[libbsd 04/22] Convert *.md files to reST
Mon May 23 14:33:27 UTC 2022
The reST format is used by the standard RTEMS documentation.
 CONTRIBUTING.md => CONTRIBUTING.rst | 398 ++++++++++++++--------------
 README.md                           | 286 --------------------
 README.rst                          | 293 ++++++++++++++++++++
 3 files changed, 497 insertions(+), 480 deletions(-)
 rename CONTRIBUTING.md => CONTRIBUTING.rst (50%)
 delete mode 100644 README.md
 create mode 100644 README.rst
diff --git a/CONTRIBUTING.md b/CONTRIBUTING.rst
similarity index 50%
rename from CONTRIBUTING.md
rename to CONTRIBUTING.rst
index 57b05e42..8cfec7cd 100644
--- a/CONTRIBUTING.md
+++ b/CONTRIBUTING.rst
@@ -1,8 +1,8 @@
 Guidelines for Developing and Contributing Code
 Introduction
 This guide aims to help developing and contributing code to the libbsd.  One
 goal of the libbsd is to stay in synchronization with FreeBSD.  This is only
@@ -10,31 +10,31 @@ feasible if certain rules are in place.  Otherwise, managing more than a
 thousand imported source files will become too labour intensive eventually.
 What is in the Git Repository
 The libbsd a self-contained kit with FreeBSD and RTEMS components
 pre-merged. The Waf wscript in libbsd automatically generates the build when
 you run waf by reading the modules and module's source, header, defines and
-special flags from `libbsd.py`. This is the same module data used to manage
+special flags from ``libbsd.py``. This is the same module data used to manage
 the FreeBSD source.
-Any changes to source in the `freebsd` directories will need to be merged
-upstream into our master FreeBSD checkout, the `freebsd-org` submodule.
+Any changes to source in the ``freebsd`` directories will need to be merged
+upstream into our master FreeBSD checkout, the ``freebsd-org`` submodule.
-The repository contains two FreeBSD source trees.  In the `freebsd` directory
+The repository contains two FreeBSD source trees.  In the ``freebsd`` directory
 are the so called *managed* FreeBSD sources used to build the BSD library.
-The FreeBSD source in `freebsd-org` is the *master* version.  The
-`freebsd-to-rtems.py` script is used to transfer files between the two trees
-using the module defnitions in `libbsd.py`.  In general terms, if you have
+The FreeBSD source in ``freebsd-org`` is the *master* version.  The
+``freebsd-to-rtems.py`` script is used to transfer files between the two trees
+using the module defnitions in ``libbsd.py``.  In general terms, if you have
 modified managed FreeBSD sources, you will need to run the script in *revert*
-or *reverse* mode using the `-R` switch.  This will copy the source back to
-your local copy of the master FreeBSD source so you can run `git diff` against
+or *reverse* mode using the ``-R`` switch.  This will copy the source back to
+your local copy of the master FreeBSD source so you can run ``git diff`` against
 the upstream FreeBSD source.  If you want to transfer source files from the
 master FreeBSD source to the manged FreeBSD sources, then you must run the
 script in *forward* mode (the default).
 Kernel and User Space
 FreeBSD uses virtual memory to run separate address spaces. The kernel is one
 address space and each process the kernel runs is another separate address
@@ -44,8 +44,8 @@ linked executable for the kernel and user land maintains the separation.
 RTEMS is a single address space operating system and that means the kernel and
 user space code have to be linked to together and be able to run side by
 side. This creates additional complexity when working with the FreeBSD code,
-for example the FreeBSD kernel has a `malloc` call with a different signature
-to the user land `malloc` call. The RTEMS LibBSD support code provides
+for example the FreeBSD kernel has a ``malloc`` call with a different signature
+to the user land ``malloc`` call. The RTEMS LibBSD support code provides
 structured ways to manage the separation.
 LibBSD manages the integration of kernel and user code by knowing the context
@@ -55,52 +55,52 @@ include paths a source file sees. The kernel code sees the kernel, CPU
 specific and build system generated include paths in that order. User code
 sees the user include paths then the kernel, CPU specific and build system
 generated include paths in that order. The FreeBSD OS include path
-`/usr/include` has a mix of kernel and user space header files. The kernel
+``/usr/include`` has a mix of kernel and user space header files. The kernel
 headers let user space code cleanly access structures the kernel exports. If a
 user header file has the same name as a kernel header file the user file will
 be used in the user code rather than the kernel file. If the user code
 includes a kernel header that file will be found and included.
 Organization
 The top level directory contains a few directories and files. The following
 are important to understand
-* `freebsd-to-rtems.py` - script to convert to and free FreeBSD and RTEMS trees,
-* `create-kernel-namespace.sh` - script to create the kernel namespace header `<machine/rtems-bsd-kernel-namespace.h>`,
-* `wscript` - automatically generates the build from libbsd.py,
-* `libbsd.py` - modules, sources, compile flags, and dependencies
-* `freebsd/` - from FreeBSD by script,
-* `rtemsbsd/` - RTEMS specific implementations of FreeBSD kernel support routines,
-* `testsuite/` - RTEMS specific tests, and
-* `libbsd.txt` - documentation in Asciidoc.
