=9>`_: Kernel shared/exclusive lock
+* `SYSCTL(9) <http://www.freebsd.org/cgi/man.cgi?query=SYSCTL_DECL&sektion=9>`_: Dynamic and static sysctl MIB creation functions
+* `SYSINIT(9) <http://www.freebsd.org/cgi/man.cgi?query=sysinit&sektion=9>`_: A framework for dynamic kernel initialization
+* `TASKQUEUE(9) <http://www.freebsd.org/cgi/man.cgi?query=taskqueue&sektion=9>`_: Asynchronous task execution
+* `UMA(9) <http://www.freebsd.org/cgi/man.cgi?query=uma&sektion=9>`_: General-purpose kernel object allocator
diff --git a/libbsd.txt b/libbsd.txt
index fc748f24..cb8111bf 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -298,66 +298,6 @@ SYSCTL_NODE(, CTL_KERN, kern, CTLFLAG_RW, 0,
"High kernel, proc, limits &c");
-== Core FreeBSD APIs and RTEMS Replacements ==
-=== SX(9) (Shared/exclusive locks) ===
-http://www.freebsd.org/cgi/man.cgi?query=sx
-Binary semaphores (this neglects the ability to allow shared access).
-=== MUTEX(9) (Mutual exclusion) ===
-http://www.freebsd.org/cgi/man.cgi?query=mutex
-Binary semaphores (not recursive mutexes are not supported this way).
-=== RWLOCK(9) (Reader/writer lock) ===
-http://www.freebsd.org/cgi/man.cgi?query=rwlock
-POSIX r/w lock.
-=== RMLOCK(9) (Reader/writer lock optimized for mostly read access patterns) ===
-Note: This object was implemented as a wrapper for RWLOCK in the rm_lock header file.
-http://www.freebsd.org/cgi/man.cgi?query=rmlock
-POSIX r/w lock.
-=== CONDVAR(9) (Condition variables) ===
-http://www.freebsd.org/cgi/man.cgi?query=condvar
-POSIX condition variables with modifications (hack).
-=== CALLOUT(9) (Timer functions) ===
-http://www.freebsd.org/cgi/man.cgi?query=callout
-Timer server.
-=== TASKQUEUE(9) (Asynchronous task execution) ===
-http://www.freebsd.org/cgi/man.cgi?query=taskqueue
-TBD.
-=== KTHREAD(9), KPROC(9) (Tasks) ===
-http://www.freebsd.org/cgi/man.cgi?query=kthread
-http://www.freebsd.org/cgi/man.cgi?query=kproc
-Tasks.
-=== ZONE(9) (Zone allocator) ===
-http://www.freebsd.org/cgi/man.cgi?query=zone
-TBD.
=== devfs (Device file system) ===
There is a minimal implementation based on IMFS. The mount point is fixed to
@@ -370,237 +310,6 @@ for the device.
TBD: remove empty paths on devfs_destroy().
-=== psignal (Signals) ===
-TBD. Seems to be not needed.
-=== poll, select ===
-=== RMAN(9) (Resource management) ===
-http://www.freebsd.org/cgi/man.cgi?query=rman
-=== DEVCLASS(9), DEVICE(9), DRIVER(9), MAKE_DEV(9) (Device management) ===
-http://www.freebsd.org/cgi/man.cgi?query=devclass
-http://www.freebsd.org/cgi/man.cgi?query=device
-http://www.freebsd.org/cgi/man.cgi?query=driver
-http://www.freebsd.org/cgi/man.cgi?query=make_dev
-Use FreeBSD implementation as far as possible. FreeBSD has a nice API for
-dynamic device handling. It may be interesting for RTEMS to use this API
-internally in the future.
-=== BUS_SPACE(9), BUS_DMA(9) (Bus and DMA access) ===
-http://www.freebsd.org/cgi/man.cgi?query=bus_space
-http://www.freebsd.org/cgi/man.cgi?query=bus_dma
-Likely BSP dependent. A default implementation for memory mapped linear access
-is easy to provide. The current heap implementation supports all properties
-demanded by bus_dma (including the boundary constraint).
-== RTEMS Replacements by File Description ==
-Note: Files with a status of USB are used by the USB test and have at least
-been partially tested. If they contain both USB and Nic, then they are used
-by both and MAY contain methods that have not been tested yet. Files that
-are only used by the Nic test are the most suspect.
-rtems-libbsd File: rtems-bsd-assert.c
-FreeBSD File: rtems-bsd-config.h redefines BSD_ASSERT.
