GCC version for RTEMS 6?
Sebastian Huber
Tue May 24 07:01:55 UTC 2022
On 24/05/2022 08:43, Sebastian Huber wrote:
> On 24/05/2022 02:32, Chris Johns wrote:
>> On 6/5/2022 4:16 pm, Sebastian Huber wrote:
>>>> - aarch64 bsps
>>>> These BSPs generated lots of warnings in the testsuite due to this
>>>> line:
>>>> https://git.rtems.org/rtems/tree/bsps/aarch64/include/bsp/start.h#n175
>>>> The warning is about comparing arrays. I have not looked deeper.
>>> This can be fixed by using RTEMS_OBFUSCATE_VARIABLE().
>> Sorry, I do not know how to use this macro to remove the warning?
> For this macro you need a stack variable.
> I guess the warning could be also removed using this compiler note:
> rtems/bsps/aarch64/include/bsp/start.h:175:28: note: use
> '&bsp_vector_table_end[0] != &bsp_vector_table_size[0]' to compare the
> addresses
> What is the purpose of AArch64_start_set_vector_base()? Do we need this
> at all on the aarch64 target?
Also why is this function exposed by <bsp.h>?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