+* ``freebsd-to-rtems.py`` - script to convert to and free FreeBSD and RTEMS trees,
+* ``create-kernel-namespace.sh`` - script to create the kernel namespace header ``<machine/rtems-bsd-kernel-namespace.h>``,
+* ``wscript`` - automatically generates the build from libbsd.py,
+* ``libbsd.py`` - modules, sources, compile flags, and dependencies
+* ``freebsd/`` - from FreeBSD by script,
+* ``rtemsbsd/`` - RTEMS specific implementations of FreeBSD kernel support routines,
+* ``testsuite/`` - RTEMS specific tests, and
+* ``libbsd.txt`` - documentation in Asciidoc.
 Moving Code Between Managed and Master FreeBSD Source
-The script `freebsd-to-rtems.py` is used to copy code from FreeBSD to the
+The script ``freebsd-to-rtems.py`` is used to copy code from FreeBSD to the
 rtems-libbsd tree and to reverse this process. This script attempts to
 automate this process as much as possible and performs some transformations
 on the FreeBSD code. Its command line arguments are shown below:
-freebsd-to-rtems.py [args]
-  -?|-h|--help      print this and exit
-  -d|--dry-run      run program but no modifications
-  -D|--diff         provide diff of files between trees
-  -e|--early-exit   evaluate arguments, print results, and exit
-  -m|--makefile     Warning: depreciated and will be removed
-  -b|--buildscripts just generate the build scripts
-  -S|--stats        Print a statistics report
-  -R|--reverse      default FreeBSD -> RTEMS, reverse that
-  -r|--rtems        RTEMS Libbsd directory (default: '.')
-  -f|--freebsd      FreeBSD SVN directory (default: 'freebsd-org')
-  -c|--config       Output the configuration then exit
-  -v|--verbose      enable verbose output mode
-In its default mode of operation, `freebsd-to-rtems.py` is used to copy code
+.. code-block:: none
+    freebsd-to-rtems.py [args]
+      -?|-h|--help      print this and exit
+      -d|--dry-run      run program but no modifications
+      -D|--diff         provide diff of files between trees
+      -e|--early-exit   evaluate arguments, print results, and exit
+      -m|--makefile     Warning: depreciated and will be removed
+      -b|--buildscripts just generate the build scripts
+      -S|--stats        Print a statistics report
+      -R|--reverse      default FreeBSD -> RTEMS, reverse that
+      -r|--rtems        RTEMS Libbsd directory (default: '.')
+      -f|--freebsd      FreeBSD SVN directory (default: 'freebsd-org')
+      -c|--config       Output the configuration then exit
+      -v|--verbose      enable verbose output mode
+In its default mode of operation, ``freebsd-to-rtems.py`` is used to copy code
 from FreeBSD to the rtems-libbsd tree and perform transformations.
 In *reverse mode*, this script undoes those transformations and copies
@@ -127,18 +127,18 @@ those files into the RTEMS FreeBSD tree.
 The following is an example forward run with no changes.
-$ ./freebsd-to-rtems.py -v
-Verbose:                     yes (1)
-Dry Run:                     no
-Diff Mode Enabled:           no
-Only Generate Build Scripts: no
-RTEMS Libbsd Directory:      .
-FreeBSD SVN Directory:       freebsd-org
-Direction:                   forward
-Forward from FreeBSD GIT into  .
-0 file(s) were changed:
+    $ ./freebsd-to-rtems.py -v
+    Verbose:                     yes (1)
+    Dry Run:                     no
+    Diff Mode Enabled:           no
+    Only Generate Build Scripts: no
+    RTEMS Libbsd Directory:      .
+    FreeBSD SVN Directory:       freebsd-org
+    Direction:                   forward
+    Forward from FreeBSD GIT into  .
+    0 file(s) were changed:
 The script may also be used to generate a diff in either forward or reverse
 direction.
@@ -147,47 +147,49 @@ You can add more than one verbose option (-v) to the command line and get more
 detail and debug level information from the command.
 FreeBSD Baseline
 Use
-$ git log freebsd-org
+    $ git log freebsd-org
 to figure out the current FreeBSD baseline.
 How to Import Code from FreeBSD
 * In case you import files from a special FreeBSD version, then update the list above.
-* Run `git status` and make sure your working directory is clean.
-* Run `./freebsd-to-rtems.py -R`
-* Run `./freebsd-to-rtems.py`
-* Run `git status` and make sure your working directory is clean.  If you see modified files, then the `freebsd-to-rtems.py` script needs to be fixed first.
-* Add the files to import to `libbsd.py` and your intended build set (for example `buildset/default.ini`.
-* Immediately check in the imported files without the changes to `libbsd.py` and the buildsets.  Do not touch the imported files yourself at this point.
+* Run ``git status`` and make sure your working directory is clean.
+* Run ``./freebsd-to-rtems.py -R``
+* Run ``./freebsd-to-rtems.py``
+* Run ``git status`` and make sure your working directory is clean.  If you see modified files, then the ``freebsd-to-rtems.py`` script needs to be fixed first.
+* Add the files to import to ``libbsd.py`` and your intended build set (for example ``buildset/default.ini``.
+* Immediately check in the imported files without the changes to ``libbsd.py`` and the buildsets.  Do not touch the imported files yourself at this point.
 * Port the imported files to RTEMS.  See 'Rules for Modifying FreeBSD Source'.
 * Add a test to the testsuite if possible.