-Description: This file contains the support method rtems_bsd_assert_func().
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-autoconf.c
-FreeBSD File: FreeBSD has BSP specific autoconf.c
-Description: This file contains configuration methods that are used to setup the system.
-Status: USB
-rtems-libbsd File: rtems-bsd-bus-dma.c
-FreeBSD File: FreeBSD has BSP specific busdma_machdep.c
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-bus-dma-mbuf.c
-Description:
-Status: Nic
-rtems-libbsd File: rtems-bsd-callout.c
-FreeBSD File: kern/kern_timeout.c
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-cam.c
-FreeBSD File: cam/cam_sim.c
-Description:
-Status: USB
-rtems-libbsd File: rtems-bsd-condvar.c
-FreeBSD File: kern/kern_condvar.c
-Description:
-Status: USB
-rtems-libbsd File: rtems-bsd-copyinout.c
-FreeBSD File: bsp specific copyinout.c )
-Description: Note: The FreeBSD file is split with some methods being in rtems-bsd-support
-Status: Nic
-rtems-libbsd File: rtems-bsd-delay.c
-FreeBSD File: bsp specific file with multiple names
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-descrip.c
-FreeBSD File: kern/kern_descrip.c
-Description:
-Status: Nic
-rtems-libbsd File: rtems-bsd-generic.c
-FreeBSD File: kern/sys_generic.c
-Description:
-Status: Nic
-rtems-libbsd File: rtems-bsd-init.c
-FreeBSD File: N/A
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-init-with-irq.c
-FreeBSD File: N/A
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-jail.c
-FreeBSD File: kern/kern_jail.c
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-lock.c
-FreeBSD File: kern/subr_lock.c
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-log.c
-FreeBSD File: kern/subr_prf.c
-Description:
-Status: Nic
-rtems-libbsd File: rtems-bsd-malloc.c
-FreeBSD File: kern/kern_malloc.c
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-mutex.c
-FreeBSD File: kern/kern_mutex.c
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-newproc.c
-FreeBSD File: N/A
-Description:
-Status: Nic
-rtems-libbsd File: rtems-bsd-nexus.c
-FreeBSD File: bsp specific nexus.c
-Description:
-Status: USB
-rtems-libbsd File: rtems-bsd-panic.c
-FreeBSD File: boot/common/panic.c
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-rwlock.c
-FreeBSD File: kern_rwlock.c
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-shell.c
-FreeBSD File: N/A
-Description:
-Status: USB
-rtems-libbsd File: rtems-bsd-signal.c
-FreeBSD File: kern/kern_sig.c
-Description:
-Status: Nic
-rtems-libbsd File: rtems-bsd-smp.c
-FreeBSD File: N/A
-Description:
-Status: Nic
-rtems-libbsd File: rtems-bsd-support.c
-Description: Note: the FreeBSD file is split with some methods being in rtems-bsd-copyinout.
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-sx.c
-FreeBSD File: kern/kern_sx.c
-Description: Status: USB, Nic
-rtems-libbsd File: rtems-bsd-synch.c
-FreeBSD File: kern/kern_synch.c
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-syscalls.c
-FreeBSD File: User API for kern/uipc_syscalls.c
-Description:
-Status: Nic
-rtems-libbsd File: rtems-bsd-sysctlbyname.c
-FreeBSD File: User API for sysctlbyname(3)
-Description:
-Status:
-rtems-libbsd File: rtems-bsd-sysctl.c
-FreeBSD File: User API for sysctl(8)
-Description:
-Status:
-rtems-libbsd File: rtems-bsd-sysctlnametomib.c
-FreeBSD File: User API for sysctlnametomib
-Description:
-Status:
-rtems-libbsd File: rtems-bsd-taskqueue.c
-FreeBSD File: kern/subr_taskqueue.c
-Description:
-Status: Nic
-rtems-libbsd File: rtems-bsd-thread.c
-FreeBSD File: kern/kern_kthread.c
-Description:
-Status: USB, Nic
-rtems-libbsd File: rtems-bsd-timeout.c
-Description:
-Status: Nic
-rtems-libbsd File: rtems-bsd-timesupport.c
-FreeBSD File: kern/kern_clock.c
-Description:
-Status: Nic
-rtems-libbsd File: rtems-bsd-vm_glue.c
-FreeBSD File: vm/vm_glue.c
-Description:
-Status: USB, Nic
== Notes by File ==
altq_subr.c - Arbitrary choices were made in this file that RTEMS would
2.35.3