-* Run `./create-kernel-namespace.sh` if you imported kernel space headers.  Add only your new defines via `git add -p rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h`.
+* Run ``./create-kernel-namespace.sh`` if you imported kernel space headers.  Add only your new defines via ``git add -p rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h``.
 * Create one commit from this.
 The -S or --stats option generates reports the changes we have made to
 FreeBSD. If the code has been reserved into the original FreeBSD tree it will
 show nothing has changed. To see what we have change:
-$ cd freebsd-org
-$ git checkout -- .
-$ cd ..
-$ ./freebsd-to-rtems.py -R -S -d
+    $ cd freebsd-org
+    $ git checkout -- .
+    $ cd ..
+    $ ./freebsd-to-rtems.py -R -S -d
 The report lists the files change based on the opacity level. The opacity is a
 measure on how much of a file differs from the original FreeBSD source. The
 lower the value the more transparent the source file it.
 Porting of User-Space Utilities
 The theory behind the described method is to put all BSS and initialized data
 objects into a named section. This section then will be saved before the code is
@@ -196,157 +198,165 @@ threaded execution of the application but minimizes the necessary changes to the
 original FreeBSD code.
 * Import and commit the unchanged source files like described above.
-* Add the files to the [libbsd.py](libbsd.py) and build them.
+* Add the files to the `<libbsd.py>`_ and build them.
 * Check the sources for everything that can be made const. This type of patches
   should go back to the upstream FreeBSD sources.
 * Move static variables out of functions if necessary (search for
   "\tstatic"). These patches most likely will not be accepted into FreeBSD.
 * Add a rtems_bsd_command_PROGNAME() wrapper function to the source file
   containing the main function (e.g. PROGNAME = pfctl). For an example look at
-  `rtems_bsd_command_pfctl()` in [pfctl.c](freebsd/sbin/pfctl/pfctl.c).
+  ``rtems_bsd_command_pfctl()`` in `pfctl.c <freebsd/sbin/pfctl/pfctl.c>`_.
 * You probably have to use getopt_r() instead of getopt(). Have a look at
-  [pfctl.c](freebsd/sbin/pfctl/pfctl.c).
+  `pfctl.c <freebsd/sbin/pfctl/pfctl.c>`_.
 * Build the libbsd without optimization.
-* Use the `userspace-header-gen.py` to generate some necessary header
-  files. It will generate one `rtems-bsd-PROGNAME-MODULE-data.h` per object file, one
-  `rtems-bsd-PROGNAME-namespace.h` and one `rtems-bsd-PROGNAME-data.h`. To call
+* Use the ``userspace-header-gen.py`` to generate some necessary header
+  files. It will generate one ``rtems-bsd-PROGNAME-MODULE-data.h`` per object file, one
+  ``rtems-bsd-PROGNAME-namespace.h`` and one ``rtems-bsd-PROGNAME-data.h``. To call
   the script, you have to compile the objects and afterwards run the helper
   script with a call similar to this one:
-  `python ./userspace-header-gen.py build/arm-rtems4.12-xilinx_zynq_a9_qemu/freebsd/sbin/pfctl/*.o -p pfctl`
+  ``python ./userspace-header-gen.py build/arm-rtems4.12-xilinx_zynq_a9_qemu/freebsd/sbin/pfctl/*.o -p pfctl``
   Replace the name (given via -p option) by the name of the userspace tool. It
   has to match the name that is used in the RTEMS linker set further below.
-  `Note:` the script `userspace-header-gen.py` depends on pyelftools. It can be
+  ``Note:`` the script ``userspace-header-gen.py`` depends on pyelftools. It can be
   installed using pip:
-  `pip install --user pyelftools`
+  ``pip install --user pyelftools``
 * If you regenerated files that have already been generated, you may have to
   remove RTEMS-specific names from the namespace. The defaults (linker set names
   and rtems_bsd_program_.*) should already be filtered.
 * Put the generated header files into the same folder like the source files.
 * At the top of each source file place the following right after the user-space header:
-  ```c
-  #ifdef __rtems__
-  #include <machine/rtems-bsd-program.h>
-  #include "rtems-bsd-PROGNAME-namespace.h"
-  #endif /* __rtems__ */
+  .. code-block:: c
+       #ifdef __rtems__
+       #include <machine/rtems-bsd-program.h>
+       #include "rtems-bsd-PROGNAME-namespace.h"
+       #endif /* __rtems__ */
   The following command may be useful:
-  sed -i 's%#include <machine/rtems-bsd-user-space.h>%#include <machine/rtems-bsd-user-space.h>\n\n#ifdef __rtems__\n#include <machine/rtems-bsd-program.h>\n#include "rtems-bsd-PROGNAME-namespace.h"\n#endif /* __rtems__ */%' *.c
+  .. code-block:: none
+       sed -i 's%#include <machine/rtems-bsd-user-space.h>%#include <machine/rtems-bsd-user-space.h>\n\n#ifdef __rtems__\n#include <machine/rtems-bsd-program.h>\n#include "rtems-bsd-PROGNAME-namespace.h"\n#endif /* __rtems__ */%' *.c
 * At the bottom of each source file place the follwing:
-  ```c
-  #ifdef __rtems__
-  #include "rtems-bsd-PROGNAME-FILE-data.h"
+  .. code-block:: c
+       #ifdef __rtems__
+       #include "rtems-bsd-PROGNAME-FILE-data.h"
-  for i in *.c ; do n=$(basename $i .c) ; echo -e "#ifdef __rtems__\n#include \"rtems-bsd-PROGNAME-$n-data.h\"\n#endif /* __rtems__ */" >> $i ; done
+       for i in *.c ; do n=$(basename $i .c) ; echo -e "#ifdef __rtems__\n#include \"rtems-bsd-PROGNAME-$n-data.h\"\n#endif /* __rtems__ */" >> $i ; done
 * Create one compilable commit.
-Changes in FreeBSD files must be done using `__rtems__` C pre-processor guards.
+Changes in FreeBSD files must be done using ``__rtems__`` C pre-processor guards.
 This makes synchronization with the FreeBSD upstream easier and is very
 important.  Patches which do not follow these rules will be rejected.  Only add
-lines.  If your patch contains lines starting with a `-`, then this is wrong.
-Subtract code by added `#ifndef __rtems__`.  For example:
-```c
-/* Global variables for the kernel. */
-#ifndef __rtems__
-/* 1.1 */
-extern char kernelname[MAXPATHLEN];
-#endif /* __rtems__ */
-extern int tick;			/* usec per tick (1000000 / hz) */
-```c
-#if defined(_KERNEL) || defined(_WANT_FILE)
-#ifdef __rtems__
-#include <rtems/libio_.h>
-#include <sys/fcntl.h>
- * Kernel descriptor table.
- * One entry for each open kernel vnode and socket.
- * Below is the list of locks that protects members in struct file.
- * (f) protected with mtx_lock(mtx_pool_find(fp))
- * (d) cdevpriv_mtx
- * none	not locked
-```c
-extern int profprocs;			/* number of process's profiling */
-#ifndef __rtems__
-extern volatile int ticks;
-#else /* __rtems__ */
-#include <rtems/score/watchdogimpl.h>
-#define ticks _Watchdog_Ticks_since_boot
-#endif /* _KERNEL */
-Add nothing (even blank lines) before or after the `__rtems__` guards.  Always
-include a `__rtems__` in the guards to make searches easy, so use
-* `#ifndef __rtems__`,
-* `#ifdef __rtems__`,
-* `#else /* __rtems__ */`, and
-* `#endif /* __rtems__ */`.
+lines.  If your patch contains lines starting with a ``-``, then this is wrong.
+Subtract code by added ``#ifndef __rtems__``.  For example:
+.. code-block:: c
+     /* Global variables for the kernel. */
+     #ifndef __rtems__
+     /* 1.1 */
+     extern char kernelname[MAXPATHLEN];
+     extern int tick;			/* usec per tick (1000000 / hz) */
+.. code-block:: c
+     #if defined(_KERNEL) || defined(_WANT_FILE)
+     #ifdef __rtems__
+     #include <rtems/libio_.h>
+     #include <sys/fcntl.h>
+      * Kernel descriptor table.
+      * One entry for each open kernel vnode and socket.
+      * Below is the list of locks that protects members in struct file.
+      * (f) protected with mtx_lock(mtx_pool_find(fp))
+      * (d) cdevpriv_mtx
+      * none	not locked
+.. code-block:: c
+     extern int profprocs;			/* number of process's profiling */
+     #ifndef __rtems__
+     extern volatile int ticks;
+     #else /* __rtems__ */
+     #include <rtems/score/watchdogimpl.h>
+     #define ticks _Watchdog_Ticks_since_boot
+     #endif /* _KERNEL */
+Add nothing (even blank lines) before or after the ``__rtems__`` guards.  Always
+include a ``__rtems__`` in the guards to make searches easy, so use
+* ``#ifndef __rtems__``,
+* ``#ifdef __rtems__``,
+* ``#else /* __rtems__ */``, and
+* ``#endif /* __rtems__ */``.
 The guards must start at the begin of the line.  Examples for wrong guards:
-```c
-static void
-guards_must_start_at_the_begin_of_the_line(int j)
-	/* WRONG */
-	#ifdef __rtems__
-	return (j + 1);
-	#else /* __rtems__ */
-	return (j + 2);
-static void
-missing_rtems_comments_in_the_guards(int j)
-#ifdef __rtems__
-	return (j + 3);
-/* WRONG */
-#else
-	return (j + 4);
-#endif
+.. code-block:: c
+    static void
+    guards_must_start_at_the_begin_of_the_line(int j)
+            /* WRONG */
+            #ifdef __rtems__
+            return (j + 1);
+            return (j + 2);
+    static void
+    missing_rtems_comments_in_the_guards(int j)
+    #ifdef __rtems__
+            return (j + 3);
+    /* WRONG */
+    #else
+            return (j + 4);
+    #endif
 The FreeBSD build and configuration system uses option header files, e.g.
-`#include "opt_xyz.h"` in an unmodified FreeBSD file.  This include is
-transformed by the import script into `#include <rtems/bsd/local/opt_xyz.h>`.  Do
+``#include "opt_xyz.h"`` in an unmodified FreeBSD file.  This include is
+transformed by the import script into ``#include <rtems/bsd/local/opt_xyz.h>``.  Do
 not disable option header includes via guards.  Instead, add an empty option
-header, e.g. `touch rtemsbsd/include/rtems/bsd/local/opt_xyz.h`.
-```c
-/* WRONG */
-#ifndef __rtems__
-#include <rtems/bsd/local/opt_xyz.h>
+header, e.g. ``touch rtemsbsd/include/rtems/bsd/local/opt_xyz.h``.
+.. code-block:: c
+    /* WRONG */
+    #ifndef __rtems__
+    #include <rtems/bsd/local/opt_xyz.h>
 In general, provide empty header files and do not guard includes.
 For new code use
-[STYLE(9)](http://www.freebsd.org/cgi/man.cgi?query=style&apropos=0&sektion=9).
+`STYLE(9) <http://www.freebsd.org/cgi/man.cgi?query=style&apropos=0&sektion=9>`_.
 Do not format original FreeBSD code.  Do not perform white space changes even
 if you get git commit warnings.  Check your editor settings so that it doesn't
@@ -355,10 +365,10 @@ end of the file.  White space changes may result in conflicts during updates,
 especially changes at the end of a file.
 Automatically Generated FreeBSD Files
 Some source and header files are automatically generated during the FreeBSD
-build process.  The `Makefile.todo` file performs this manually.  The should be
-included in `freebsd-to-rtems.py` script some time in the future.  For details,
+build process.  The ``Makefile.todo`` file performs this manually.  The should be
+included in ``freebsd-to-rtems.py`` script some time in the future.  For details,
 see also
-[KOBJ(9)](http://www.freebsd.org/cgi/man.cgi?query=kobj&sektion=9&apropos=0).
+`KOBJ(9) <http://www.freebsd.org/cgi/man.cgi?query=kobj&sektion=9&apropos=0>`_.
diff --git a/README.md b/README.md
deleted file mode 100644
index 63711770..00000000
--- a/README.md
+++ /dev/null
@@ -1,286 +0,0 @@
-RTEMS LibBSD
-Welcome to building LibBSD for RTEMS using Waf. This package is a library
-containing various parts of the FreeBSD kernel ported to RTEMS. The library
-replaces the networking port of FreeBSD in the RTEMS kernel sources. This
-package is designed to be updated from the FreeBSD kernel sources and contains
-more than just the networking code.
-To build this package you need a current RTEMS tool set for your architecture,
-and a recent RTEMS kernel for your BSP installed. If you already have this, you
-can skip to step 5 of the build procedure.
-Building and Installing LibBSD
-The following instructions show you how to build and install the RTEMS Tool
-Suite for the `arm` target, the RTEMS kernel using the
-`arm/xilinx_zynq_a9_qemu` Board Support Package (BSP), and the LibBSD for this
-BSP.
-The Waf build support for RTEMS requires you provide your BSP name as an
-architecture and BSP pair. You must provide both or Waf will generate an error
-message during the configure phase.
-We will build an Xilinx Zynq Qemu BSP using the name
-*arm/xilinx_zynq_a9_qemu*.  You can copy and paste the shell commands below to
-do this.  The individual steps are explained afterwards.
-sandbox="$PWD/sandbox"
-mkdir sandbox
-cd "$sandbox"
-git clone git://git.rtems.org/rtems-source-builder.git
-git clone git://git.rtems.org/rtems.git
-git clone git://git.rtems.org/rtems-libbsd.git
-cd "$sandbox"
-cd rtems-source-builder/rtems
-../source-builder/sb-set-builder --prefix="$sandbox/rtems/6" 6/rtems-arm
-cd "$sandbox"
-cd rtems
-echo -e "[arm/xilinx_zynq_a9_qemu]\nRTEMS_POSIX_API = True" > config.ini
-./waf configure --prefix "$sandbox/rtems/6"
-./waf
-./waf install
-cd "$sandbox"
-cd rtems-libbsd
-git submodule init
-git submodule update rtems_waf
-./waf configure --prefix="$sandbox/rtems/6" \
-  --rtems-bsps=arm/xilinx_zynq_a9_qemu \
-  --buildset=buildset/default.ini
-./waf
-./waf install
-../rtems/6/bin/rtems-test --rtems-bsp=xilinx_zynq_a9_qemu build
-1. Create a sandbox directory:
-$ sandbox="$PWD/sandbox"
-$ mkdir sandbox
-2. Clone the repositories:
-$ cd "$sandbox"
-$ git clone git://git.rtems.org/rtems-source-builder.git
-$ git clone git://git.rtems.org/rtems.git
-$ git clone git://git.rtems.org/rtems-libbsd.git
-3. Build and install the tools:
-$ cd "$sandbox"
-$ cd rtems-source-builder/rtems
-$ ../source-builder/sb-set-builder --prefix="$sandbox/rtems/6" 6/rtems-arm
-4. Build and install the RTEMS Board Support Packages (BSP) you want to use:
-$ cd "$sandbox"
-$ cd rtems
-$ echo -e "[arm/xilinx_zynq_a9_qemu]\nRTEMS_POSIX_API = True" > config.ini
-$ ./waf configure --prefix "$sandbox/rtems/6"
-$ ./waf
-$ ./waf install
-5. Populate the rtems_waf git submodule.  Note, make sure you specify
-   'rtems_waf' or the FreeBSD kernel source will be cloned:
-$ cd "$sandbox"
-$ cd rtems-libbsd
-$ git submodule init
-$ git submodule update rtems_waf
-6. Run Waf's configure with your specific settings. In this case the path to
-   the tools and RTEMS are provided on the command line and so do not need to
-   be in your path or environment [1].  You can use
-   '--rtems-archs=arm,sparc,i386' or
-   '--rtems-bsps=arm/xilinx_zynq_a9_qemu,sparc/sis,i386/pc586' to build for
-   more than BSP at a time.  Note, you must provide the architecture and BSP as
-   a pair. Providing just the BSP name will fail. This call also explicitly
-   provides a buildset via the '--buildset=buildset/default.ini' option. If no
-   buildset is provided the default one (which is the same as the one provided
-   explicitly here) will be used. You can also provide multiple buildsets as a
-   coma separated list or via multiple '--buildset=x' options.
-$ cd "$sandbox"
-$ cd rtems-libbsd
-$ ./waf configure --prefix="$sandbox/rtems/6" \
-7. Build and install.  The LibBSD package will be installed into the prefix
-   provided to configure:
-$ cd "$sandbox"
-$ cd rtems-libbsd
-$ ./waf
-$ ./waf install
-9. Run the tests:
-$ cd "$sandbox"
-$ cd rtems-libbsd
-$ ../rtems/6/bin/rtems-test --rtems-bsp=xilinx_zynq_a9_qemu build
-It is good practice to keep your environment as empty as possible. Setting
-paths to tools or specific values to configure or control a build is dangerous
-because settings can leak between different builds and change what you expect a
-build to do. The Waf tool used here lets you specify on the command line the
-tools and RTEMS paths and this is embedded in Waf's configuration information.
-If you have a few source trees working at any one time with different tool sets
-or configurations you can easly move between them safe in the knowledge that
-one build will not infect another.
-Branches
-* master - branch intended for the RTEMS master which tracks the FreeBSD master
-  branch.  This branch must be used for libbsd development.  Back ports to the
-  6-freebsd-12 are allowed.
-* 6-freebsd-12 - branch intended for RTEMS 6 which tracks the FreeBSD stable/12
-  branch.  This branch is maintained and regular updates from FreeBSD are
-  planned.  It is recommended for production systems.
-* 5-freebsd-12 - branch belongs to the RTEMS 5 release. It is based on FreeBSD
-  stable/12 branch. It is recommended for production systems that use RTEMS 5.
-* 5 - branch belongs to the RTEMS 5 release. It is based on a FreeBSD
-  development version.  This branch is unmaintained.  Use 5-freebsd-12 for
-  RTEMS 5.
-* freebsd-9.3 - branch for some RTEMS version with a FreeBSD 9.3 baseline.
-  This branch is unmaintained.  It is recommended to update to RTEMS 5 or 6.
-* 4.11 - branch for the RTEMS 4.11 release series.  This branch is
-  unmaintained.  It is recommended to update to RTEMS 5 or 6.
-Updating RTEMS Waf Support
-If you have a working libbsd repository and new changes to the `rtems_waf`
-submodule has been made, you will need update. A `git status` will indicate
-there are new commits with:
-$ git status
-    [ snip output ]
-          modified:   rtems_waf (new commits)
-    [ snip output ]
-To update:
-Please make sure you use the exact command or you might find you are cloning
-the whole of the FreeBSD source tree. If that happens simply git ^C and try
-again.
-FreeBSD Kernel Options
-You can set FreeBSD kernel options during build configuration with the
---freebsd-option=a,b,c,... configuration command option.  This is an advanced
-option and should only be used if you are familiar with the internals of the
-FreeBSD kernel and what these options do.  Each of the comma separated options
-is converted to uppercase and passed as a compiler command line define (-D).
-The options are listed in:
-https://github.com/freebsd/freebsd/blob/master/sys/conf/NOTES
-An example to turn on a verbose kernel boot, verbose sysinit and bus debugging
-configure with:
---freebsd-options=bootverbose,verbose_sysinit,bus_debug
-To enable kernel internal consistency checking use:
---freebsd-options=invariants,invariant_support
-SMP Requirements
-In order to support
-[EPOCH(9)](https://www.freebsd.org/cgi/man.cgi?query=epoch&apropos=0&sektion=9)
-a scheduler with thread pinning support is required.  This is the case if you
-use the default scheduler configuration.  EPOCH(9) is a central synchronization
-mechanism of the network stack.
-Qemu and Networking
-You can use the Qemu simulator to run a LibBSD based application and connect it
-to a virtual network on your host.  You have to create a TAP virtual Ethernet
-interface for this:
-sudo tunctl -p -t qtap -u $(whoami)
-sudo ip link set dev qtap up
-sudo ip addr add 169.254.1.1/16 dev qtap
-You can show the interface state with the following command:
-$ ip addr show qtap
-27: qtap: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
-    link/ether 8e:50:a2:fb:e1:3b brd ff:ff:ff:ff:ff:ff
-    inet 169.254.1.1/16 scope global qtap
-       valid_lft forever preferred_lft forever
-You may have to assign the interface to a firewall zone.
-The Qemu command line varies by board support package, here is an example for
-the arm/xilinx_zynq_a9_qemu BSP:
-qemu-system-arm -serial null -serial mon:stdio -nographic \
-  -M xilinx-zynq-a9 -m 256M \
-  -net tap,ifname=qtap,script=no,downscript=no \
-  -net nic,model=cadence_gem,macaddr=0e:b0:ba:5e:ba:12 \
-  -kernel build/arm-rtems6-xilinx_zynq_a9_qemu-default/media01.exe
-After some seconds it will acquire a IPv4 link-local address, e.g.
-info: cgem0: probing for an IPv4LL address
-debug: cgem0: checking for 169.254.159.156
-You can connect to the target via telnet for example:
-$ telnet 169.254.159.156
-Trying 169.254.159.156...
-Connected to 169.254.159.156.
-Escape character is '^]'.
-RTEMS Shell on /dev/pty4. Use 'help' to list commands.
-TLNT [/] #
diff --git a/README.rst b/README.rst
new file mode 100644
index 00000000..75ce6dc5
--- /dev/null
+++ b/README.rst
@@ -0,0 +1,293 @@
+RTEMS LibBSD
+Welcome to building LibBSD for RTEMS using Waf. This package is a library
+containing various parts of the FreeBSD kernel ported to RTEMS. The library
+replaces the networking port of FreeBSD in the RTEMS kernel sources. This
+package is designed to be updated from the FreeBSD kernel sources and contains
+more than just the networking code.
+To build this package you need a current RTEMS tool set for your architecture,
+and a recent RTEMS kernel for your BSP installed. If you already have this, you
+can skip to step 5 of the build procedure.
+Building and Installing LibBSD
+The following instructions show you how to build and install the RTEMS Tool
+Suite for the ``arm`` target, the RTEMS kernel using the
+``arm/xilinx_zynq_a9_qemu`` Board Support Package (BSP), and the LibBSD for this
+BSP.
+The Waf build support for RTEMS requires you provide your BSP name as an
+architecture and BSP pair. You must provide both or Waf will generate an error
+message during the configure phase.
+We will build an Xilinx Zynq Qemu BSP using the name
+``arm/xilinx_zynq_a9_qemu``.  You can copy and paste the shell commands below to
+do this.  The individual steps are explained afterwards.
+    sandbox="$PWD/sandbox"
+    mkdir sandbox
+    cd "$sandbox"
+    git clone git://git.rtems.org/rtems-source-builder.git
+    git clone git://git.rtems.org/rtems.git
+    git clone git://git.rtems.org/rtems-libbsd.git
+    cd "$sandbox"
+    cd rtems-source-builder/rtems
+    ../source-builder/sb-set-builder --prefix="$sandbox/rtems/6" 6/rtems-arm
+    cd "$sandbox"
+    cd rtems
+    echo -e "[arm/xilinx_zynq_a9_qemu]\nRTEMS_POSIX_API = True" > config.ini
+    ./waf configure --prefix "$sandbox/rtems/6"
+    ./waf
+    ./waf install
+    cd "$sandbox"
+    cd rtems-libbsd
+    git submodule init
+    git submodule update rtems_waf
+    ./waf configure --prefix="$sandbox/rtems/6" \
+      --rtems-bsps=arm/xilinx_zynq_a9_qemu \
+      --buildset=buildset/default.ini
+    ./waf
+    ./waf install
+    ../rtems/6/bin/rtems-test --rtems-bsp=xilinx_zynq_a9_qemu build
+1. Create a sandbox directory:
+       $ sandbox="$PWD/sandbox"
+       $ mkdir sandbox
+2. Clone the repositories:
+       $ cd "$sandbox"
+       $ git clone git://git.rtems.org/rtems-source-builder.git
+       $ git clone git://git.rtems.org/rtems.git
+       $ git clone git://git.rtems.org/rtems-libbsd.git
+3. Build and install the tools:
+       $ cd "$sandbox"
+       $ cd rtems-source-builder/rtems
+       $ ../source-builder/sb-set-builder --prefix="$sandbox/rtems/6" 6/rtems-arm
+4. Build and install the RTEMS Board Support Packages (BSP) you want to use:
+       $ cd "$sandbox"
+       $ cd rtems
+       $ echo -e "[arm/xilinx_zynq_a9_qemu]\nRTEMS_POSIX_API = True" > config.ini
+       $ ./waf configure --prefix "$sandbox/rtems/6"
+       $ ./waf
+       $ ./waf install
+5. Populate the ``rtems_waf`` git submodule.  Note, make sure you specify
+   ``rtems_waf`` or the FreeBSD kernel source will be cloned:
+       $ cd "$sandbox"
+       $ cd rtems-libbsd
+       $ git submodule init
+       $ git submodule update rtems_waf
+6. Run Waf's configure with your specific settings. In this case the path to
+   the tools and RTEMS are provided on the command line and so do not need to
+   be in your path or environment, see comment below.  You can use
+   ``--rtems-archs=arm,sparc,i386`` or
+   ``--rtems-bsps=arm/xilinx_zynq_a9_qemu,sparc/sis,i386/pc586`` to build for
+   more than BSP at a time.  Note, you must provide the architecture and BSP as
+   a pair. Providing just the BSP name will fail. This call also explicitly
+   provides a buildset via the ``--buildset=buildset/default.ini`` option. If no
+   buildset is provided the default one (which is the same as the one provided
+   explicitly here) will be used. You can also provide multiple buildsets as a
+   coma separated list or via multiple ``--buildset=x`` options.
+       $ cd "$sandbox"
+       $ cd rtems-libbsd
+       $ ./waf configure --prefix="$sandbox/rtems/6" \
+7. Build and install.  The LibBSD package will be installed into the prefix
+   provided to configure:
+       $ cd "$sandbox"
+       $ cd rtems-libbsd
+       $ ./waf
+       $ ./waf install
+9. Run the tests:
+       $ cd "$sandbox"
+       $ cd rtems-libbsd
+       $ ../rtems/6/bin/rtems-test --rtems-bsp=xilinx_zynq_a9_qemu build
+It is good practice to keep your environment as empty as possible. Setting
+paths to tools or specific values to configure or control a build is dangerous
+because settings can leak between different builds and change what you expect a
+build to do. The Waf tool used here lets you specify on the command line the
+tools and RTEMS paths and this is embedded in Waf's configuration information.
+If you have a few source trees working at any one time with different tool sets
+or configurations you can easly move between them safe in the knowledge that
+one build will not infect another.
+Branches
+master
+    This branch is intended for the RTEMS master which tracks the FreeBSD
+    master branch.  This branch must be used for libbsd development.  Back
+    ports to the 6-freebsd-12 are allowed.
+6-freebsd-12
+    This branch is intended for RTEMS 6 which tracks the FreeBSD stable/12
+    branch.  This branch is maintained and regular updates from FreeBSD are
+    planned.  It is recommended for production systems.
+5-freebsd-12
+    This branch belongs to the RTEMS 5 release. It is based on FreeBSD
+    stable/12 branch. It is recommended for production systems that use
+    RTEMS 5.
+5
+   This branch belongs to the RTEMS 5 release. It is based on a FreeBSD
+   development version.  This branch is unmaintained.  Use 5-freebsd-12 for
+   RTEMS 5.
+freebsd-9.3
+    Is the branch for some RTEMS version with a FreeBSD 9.3 baseline.  This
+    branch is unmaintained.  It is recommended to update to RTEMS 5 or 6.
+4.11
+    Is the branch for the RTEMS 4.11 release series.  This branch is
+    unmaintained.  It is recommended to update to RTEMS 5 or 6.
+Updating RTEMS Waf Support
+If you have a working libbsd repository and new changes to the ``rtems_waf``
+submodule has been made, you will need update. A ``git status`` will indicate
+there are new commits with:
+    $ git status
+        [ snip output ]
+              modified:   rtems_waf (new commits)
+        [ snip output ]
+To update:
+Please make sure you use the exact command or you might find you are cloning
+the whole of the FreeBSD source tree. If that happens simply git ^C and try
+again.
+FreeBSD Kernel Options
+You can set FreeBSD kernel options during build configuration with the
+--freebsd-option=a,b,c,... configuration command option.  This is an advanced
+option and should only be used if you are familiar with the internals of the
+FreeBSD kernel and what these options do.  Each of the comma separated options
+is converted to uppercase and passed as a compiler command line define (-D).
+The options are listed in the FreeBSD
+`NOTES <https://github.com/freebsd/freebsd/blob/master/sys/conf/NOTES>`_
+file.
+An example to turn on a verbose kernel boot, verbose sysinit and bus debugging
+configure with:
+    --freebsd-options=bootverbose,verbose_sysinit,bus_debug
+To enable kernel internal consistency checking use:
+    --freebsd-options=invariants,invariant_support
+SMP Requirements
+In order to support
+`EPOCH(9) <https://www.freebsd.org/cgi/man.cgi?query=epoch&apropos=0&sektion=9>`_
+a scheduler with thread pinning support is required.  This is the case if you
+use the default scheduler configuration.  EPOCH(9) is a central synchronization
+mechanism of the network stack.
+Qemu and Networking
+You can use the Qemu simulator to run a LibBSD based application and connect it
+to a virtual network on your host.  You have to create a TAP virtual Ethernet
+interface for this:
+    sudo tunctl -p -t qtap -u $(whoami)
+    sudo ip link set dev qtap up
+    sudo ip addr add 169.254.1.1/16 dev qtap
+You can show the interface state with the following command:
+    $ ip addr show qtap
+    27: qtap: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
+        link/ether 8e:50:a2:fb:e1:3b brd ff:ff:ff:ff:ff:ff
+        inet 169.254.1.1/16 scope global qtap
+           valid_lft forever preferred_lft forever
+You may have to assign the interface to a firewall zone.
+The Qemu command line varies by board support package, here is an example for
+the arm/xilinx_zynq_a9_qemu BSP:
+    qemu-system-arm -serial null -serial mon:stdio -nographic \
+      -M xilinx-zynq-a9 -m 256M \
+      -net tap,ifname=qtap,script=no,downscript=no \
+      -net nic,model=cadence_gem,macaddr=0e:b0:ba:5e:ba:12 \
+      -kernel build/arm-rtems6-xilinx_zynq_a9_qemu-default/media01.exe
+After some seconds it will acquire a IPv4 link-local address, e.g.
+    info: cgem0: probing for an IPv4LL address
+    debug: cgem0: checking for 169.254.159.156
+You can connect to the target via telnet for example:
+    $ telnet 169.254.159.156
+    Trying 169.254.159.156...
+    Connected to 169.254.159.156.
+    Escape character is '^]'.
+    RTEMS Shell on /dev/pty4. Use 'help' to list commands.
+    TLNT [/] #
2.35.3
